[问题分类]:硬件上连接USB摄像头疑似锁帧率问题
[板卡类型]: [RDK S100] ,系统版本 4.0.5
[问题描述]:RDK S100上外接摄像头,采图帧率上限几乎锁死在60fps。相关代码在电脑开发端测试,采图可以达到200fps,但在板端运行仅有60fps。
开发机端代码如下:
import argparse
import threading
import time
CAMERA_INDEX = 0 # 当前外接摄像头是 camera 0
FORMAT = “MJPG” # 必须 MJPG 才能上 200fps
DEFAULT_W = 640 # 实测中 最高分辨率+最高帧率 的档位
DEFAULT_H = 480
FPS_TARGET = 1000 # 请求超高帧率, 逼相机协商出上限 (协商出 400)
DISPLAY_DIV = 4 # 显示节流: 每 4 个新帧显示一帧 (~50fps 显示)
LOG_INTERVAL = 1.0 # 终端 fps 打印间隔(秒)
def fourcc_str(v):
"""把 fourcc 整数解码成可读字符串, 非法值返回 '-'."""
try:
if not v:
return "-"
s = "".join(chr((v >> (8 \* i)) & 0xFF) for i in range(4))
return s if s.isprintable() else "-"
except Exception:
return "-"
def open_camera(idx, w, h):
"""按 MSMF + MJPG 打开相机并设好参数, 返回 cap 或 None."""
cap = cv2.VideoCapture(idx, cv2.CAP_MSMF)
if not cap.isOpened():
return None
cap.set(cv2.CAP_PROP_FOURCC, cv2.VideoWriter_fourcc(\*FORMAT))
cap.set(cv2.CAP_PROP_FRAME_WIDTH, w)
cap.set(cv2.CAP_PROP_FRAME_HEIGHT, h)
cap.set(cv2.CAP_PROP_FPS, FPS_TARGET)
return cap
class Grabber:
"""采集线程: 独占 read(), 只保留最新一帧, 并累计成功读到的帧数.
采集在独立线程里跑满, 不因显示/处理变慢而掉帧;
count 单调递增, 主循环用它算真实采集帧率.
def \__init_\_(self, cap):
self.cap = cap
self.lock = threading.Lock()
self.frame = None # 最新帧 (可能仍是旧的, 直到下一次 read 更新)
self.count = 0 # 累计成功读取帧数
def run(self):
while True:
ok, f = self.cap.read()
if not ok:
continue
with self.lock:
self.frame = f
self.count += 1
def headless_run(cap, seconds):
"""不开窗口: 跑 seconds 秒, 只打印采集 fps, 用于验证纯采集速度."""
g = Grabber(cap)
threading.Thread(target=g.run, daemon=True).start()
last_cap = 0
t0 = time.perf_counter()
t_last = t0
while time.perf_counter() - t0 < seconds:
time.sleep(LOG_INTERVAL)
with g.lock:
cur = g.count
now = time.perf_counter()
fps = (cur - last_cap) / (now - t_last)
last_cap = cur
t_last = now
print("采集 %.1f fps" % fps, flush=True)
def gui_run(cap, div, autoclose=0):
"""窗口模式: 显示节流 + 终端实时打印 采集/显示 fps, Esc 退出.
autoclose>0 时到点自动退出 (供命令行/脚本自动化测试).
g = Grabber(cap)
last_cap = 0 # 上次采样时的采集计数
last_show = 0 # 上次采样时的显示计数
last_shown_cap = 0 # 上次已显示帧对应的采集计数
show_count = 0
t_last = time.perf_counter()
t_start = t_last
while True:
time.sleep(0.001) # 关键: 让出 GIL, 否则死循环会饿死采集线程 (实测会掉到\~35fps)
with g.lock:
f = g.frame
cur_cap = g.count
if f is None:
continue
\# 节流: 每 div 个新帧才显示一次 (显示帧率 = 采集帧率/div)
if cur_cap - last_shown_cap >= div:
cv2.imshow("cam", f)
last_shown_cap = cur_cap
show_count += 1
if cv2.waitKey(1) & 0xFF == 27: # Esc 退出
break
\# 到点自动退出 (autoclose>0 时)
if autoclose > 0 and time.perf_counter() - t_start >= autoclose:
print("== 自动退出 (%.0f 秒到点) ==" % autoclose, flush=True)
break
\# 定时打印实时帧率
if now - t_last >= LOG_INTERVAL:
cap_fps = (cur_cap - last_cap) / (now - t_last)
show_fps = (show_count - last_show) / (now - t_last)
print("采集 %6.1f fps | 显示 %6.1f fps | 缓冲帧数 %d"
% (cap_fps, show_fps, cur_cap - last_shown_cap), flush=True)
last_cap = cur_cap
last_show = show_count
t_last = now
def main():
ap = argparse.ArgumentParser(description="采集/显示分离 + 实时fps (追求最高采集帧率)")
ap.add_argument("--device", type=int, default=CAMERA_INDEX, help="相机索引, 默认0")
ap.add_argument("--w", type=int, default=DEFAULT_W, help="分辨率宽, 默认640")
ap.add_argument("--h", type=int, default=DEFAULT_H, help="分辨率高, 默认480")
ap.add_argument("--div", type=int, default=DISPLAY_DIV, help="显示节流: 每N个新帧显示一帧")
ap.add_argument("--headless", type=float, default=0,
help=">0 时不开窗口, 只测该秒数的纯采集帧率")
ap.add_argument("--autoclose", type=float, default=0,
help=">0 时窗口模式到点自动退出 (供命令行测试)")
a = ap.parse_args()
cap = open_camera(a.device, a.w, a.h)
if cap is None:
print("\[!\] 无法打开 camera %d (%s %dx%d)" % (a.device, FORMAT, a.w, a.h))
return
\# 读回真实协商值 (fourcc 读回在 MSMF 下常不可靠, 仅参考)
nw = int(cap.get(cv2.CAP_PROP_FRAME_WIDTH))
nh = int(cap.get(cv2.CAP_PROP_FRAME_HEIGHT))
nfps = cap.get(cv2.CAP_PROP_FPS)
nfourcc = fourcc_str(int(cap.get(cv2.CAP_PROP_FOURCC)))
print("== camera %d 请求 %s %dx%d -> 协商 %dx%d @%.0ffps (fourcc=%s) =="
% (a.device, FORMAT, a.w, a.h, nw, nh, nfps, nfourcc))
if a.headless > 0:
headless_run(cap, a.headless)
print("== Esc 退出; 每 %.0f 秒打印一次实时帧率 ==" % LOG_INTERVAL)
gui_run(cap, a.div, a.autoclose)
cap.release()
if _name_ == “_main_”:
main()
