VTunerClient 连接失败
电脑端按照Index of /downloads/sdk/LNX6.1.83_PL5.1_V1.1.0/software_tools/isp_tuning_toolkits/ 安装了VTunerClient 和matalab_runtime。
地瓜派上运行:sudo bash run_tuning.sh --tune 1和bash run_tuning.sh --run 5,输出如下:sunrise@ubuntu:/app/multimedia_samples/tuning_tool$ sudo bash run_tuning.sh --tune 1 -p 45678
Open vtuner_server Success! Please connect VtunerClient
sunrise@ubuntu:/app/multimedia_samples/tuning_tool$ bash run_tuning.sh --run 5
Executing: ./isp_tuning --offline -s sensor=5
Offline mode enabled!!!
Using index:5 sensor_name:sc132gs-1280p config_file:linear_1088x1280_raw10_60fps_1lane.c
[INFO] RDK board_id is 302, so skip csi test for index 1 and index 3
mipi mclk is not configed.
INFO: Found sensor_name:sc132gs-1280p on mipi rx csi 0, i2c addr 0x30, config_file:linear_1088x1280_raw10_60fps_1lane.c
Pipeline index 0:
Sensor index: 5
Sensor name: sc132gs-1280p
Use mipi host: 0
[tuning_tool]: csi0 ignore mclk ex attr, because not config mclk.
start_hbplayer_thread start success. pid 281472927355136
create_socket_listen—176, listern 0xffff80001410
create a listener, port is 10086
create_socket_event—201, t_base 0xaaaaf1867d50 event base is 0xffff80000c70, listener 0xffff80001410
start_dump_server_thread start success.
在电脑端运行VTunerClient,端口输入45678,地瓜派没反应。端口输入10086,地瓜派会连接成功,但是很快就连接失败。输出如下:create a new socket success.
conn_eventcb:Connection closed. 。。。我想调节ISP,请问如何解决这个问题?
