hb_mapper_makertbin.log:
2026-09-10 15:35:32,826 file: tool_utils.py func: tool_utils line No: 77 log will be stored in /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/hb_mapper_makertbin.log
2026-09-10 15:35:32,827 file: hb_mapper.py func: hb_mapper line No: 132 Start hb_mapper....
2026-09-10 15:35:32,828 file: hb_mapper.py func: hb_mapper line No: 133 hbdk version 3.49.15
2026-09-10 15:35:32,829 file: hb_mapper.py func: hb_mapper line No: 134 horizon_nn version 1.1.0
2026-09-10 15:35:32,829 file: hb_mapper.py func: hb_mapper line No: 135 hb_mapper version 1.24.3
2026-09-10 15:35:32,830 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 530 Start Model Convert....
2026-09-10 15:35:32,834 file: mapper_conf_parser.py func: mapper_conf_parser line No: 105 validating model_parameters...
2026-09-10 15:35:32,834 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1347 Using abs path /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/yolov11x_court_keypoint_256x256.onnx
2026-09-10 15:35:32,835 file: mapper_conf_parser.py func: mapper_conf_parser line No: 260 Using onnx model file: /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/yolov11x_court_keypoint_256x256.onnx
2026-09-10 15:35:33,608 file: onnx_parser.py func: onnx_parser line No: 39 Model input names: ['images']
2026-09-10 15:35:33,609 file: mapper_conf_parser.py func: mapper_conf_parser line No: 264 Model has 1 inputs according to model file
2026-09-10 15:35:33,610 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1347 Using abs path /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/yolov11x_court_keypoint_model_256x256_output
2026-09-10 15:35:33,610 file: mapper_conf_parser.py func: mapper_conf_parser line No: 287 working_dir does not exist. Creating working_dir: /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/yolov11x_court_keypoint_model_256x256_output
2026-09-10 15:35:33,612 file: mapper_conf_parser.py func: mapper_conf_parser line No: 438 node_dict: {self.node_dict}
2026-09-10 15:35:33,612 file: mapper_conf_parser.py func: mapper_conf_parser line No: 119 validating model_parameters finished
2026-09-10 15:35:33,613 file: mapper_conf_parser.py func: mapper_conf_parser line No: 123 validating input_parameters...
2026-09-10 15:35:33,613 file: mapper_conf_parser.py func: mapper_conf_parser line No: 492 Model name not given in yaml_file, using model name from model file: ['images']
2026-09-10 15:35:33,614 file: mapper_conf_parser.py func: mapper_conf_parser line No: 536 Model input shape not given in yaml_file, using shape from model file: [[1, 3, 256, 256]]
2026-09-10 15:35:33,614 file: mapper_conf_parser.py func: mapper_conf_parser line No: 719 Nv12 input layout info received. input type rt '0' is nv12 and layout 'NCHW' is not needed.
2026-09-10 15:35:33,615 file: mapper_conf_parser.py func: mapper_conf_parser line No: 135 validating input_parameters finished
2026-09-10 15:35:33,616 file: mapper_conf_parser.py func: mapper_conf_parser line No: 139 validating calibration_parameters...
2026-09-10 15:35:33,616 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1347 Using abs path /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/court_keypoint_calibration_data_rgb_f32_256x256
2026-09-10 15:35:33,617 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1007 The calibration dir name suffix is not the same as the value float32 of the parameter cal_data_type, the parameter setting will prevail
2026-09-10 15:35:33,618 file: mapper_conf_parser.py func: mapper_conf_parser line No: 155 validating calibration_parameters finished
2026-09-10 15:35:33,619 file: mapper_conf_parser.py func: mapper_conf_parser line No: 159 validating custom_op...
2026-09-10 15:35:33,619 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1076 custom_op does not exist, skipped
2026-09-10 15:35:33,620 file: mapper_conf_parser.py func: mapper_conf_parser line No: 165 validating custom_op finished
2026-09-10 15:35:33,621 file: mapper_conf_parser.py func: mapper_conf_parser line No: 168 validating compiler_parameters...
2026-09-10 15:35:33,621 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1157 Input node images's input_source not set, it will be set to pyramid by default
2026-09-10 15:35:33,622 file: mapper_conf_parser.py func: mapper_conf_parser line No: 183 validating compiler_parameters finished
2026-09-10 15:35:33,622 file: mapper_conf_parser.py func: mapper_conf_parser line No: 187 validating deprecated parameters...
2026-09-10 15:35:33,623 file: mapper_conf_parser.py func: mapper_conf_parser line No: 193 validating deprecated parameters finished
2026-09-10 15:35:33,623 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 54 Dump config:
2026-09-10 15:35:33,624 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 55 calibration_parameters:
cal_data_dir: ./court_keypoint_calibration_data_rgb_f32_256x256
cal_data_type: float32
calibration_type: max
max_percentile: 0.99995
optimization: set_all_nodes_int16
per_channel: true
compile_mode: latency
debug: false
max_time_per_fc: 1000
optimize_level: O3
input_layout_rt: NCHW
input_layout_train: NCHW
input_name: ''
input_type_rt: nv12
input_type_train: rgb
norm_type: data_scale
scale_value: '0.003921568627451'
layer_out_dump: false
march: bayes-e
onnx_model: yolov11x_court_keypoint_256x256.onnx
output_model_file_prefix: yolov11x_court_keypoint_bayese_256x256_nv12
working_dir: yolov11x_court_keypoint_model_256x256_output
2026-09-10 15:35:33,625 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 60 input 'images' : original model shape: [1, 3, 256, 256]
2026-09-10 15:35:33,628 file: loader.py func: loader line No: 204 *******************************************
2026-09-10 15:35:33,629 file: loader.py func: loader line No: 205 First calibration picture name: 0204_pc1_venc0_train_1_01208.rgb
2026-09-10 15:35:33,629 file: loader.py func: loader line No: 207 First calibration picture md5:
2026-09-10 15:35:33,637 file: loader.py func: loader line No: 211 *******************************************
2026-09-10 15:35:33,639 file: loader.py func: loader line No: 282 created RawImageDirLoader of shape:[1, 3, 256, 256]
2026-09-10 15:35:33,640 file: loader.py func: loader line No: 287 Read raw file: /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/court_keypoint_calibration_data_rgb_f32_256x256/0204_pc1_venc0_train_1_01208.rgb
2026-09-10 15:35:35,500 file: loader.py func: loader line No: 287 Read raw file: /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/court_keypoint_calibration_data_rgb_f32_256x256/0926_pc3_venc0_train_0926_00535.rgb
2026-09-10 15:35:35,509 file: tool_utils.py func: tool_utils line No: 368 num of calibration data: 200
2026-09-10 15:35:35,509 file: tool_utils.py func: tool_utils line No: 369 calibration data shape: (1, 3, 256, 256)
2026-09-10 15:35:35,559 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 519 call build params:
2026-09-10 15:35:38,130 file: model_builder.py func: model_builder line No: 38 End to prepare the onnx model.
2026-09-10 15:35:38,774 file: model_builder.py func: model_builder line No: 265 Saving model to: yolov11x_court_keypoint_bayese_256x256_nv12_original_float_model.onnx.
2026-09-10 15:35:38,775 file: model_builder.py func: model_builder line No: 35 Start to optimize the onnx model.
2026-09-10 15:35:39,973 file: constant_folding.py func: constant_folding line No: 66 Summary info for constant_folding:
2026-09-10 15:35:39,975 file: constant_folding.py func: constant_folding line No: 67 After constant_folding, the number of nodes has changed from 644 to 632.
2026-09-10 15:35:39,975 file: constant_folding.py func: constant_folding line No: 71 After constant_folding, the number of parameters has changed from 58739116 to 58739116.
2026-09-10 15:35:39,976 file: constant_folding.py func: constant_folding line No: 76 Detailed info for constant_folding:
2026-09-10 15:35:39,976 file: constant_folding.py func: constant_folding line No: 88
2026-09-10 15:35:40,813 file: model_builder.py func: model_builder line No: 38 End to optimize the onnx model.
2026-09-10 15:35:41,495 file: model_builder.py func: model_builder line No: 265 Saving model to: yolov11x_court_keypoint_bayese_256x256_nv12_optimized_float_model.onnx.
2026-09-10 15:35:41,496 file: model_builder.py func: model_builder line No: 35 Start to calibrate the model.
2026-09-10 15:35:42,182 file: calibration_data_set.py func: calibration_data_set line No: 111 input name: images, number_of_samples: 200
2026-09-10 15:35:42,182 file: tool_utils.py func: tool_utils line No: 321 The input0 of Node(name:HZ_PREPROCESS_FOR_images, type:HzPreprocess) does not support data type: int16
2026-09-10 15:35:42,184 file: calibration_data_set.py func: calibration_data_set line No: 123 There are 200 samples in the data set.
2026-09-10 15:35:42,185 file: tool_utils.py func: tool_utils line No: 321 The input1 of Node(name:HZ_PREPROCESS_FOR_images, type:HzPreprocess) does not support data type: int16
2026-09-10 15:35:42,186 file: infer_thresholds.py func: infer_thresholds line No: 84 Run calibration model with max-percentile:percentile=0.99995,per_channel method.
2026-09-10 15:35:42,187 file: tool_utils.py func: tool_utils line No: 321 The input2 of Node(name:HZ_PREPROCESS_FOR_images, type:HzPreprocess) does not support data type: int16
2026-09-10 15:35:42,303 file: tool_utils.py func: tool_utils line No: 321 The output of Node(name:/model.14/Resize, type:Resize) does not support data type: int16
2026-09-10 15:35:42,613 file: tool_utils.py func: tool_utils line No: 321 The output of Node(name:/model.11/Resize, type:Resize) does not support data type: int16
2026-09-10 15:35:42,655 file: base.py func: base line No: 138 Calibration using batch 8
2026-09-10 15:35:42,655 file: tool_utils.py func: tool_utils line No: 321 The input0 of Node(name:/model.10/m/m.0/attn/MatMul, type:MatMul) does not support data type: int16
2026-09-10 15:35:42,820 file: tool_utils.py func: tool_utils line No: 321 The input1 of Node(name:/model.10/m/m.0/attn/MatMul, type:MatMul) does not support data type: int16
2026-09-10 15:35:43,234 file: tool_utils.py func: tool_utils line No: 321 The input0 of Node(name:/model.10/m/m.0/attn/MatMul_1, type:MatMul) does not support data type: int16
2026-09-10 15:35:43,236 file: tool_utils.py func: tool_utils line No: 321 The input1 of Node(name:/model.10/m/m.0/attn/MatMul_1, type:MatMul) does not support data type: int16
2026-09-10 15:35:43,237 file: tool_utils.py func: tool_utils line No: 321 The input0 of Node(name:/model.10/m/m.1/attn/MatMul, type:MatMul) does not support data type: int16
2026-09-10 15:35:43,239 file: tool_utils.py func: tool_utils line No: 321 The input1 of Node(name:/model.10/m/m.1/attn/MatMul, type:MatMul) does not support data type: int16
2026-09-10 15:35:43,240 file: tool_utils.py func: tool_utils line No: 321 The input0 of Node(name:/model.10/m/m.1/attn/MatMul_1, type:MatMul) does not support data type: int16
2026-09-10 15:35:43,241 file: tool_utils.py func: tool_utils line No: 321 The input1 of Node(name:/model.10/m/m.1/attn/MatMul_1, type:MatMul) does not support data type: int16
2026-09-10 15:35:43,243 file: tool_utils.py func: tool_utils line No: 321 The input0 of Node(name:/model.11/Resize, type:Resize) does not support data type: int16
2026-09-10 15:35:43,244 file: tool_utils.py func: tool_utils line No: 321 The input1 of Node(name:/model.11/Resize, type:Resize) does not support data type: int16
2026-09-10 15:35:43,253 file: tool_utils.py func: tool_utils line No: 321 The input2 of Node(name:/model.11/Resize, type:Resize) does not support data type: int16
2026-09-10 15:35:43,254 file: tool_utils.py func: tool_utils line No: 321 The input0 of Node(name:/model.14/Resize, type:Resize) does not support data type: int16
2026-09-10 15:35:43,256 file: tool_utils.py func: tool_utils line No: 321 The input1 of Node(name:/model.14/Resize, type:Resize) does not support data type: int16
2026-09-10 15:35:43,257 file: tool_utils.py func: tool_utils line No: 321 The input2 of Node(name:/model.14/Resize, type:Resize) does not support data type: int16
2026-09-10 15:35:43,259 file: tool_utils.py func: tool_utils line No: 321 The output of Node(name:/model.10/m/m.0/attn/Transpose) is int16, then requantized to int8
2026-09-10 15:35:43,260 file: tool_utils.py func: tool_utils line No: 321 The output of Node(name:/model.10/m/m.0/attn/Transpose_2) is int16, then requantized to int8
2026-09-10 15:35:43,262 file: tool_utils.py func: tool_utils line No: 321 The output of Node(name:/model.10/m/m.1/attn/Transpose) is int16, then requantized to int8
2026-09-10 15:35:43,263 file: tool_utils.py func: tool_utils line No: 321 The output of Node(name:/model.10/m/m.1/attn/Transpose_2) is int16, then requantized to int8
2026-09-10 15:35:43,961 file: ort.py func: ort line No: 207 Reset batch_size=1 and execute forward again...
2026-09-10 15:36:22,051 file: base.py func: base line No: 138 Calibration using batch 8
2026-09-10 15:36:24,082 file: ort.py func: ort line No: 207 Reset batch_size=1 and execute forward again...
2026-09-10 15:37:32,805 file: modelwise_search.py func: modelwise_search line No: 62 Perchannel quantization is enabled.
2026-09-10 15:37:35,072 file: model_builder.py func: model_builder line No: 38 End to calibrate the model.
2026-09-10 15:37:35,949 file: model_builder.py func: model_builder line No: 265 Saving model to: yolov11x_court_keypoint_bayese_256x256_nv12_calibrated_model.onnx.
2026-09-10 15:37:35,950 file: model_builder.py func: model_builder line No: 35 Start to quantize the model.
2026-09-10 15:37:45,022 file: constant_folding.py func: constant_folding line No: 66 Summary info for constant_folding:
2026-09-10 15:37:45,024 file: constant_folding.py func: constant_folding line No: 67 After constant_folding, the number of nodes has changed from 542 to 542.
2026-09-10 15:37:45,024 file: constant_folding.py func: constant_folding line No: 71 After constant_folding, the number of parameters has changed from 58786704 to 58786704.
2026-09-10 15:37:45,025 file: constant_folding.py func: constant_folding line No: 76 Detailed info for constant_folding:
2026-09-10 15:37:45,026 file: constant_folding.py func: constant_folding line No: 88
2026-09-10 15:37:45,912 file: model_builder.py func: model_builder line No: 38 End to quantize the model.
2026-09-10 15:37:46,311 file: model_builder.py func: model_builder line No: 265 Saving model to: yolov11x_court_keypoint_bayese_256x256_nv12_quantized_model.onnx.
2026-09-10 15:37:46,311 file: model_builder.py func: model_builder line No: 35 Start to compile the model with march bayes-e.
2026-09-10 15:37:47,881 file: hybrid_build.py func: hybrid_build line No: 111 Compile submodel: torch_jit_subgraph_0
2026-09-10 15:37:48,004 file: hbdk_cc.py func: hbdk_cc line No: 126 hbdk-cc parameters:['--O3', '--core-num', '1', '--fast', '--max-time-per-fc', '1000', '--input-layout', 'NHWC', '--output-layout', 'NHWC', '--input-source', 'pyramid']
2026-09-10 15:37:48,005 file: hbdk_cc.py func: hbdk_cc line No: 127 hbdk-cc command used:hbdk-cc -f hbir -m /tmp/tmpxjb21ytv/torch_jit_subgraph_0.hbir -o /tmp/tmpxjb21ytv/torch_jit_subgraph_0.hbm --march bayes-e --progressbar --O3 --core-num 1 --fast --max-time-per-fc 1000 --input-layout NHWC --output-layout NHWC --input-source pyramid
2026-09-10 15:42:14,190 file: tool_utils.py func: tool_utils line No: 326 consumed time 266.17
2026-09-10 15:42:14,844 file: tool_utils.py func: tool_utils line No: 326 FPS=20.83, latency = 48003.7 us, DDR = 176492480 bytes (see torch_jit_subgraph_0.html)
2026-09-10 15:42:15,616 file: model_builder.py func: model_builder line No: 38 End to compile the model with march bayes-e.
2026-09-10 15:42:20,306 file: print_info_dict.py func: print_info_dict line No: 72 The main quantized node information:
Node ON Subgraph Type Cosine Similarity Threshold DataType
HZ_PREPROCESS_FOR_images BPU id(0) HzSQuantizedPreprocess 0.999995 127.0 int8
/model.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999739 1.05237 int16
variable_1522_Requantize BPU id(0) HzRequantize -- -- int16
/model.0/act/Mul BPU id(0) HzLut2Layer 0.999474 48.4136 int16
/model.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999498 44.2955 int16
/model.1/act/Mul BPU id(0) HzLut2Layer 0.999254 38.1777 int16
/model.2/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999204 26.9646 int16
/model.2/cv1/act/Mul BPU id(0) HzLut2Layer 0.999340 23.0673 int16
/model.2/Split BPU id(0) Split 0.999069 19.1982 int16
/model.2/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999279 19.1982 int16
/model.2/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999393 16.1713 int16
/model.2/m.0/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999290 15.207 int16
/model.2/m.0/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999227 17.3678 int16
/model.2/m.0/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999564 11.4063 int16
/model.2/m.0/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999610 10.3331 int16
/model.2/m.0/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999546 15.207 int16
/model.2/m.0/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999516 16.2936 int16
/model.2/m.0/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.998446 15.0318 int16
/model.2/m.0/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999071 8.85866 int16
/model.2/m.0/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999250 13.2153 int16
/model.2/m.0/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999507 16.2936 int16
/model.2/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999235 19.1982 int16
/model.2/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999258 20.0882 int16
/model.2/m.0/Concat BPU id(0) Concat 0.999429 20.2858 int16
/model.2/m.0/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999203 20.2858 int16
/model.2/m.0/cv3/act/Mul BPU id(0) HzLut2Layer 0.999045 14.7949 int16
/model.2/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999505 13.8168 int16
/model.2/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999187 8.53702 int16
/model.2/m.1/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999409 8.52826 int16
/model.2/m.1/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999075 13.2928 int16
/model.2/m.1/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999392 9.29112 int16
/model.2/m.1/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999396 9.15062 int16
/model.2/m.1/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999438 8.52826 int16
/model.2/m.1/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999700 9.25453 int16
/model.2/m.1/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999353 7.52129 int16
/model.2/m.1/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999605 5.747 int16
/model.2/m.1/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999639 9.07597 int16
/model.2/m.1/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999683 9.25453 int16
/model.2/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999762 13.8168 int16
/model.2/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999803 8.77759 int16
/model.2/m.1/Concat BPU id(0) Concat 0.999683 11.4941 int16
/model.2/m.1/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999094 11.4941 int16
/model.2/m.1/cv3/act/Mul BPU id(0) HzLut2Layer 0.999056 13.6376 int16
/model.2/Split_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.2/Split_output_1_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
.../m.0/cv3/act/Mul_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.2/Concat BPU id(0) Concat 0.999110 19.1982 int16
/model.2/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999607 17.1546 int16
/model.2/cv2/act/Mul BPU id(0) HzLut2Layer 0.999169 10.39 int16
/model.3/conv/Conv BPU id(0) HzSQuantizedConv 0.999767 8.86029 int16
/model.3/act/Mul BPU id(0) HzLut2Layer 0.999576 8.94642 int16
/model.4/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999658 8.84059 int16
/model.4/cv1/act/Mul BPU id(0) HzLut2Layer 0.999527 11.0815 int16
/model.4/Split BPU id(0) Split 0.999433 10.9019 int16
/model.4/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999759 10.9019 int16
/model.4/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999682 9.28539 int16
/model.4/m.0/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999832 9.12165 int16
/model.4/m.0/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999461 9.70152 int16
/model.4/m.0/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999634 7.19346 int16
/model.4/m.0/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999549 9.37117 int16
/model.4/m.0/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999637 9.12165 int16
/model.4/m.0/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999882 9.5662 int16
/model.4/m.0/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999648 7.79349 int16
/model.4/m.0/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999672 6.7126 int16
/model.4/m.0/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999650 10.7333 int16
/model.4/m.0/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999691 9.5662 int16
/model.4/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999850 10.9019 int16
/model.4/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999723 8.74658 int16
/model.4/m.0/Concat BPU id(0) Concat 0.999691 11.4041 int16
/model.4/m.0/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999697 11.4041 int16
/model.4/m.0/cv3/act/Mul BPU id(0) HzLut2Layer 0.999526 8.90029 int16
/model.4/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999856 8.6903 int16
/model.4/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999803 8.40681 int16
/model.4/m.1/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999772 8.40493 int16
/model.4/m.1/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999423 7.14333 int16
/model.4/m.1/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999690 5.92905 int16
/model.4/m.1/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999598 7.1 int16
/model.4/m.1/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999722 8.40493 int16
/model.4/m.1/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999827 8.79616 int16
/model.4/m.1/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999268 6.40964 int16
/model.4/m.1/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999620 5.697 int16
/model.4/m.1/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999697 10.1554 int16
/model.4/m.1/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999752 8.79616 int16
/model.4/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999922 8.6903 int16
/model.4/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999949 5.06982 int16
/model.4/m.1/Concat BPU id(0) Concat 0.999754 10.4581 int16
/model.4/m.1/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999662 10.4581 int16
/model.4/m.1/cv3/act/Mul BPU id(0) HzLut2Layer 0.999596 8.12596 int16
/model.4/Split_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.4/Split_output_1_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.4/Concat BPU id(0) Concat 0.999478 10.9019 int16
/model.4/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999758 9.844 int16
/model.4/cv2/act/Mul BPU id(0) HzLut2Layer 0.999529 7.55435 int16
/model.5/conv/Conv BPU id(0) HzSQuantizedConv 0.999824 6.89459 int16
/model.5/act/Mul BPU id(0) HzLut2Layer 0.999627 5.67276 int16
/model.6/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999752 5.55827 int16
/model.6/cv1/act/Mul BPU id(0) HzLut2Layer 0.999674 7.45034 int16
/model.6/Split BPU id(0) Split 0.999737 7.42279 int16
/model.6/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999675 7.42279 int16
/model.6/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999338 6.77121 int16
/model.6/m.0/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999567 6.57526 int16
/model.6/m.0/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.998929 6.10407 int16
/model.6/m.0/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999292 4.7094 int16
/model.6/m.0/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.998650 8.507 int16
/model.6/m.0/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.998844 6.57526 int16
/model.6/m.0/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999227 11.0894 int16
/model.6/m.0/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.998663 11.3527 int16
/model.6/m.0/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.998594 11.2017 int16
/model.6/m.0/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.998297 23.2091 int16
/model.6/m.0/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.998509 11.0894 int16
/model.6/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999534 7.42279 int16
/model.6/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999247 8.48508 int16
/model.6/m.0/Concat BPU id(0) Concat 0.998526 27.5865 int16
/model.6/m.0/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.998677 27.5865 int16
/model.6/m.0/cv3/act/Mul BPU id(0) HzLut2Layer 0.998290 16.3494 int16
/model.6/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.998895 16.3494 int16
/model.6/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.997788 12.3725 int16
/model.6/m.1/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.998800 10.3425 int16
/model.6/m.1/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999139 10.1459 int16
/model.6/m.1/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999111 8.7275 int16
/model.6/m.1/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999297 10.0626 int16
/model.6/m.1/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.998658 10.3425 int16
/model.6/m.1/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999128 12.6929 int16
/model.6/m.1/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999077 7.50352 int16
/model.6/m.1/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999105 7.11137 int16
/model.6/m.1/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999345 8.68859 int16
/model.6/m.1/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999254 12.6929 int16
/model.6/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.998957 16.3494 int16
/model.6/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.997755 11.1791 int16
/model.6/m.1/Concat BPU id(0) Concat 0.999200 13.2881 int16
/model.6/m.1/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999192 13.2881 int16
/model.6/m.1/cv3/act/Mul BPU id(0) HzLut2Layer 0.999189 9.01841 int16
/model.6/Split_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.6/Split_output_1_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.6/Concat BPU id(0) Concat 0.998878 7.42279 int16
/model.6/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.998941 13.6694 int16
/model.6/cv2/act/Mul BPU id(0) HzLut2Layer 0.998545 16.0817 int16
/model.7/conv/Conv BPU id(0) HzSQuantizedConv 0.998758 15.884 int16
/model.7/act/Mul BPU id(0) HzLut2Layer 0.998544 17.8982 int16
/model.8/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.998642 17.8982 int16
/model.8/cv1/act/Mul BPU id(0) HzLut2Layer 0.998520 19.4578 int16
/model.8/Split BPU id(0) Split 0.998905 19.4578 int16
/model.8/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.998442 19.4578 int16
/model.8/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.997961 17.89 int16
/model.8/m.0/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.998155 17.89 int16
/model.8/m.0/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.997426 16.0555 int16
/model.8/m.0/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.997175 14.5535 int16
/model.8/m.0/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.995432 16.4966 int16
/model.8/m.0/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.997018 17.89 int16
/model.8/m.0/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.997788 25.9671 int16
/model.8/m.0/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.993834 13.6662 int16
/model.8/m.0/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.996380 13.6334 int16
/model.8/m.0/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.995681 11.9005 int16
/model.8/m.0/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.997048 25.9671 int16
/model.8/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.997912 19.4578 int16
/model.8/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.996523 15.056 int16
/model.8/m.0/Concat BPU id(0) Concat 0.996983 25.7703 int16
/model.8/m.0/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.997154 25.7703 int16
/model.8/m.0/cv3/act/Mul BPU id(0) HzLut2Layer 0.996485 17.5716 int16
/model.8/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.996262 17.4673 int16
/model.8/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.992715 16.9977 int16
/model.8/m.1/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.998465 16.9977 int16
/model.8/m.1/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.997440 8.20628 int16
/model.8/m.1/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999650 6.37658 int16
/model.8/m.1/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999612 3.67352 int16
/model.8/m.1/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.997400 16.9977 int16
/model.8/m.1/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.997760 17.932 int16
/model.8/m.1/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.997352 16.1021 int16
/model.8/m.1/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.996933 16.102 int16
/model.8/m.1/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.996908 19.3761 int16
/model.8/m.1/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.997298 17.932 int16
/model.8/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.998030 17.4673 int16
/model.8/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999166 14.0887 int16
/model.8/m.1/Concat BPU id(0) Concat 0.997444 22.1448 int16
/model.8/m.1/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.997665 22.1448 int16
/model.8/m.1/cv3/act/Mul BPU id(0) HzLut2Layer 0.997243 11.5691 int16
/model.8/Split_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.8/Split_output_1_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.8/Concat BPU id(0) Concat 0.997759 19.4578 int16
/model.8/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999042 18.2965 int16
/model.8/cv2/act/Mul BPU id(0) HzLut2Layer 0.999033 15.8207 int16
/model.9/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.998863 15.7444 int16
/model.9/m/MaxPool BPU id(0) HzQuantizedMaxPool 0.999260 13.7874 int16
/model.9/m_1/MaxPool BPU id(0) HzQuantizedMaxPool 0.999396 13.7874 int16
/model.9/m_2/MaxPool BPU id(0) HzQuantizedMaxPool 0.999548 13.7874 int16
/model.9/Concat BPU id(0) Concat 0.999213 13.7874 int16
/model.9/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999771 13.7874 int16
/model.9/cv2/act/Mul BPU id(0) HzLut2Layer 0.999780 6.85189 int16
/model.10/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999823 6.82077 int16
/model.10/cv1/act/Mul BPU id(0) HzLut2Layer 0.999801 8.60449 int16
/model.10/Split BPU id(0) Split 0.999868 8.55743 int16
/model.10/m/m.0/attn/qkv/conv/Conv BPU id(0) HzSQuantizedConv 0.999752 8.55743 int16
/model.10/m/m.0/attn/Reshape BPU id(0) Reshape 0.999752 9.68014 int16
/model.10/m/m.0/attn/Split BPU id(0) Split 0.999848 9.68014 int16
...0/attn/Transpose_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.10/m/m.0/attn/Split_output_1_Requantize BPU id(0) HzRequantize -- -- int16
/model.10/m/m.0/attn/MatMul BPU id(0) HzSQuantizedMatmul 0.999688 9.68014 int8
/model.10/m/m.0/attn/Mul BPU id(0) HzSQuantizedConv 0.999688 358.761 int16
/model.10/m/m.0/attn/ReduceMax BPU id(0) HzQuantizedReduceMax 0.999725 63.4205 int16
/model.10/m/m.0/attn/Sub BPU id(0) HzSElementwiseSub 0.996009 63.4205 int16
/model.10/m/m.0/attn/Exp BPU id(0) HzLut2Layer 0.963996 48.7613 int16
/model.10/m/m.0/attn/ReduceSum BPU id(0) HzSQuantizedReduceSum 0.995237 1.0 int16
/model.10/m/m.0/attn/Div_reciprocal BPU id(0) HzLut2Layer 0.963504 31.0544 int16
/model.10/m/m.0/attn/Div_mul BPU id(0) HzSElementwiseMul 0.846076 1.0 int16
/model.10/m/m.0/attn/Transpose_2 BPU id(0) Transpose 0.846076 0.997208 int8
/model.10/m/m.0/attn/Split_output_2_Requantize BPU id(0) HzRequantize -- -- int16
/model.10/m/m.0/attn/MatMul_1 BPU id(0) HzSQuantizedMatmul 0.999770 9.68014 int8
/model.10/m/m.0/attn/Reshape_1 BPU id(0) Reshape 0.999770 10.1452 int16
/model.10/m/m.0/attn/Reshape_2 BPU id(0) Reshape 0.999794 9.68014 int16
/model.10/m/m.0/attn/pe/conv/Conv BPU id(0) HzSQuantizedConv 0.999707 9.68014 int16
variable_1527_Requantize BPU id(0) HzRequantize -- -- int16
/model.10/m/m.0/attn/Add BPU id(0) HzSElementwiseAdd 0.999271 10.1452 int16
/model.10/m/m.0/attn/proj/conv/Conv BPU id(0) HzSQuantizedConv 0.999553 9.95981 int16
/model.10/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999764 8.55743 int16
/model.10/m/m.0/ffn/ffn.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999728 14.0057 int16
/model.10/m/m.0/ffn/ffn.0/act/Mul BPU id(0) HzLut2Layer 0.999818 7.76713 int16
/model.10/m/m.0/ffn/ffn.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999832 7.71614 int16
/model.10/m/m.0/Add_1 BPU id(0) HzSElementwiseAdd 0.999804 14.0057 int16
/model.10/m/m.1/attn/qkv/conv/Conv BPU id(0) HzSQuantizedConv 0.999864 18.59 int16
/model.10/m/m.1/attn/Reshape BPU id(0) Reshape 0.999864 11.453 int16
/model.10/m/m.1/attn/Split BPU id(0) Split 0.999890 11.453 int16
...1/attn/Transpose_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.10/m/m.1/attn/Split_output_1_Requantize BPU id(0) HzRequantize -- -- int16
/model.10/m/m.1/attn/MatMul BPU id(0) HzSQuantizedMatmul 0.999524 11.453 int8
/model.10/m/m.1/attn/Mul BPU id(0) HzSQuantizedConv 0.999524 404.861 int16
/model.10/m/m.1/attn/ReduceMax BPU id(0) HzQuantizedReduceMax 0.999812 71.57 int16
/model.10/m/m.1/attn/Sub BPU id(0) HzSElementwiseSub 0.999555 71.57 int16
/model.10/m/m.1/attn/Exp BPU id(0) HzLut2Layer 0.987206 87.1239 int16
/model.10/m/m.1/attn/ReduceSum BPU id(0) HzSQuantizedReduceSum 0.996519 1.0 int16
/model.10/m/m.1/attn/Div_reciprocal BPU id(0) HzLut2Layer 0.998149 38.0593 int16
/model.10/m/m.1/attn/Div_mul BPU id(0) HzSElementwiseMul 0.992576 1.0 int16
/model.10/m/m.1/attn/Transpose_2 BPU id(0) Transpose 0.992576 0.990095 int8
/model.10/m/m.1/attn/Split_output_2_Requantize BPU id(0) HzRequantize -- -- int16
/model.10/m/m.1/attn/MatMul_1 BPU id(0) HzSQuantizedMatmul 0.999898 11.453 int8
/model.10/m/m.1/attn/Reshape_1 BPU id(0) Reshape 0.999898 9.2799 int16
/model.10/m/m.1/attn/Reshape_2 BPU id(0) Reshape 0.999884 11.453 int16
/model.10/m/m.1/attn/pe/conv/Conv BPU id(0) HzSQuantizedConv 0.999783 11.453 int16
variable_1528_Requantize BPU id(0) HzRequantize -- -- int16
/model.10/m/m.1/attn/Add BPU id(0) HzSElementwiseAdd 0.999754 9.2799 int16
/model.10/m/m.1/attn/proj/conv/Conv BPU id(0) HzSQuantizedConv 0.999817 17.4966 int16
/model.10/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999848 18.59 int16
/model.10/m/m.1/ffn/ffn.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999962 23.566 int16
/model.10/m/m.1/ffn/ffn.0/act/Mul BPU id(0) HzLut2Layer 0.999955 8.663 int16
/model.10/m/m.1/ffn/ffn.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999927 8.6615 int16
/model.10/m/m.1/Add_1 BPU id(0) HzSElementwiseAdd 0.999831 23.566 int16
/model.10/Split_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.10/Concat BPU id(0) Concat 0.999832 8.55743 int16
/model.10/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999846 23.9212 int16
/model.10/cv2/act/Mul BPU id(0) HzLut2Layer 0.999806 9.4852 int16
...l.10/cv2/act/Mul_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.11/Resize BPU id(0) HzQuantizedResizeUpsample 0.999806 8.52714 int8
/model.11/Resize_output_0_Requantize BPU id(0) HzRequantize -- -- int8
/model.11/Resize_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
...el.6/cv2/act/Mul_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.12/Concat BPU id(0) Concat 0.999155 8.52714 int16
/model.13/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999614 14.0865 int16
/model.13/cv1/act/Mul BPU id(0) HzLut2Layer 0.999574 11.8284 int16
/model.13/Split BPU id(0) Split 0.999686 10.7871 int16
/model.13/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999435 10.7871 int16
/model.13/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.998791 9.99734 int16
/model.13/m.0/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999459 7.13606 int16
/model.13/m.0/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.998913 7.7287 int16
/model.13/m.0/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999383 6.37761 int16
/model.13/m.0/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999122 5.69729 int16
/model.13/m.0/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999065 7.13606 int16
/model.13/m.0/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999564 7.82954 int16
/model.13/m.0/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999134 6.19624 int16
/model.13/m.0/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999150 6.18365 int16
/model.13/m.0/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999005 7.86073 int16
/model.13/m.0/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999033 7.82954 int16
/model.13/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999336 10.7871 int16
/model.13/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999095 9.01156 int16
/model.13/m.0/Concat BPU id(0) Concat 0.999043 10.2022 int16
/model.13/m.0/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999433 10.2022 int16
/model.13/m.0/cv3/act/Mul BPU id(0) HzLut2Layer 0.999418 6.02426 int16
/model.13/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999859 5.22531 int16
/model.13/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999799 4.75832 int16
/model.13/m.1/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999792 4.17385 int16
/model.13/m.1/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999666 6.67485 int16
/model.13/m.1/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999784 6.64566 int16
/model.13/m.1/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999768 4.85403 int16
/model.13/m.1/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999772 4.17385 int16
/model.13/m.1/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999825 6.31014 int16
/model.13/m.1/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999724 5.4688 int16
/model.13/m.1/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999859 5.17511 int16
/model.13/m.1/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999882 6.6218 int16
/model.13/m.1/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999870 6.31014 int16
/model.13/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999953 5.22531 int16
/model.13/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999965 3.02528 int16
/model.13/m.1/Concat BPU id(0) Concat 0.999872 8.52635 int16
/model.13/m.1/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999882 8.52635 int16
/model.13/m.1/cv3/act/Mul BPU id(0) HzLut2Layer 0.999852 4.58016 int16
/model.13/Split_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.13/Split_output_1_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.13/Concat BPU id(0) Concat 0.999591 10.7871 int16
/model.13/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999869 9.33382 int16
/model.13/cv2/act/Mul BPU id(0) HzLut2Layer 0.999674 7.77641 int16
...l.13/cv2/act/Mul_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.14/Resize BPU id(0) HzQuantizedResizeUpsample 0.999677 7.46435 int8
/model.14/Resize_output_0_Requantize BPU id(0) HzRequantize -- -- int8
/model.14/Resize_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
...el.4/cv2/act/Mul_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.15/Concat BPU id(0) Concat 0.999602 7.46435 int16
/model.16/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999823 7.45463 int16
/model.16/cv1/act/Mul BPU id(0) HzLut2Layer 0.999699 6.55645 int16
/model.16/Split BPU id(0) Split 0.999672 6.33352 int16
/model.16/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999953 6.33352 int16
/model.16/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999970 3.82579 int16
/model.16/m.0/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999958 3.01099 int16
/model.16/m.0/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999877 5.37007 int16
/model.16/m.0/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999905 3.39742 int16
/model.16/m.0/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999869 5.4705 int16
/model.16/m.0/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999953 3.01099 int16
/model.16/m.0/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999978 4.5547 int16
/model.16/m.0/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999912 4.96691 int16
/model.16/m.0/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999939 4.33829 int16
/model.16/m.0/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999941 7.55061 int16
/model.16/m.0/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999947 4.5547 int16
/model.16/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999901 6.33352 int16
variable_1526_Requantize BPU id(0) HzRequantize -- -- int16
/model.16/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999867 4.92318 int16
/model.16/m.0/Concat BPU id(0) Concat 0.999943 10.4548 int16
/model.16/m.0/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999949 10.4548 int16
/model.16/m.0/cv3/act/Mul BPU id(0) HzLut2Layer 0.999886 7.24614 int16
/model.16/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999989 7.21068 int16
/model.16/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999982 3.51512 int16
/model.16/m.1/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999980 2.59117 int16
/model.16/m.1/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999955 5.74755 int16
/model.16/m.1/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999972 5.72927 int16
/model.16/m.1/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999961 6.40175 int16
/model.16/m.1/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999967 2.59117 int16
/model.16/m.1/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999976 6.50637 int16
/model.16/m.1/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999954 6.03436 int16
/model.16/m.1/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999948 5.99398 int16
/model.16/m.1/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999941 10.4137 int16
/model.16/m.1/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999945 6.50637 int16
/model.16/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999974 7.21068 int16
/model.16/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999975 3.60241 int16
/model.16/m.1/Concat BPU id(0) Concat 0.999947 11.6505 int16
/model.16/m.1/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999942 11.6505 int16
variable_1529_Requantize BPU id(0) HzRequantize -- -- int16
/model.16/m.1/cv3/act/Mul BPU id(0) HzLut2Layer 0.999923 7.60436 int16
/model.16/Split_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.16/Split_output_1_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.16/Concat BPU id(0) Concat 0.999817 6.33352 int16
/model.16/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999933 7.02302 int16
/model.16/cv2/act/Mul BPU id(0) HzLut2Layer 0.999856 6.67985 int16
/model.17/conv/Conv BPU id(0) HzSQuantizedConv 0.999867 6.31286 int16
/model.17/act/Mul BPU id(0) HzLut2Layer 0.999877 7.25431 int16
/model.18/Concat BPU id(0) Concat 0.999794 7.46435 int16
/model.19/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999885 7.46435 int16
/model.19/cv1/act/Mul BPU id(0) HzLut2Layer 0.999860 8.15456 int16
/model.19/Split BPU id(0) Split 0.999877 8.15222 int16
/model.19/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999918 8.15222 int16
/model.19/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999842 6.67443 int16
/model.19/m.0/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999848 6.66602 int16
/model.19/m.0/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999684 10.599 int16
/model.19/m.0/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999842 10.5979 int16
/model.19/m.0/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999808 9.14837 int16
/model.19/m.0/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999847 6.66602 int16
/model.19/m.0/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999857 10.0042 int16
/model.19/m.0/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999747 11.1573 int16
/model.19/m.0/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999795 11.1309 int16
/model.19/m.0/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999733 12.5554 int16
/model.19/m.0/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999784 10.0042 int16
/model.19/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999888 8.15222 int16
/model.19/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999900 7.05805 int16
/model.19/m.0/Concat BPU id(0) Concat 0.999817 13.875 int16
/model.19/m.0/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999890 13.875 int16
/model.19/m.0/cv3/act/Mul BPU id(0) HzLut2Layer 0.999823 8.52241 int16
/model.19/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999867 7.9172 int16
/model.19/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999769 8.68838 int16
/model.19/m.1/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999819 8.56516 int16
/model.19/m.1/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999661 14.8224 int16
/model.19/m.1/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999743 12.7852 int16
/model.19/m.1/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999662 15.0353 int16
/model.19/m.1/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999712 8.56516 int16
/model.19/m.1/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999689 14.8895 int16
/model.19/m.1/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999354 13.654 int16
/model.19/m.1/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999548 13.5982 int16
/model.19/m.1/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999482 18.0228 int16
/model.19/m.1/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999593 14.8895 int16
/model.19/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999854 7.9172 int16
/model.19/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999765 8.68635 int16
/model.19/m.1/Concat BPU id(0) Concat 0.999610 19.2204 int16
/model.19/m.1/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999632 19.2204 int16
/model.19/m.1/cv3/act/Mul BPU id(0) HzLut2Layer 0.996421 13.2477 int16
/model.19/Split_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.19/Split_output_1_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.19/Concat BPU id(0) Concat 0.999342 8.15222 int16
/model.19/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999619 9.36354 int16
/model.19/cv2/act/Mul BPU id(0) HzLut2Layer 0.999352 9.52754 int16
/model.20/conv/Conv BPU id(0) HzSQuantizedConv 0.999806 9.46953 int16
/model.20/act/Mul BPU id(0) HzLut2Layer 0.999785 5.63104 int16
/model.21/Concat BPU id(0) Concat 0.999752 8.52714 int16
/model.22/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999866 8.52714 int16
/model.22/cv1/act/Mul BPU id(0) HzLut2Layer 0.999818 7.04198 int16
/model.22/Split BPU id(0) Split 0.999809 6.73724 int16
/model.22/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999840 6.73724 int16
/model.22/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999785 4.42096 int16
/model.22/m.0/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999763 4.11213 int16
/model.22/m.0/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999763 4.53154 int16
/model.22/m.0/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999783 3.58859 int16
/model.22/m.0/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999764 4.7389 int16
/model.22/m.0/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999795 4.11213 int16
/model.22/m.0/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999886 6.14411 int16
/model.22/m.0/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999831 5.09059 int16
/model.22/m.0/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999819 4.19109 int16
/model.22/m.0/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999764 5.10559 int16
/model.22/m.0/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999822 6.14411 int16
/model.22/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999863 6.73724 int16
/model.22/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999808 5.13094 int16
/model.22/m.0/Concat BPU id(0) Concat 0.999820 8.18926 int16
/model.22/m.0/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999866 8.18926 int16
/model.22/m.0/cv3/act/Mul BPU id(0) HzLut2Layer 0.999836 4.66851 int16
/model.22/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999938 4.41038 int16
/model.22/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999935 3.10132 int16
/model.22/m.1/m/m.0/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999918 2.95076 int16
/model.22/m.1/m/m.0/cv1/act/Mul BPU id(0) HzLut2Layer 0.999919 3.08274 int16
/model.22/m.1/m/m.0/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999967 2.21944 int16
/model.22/m.1/m/m.0/cv2/act/Mul BPU id(0) HzLut2Layer 0.999973 2.35344 int16
/model.22/m.1/m/m.0/Add BPU id(0) HzSElementwiseAdd 0.999965 2.95076 int16
/model.22/m.1/m/m.1/cv1/conv/Conv BPU id(0) HzSQuantizedConv 0.999983 3.91514 int16
/model.22/m.1/m/m.1/cv1/act/Mul BPU id(0) HzLut2Layer 0.999980 2.80304 int16
/model.22/m.1/m/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999996 1.99667 int16
/model.22/m.1/m/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999997 2.12833 int16
/model.22/m.1/m/m.1/Add BPU id(0) HzSElementwiseAdd 0.999975 3.91514 int16
/model.22/m.1/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999932 4.41038 int16
/model.22/m.1/cv2/act/Mul BPU id(0) HzLut2Layer 0.999944 3.37642 int16
/model.22/m.1/Concat BPU id(0) Concat 0.999969 4.96046 int16
/model.22/m.1/cv3/conv/Conv BPU id(0) HzSQuantizedConv 0.999975 4.96046 int16
/model.22/m.1/cv3/act/Mul BPU id(0) HzLut2Layer 0.999968 2.40712 int16
/model.22/Split_output_0_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.22/Split_output_1_calibrated_Requantize BPU id(0) HzRequantize -- -- int16
/model.22/Concat BPU id(0) Concat 0.999794 6.73724 int16
/model.22/cv2/conv/Conv BPU id(0) HzSQuantizedConv 0.999921 5.97873 int16
/model.22/cv2/act/Mul BPU id(0) HzLut2Layer 0.999893 4.76637 int16
/model.23/cv2.0/cv2.0.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999906 6.31286 int16
/model.23/cv2.0/cv2.0.0/act/Mul BPU id(0) HzLut2Layer 0.999892 6.08668 int16
/model.23/cv2.0/cv2.0.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999875 6.07288 int16
/model.23/cv2.0/cv2.0.1/act/Mul BPU id(0) HzLut2Layer 0.999896 6.47828 int16
/model.23/cv2.0/cv2.0.2/Conv BPU id(0) HzSQuantizedConv 0.999887 6.16586 int16
/model.23/cv3.0/cv3.0.0/cv3.0.0.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999864 6.31286 int16
variable_1525_Requantize BPU id(0) HzRequantize -- -- int16
/model.23/cv3.0/cv3.0.0/cv3.0.0.0/act/Mul BPU id(0) HzLut2Layer 0.999785 11.4127 int16
/model.23/cv3.0/cv3.0.0/cv3.0.0.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999753 10.2698 int16
variable_1524_Requantize BPU id(0) HzRequantize -- -- int16
/model.23/cv3.0/cv3.0.0/cv3.0.0.1/act/Mul BPU id(0) HzLut2Layer 0.999649 10.5992 int16
/model.23/cv3.0/cv3.0.1/cv3.0.1.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999660 8.09776 int16
variable_1523_Requantize BPU id(0) HzRequantize -- -- int16
/model.23/cv3.0/cv3.0.1/cv3.0.1.0/act/Mul BPU id(0) HzLut2Layer 0.999572 13.4849 int16
/model.23/cv3.0/cv3.0.1/cv3.0.1.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999636 12.2454 int16
variable_1521_Requantize BPU id(0) HzRequantize -- -- int16
/model.23/cv3.0/cv3.0.1/cv3.0.1.1/act/Mul BPU id(0) HzLut2Layer 0.999675 12.4852 int16
/model.23/cv3.0/cv3.0.2/Conv BPU id(0) HzSQuantizedConv 0.999888 10.7147 int16
/model.23/cv2.1/cv2.1.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999781 9.46953 int16
/model.23/cv2.1/cv2.1.0/act/Mul BPU id(0) HzLut2Layer 0.999719 16.2693 int16
/model.23/cv2.1/cv2.1.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999741 16.2693 int16
/model.23/cv2.1/cv2.1.1/act/Mul BPU id(0) HzLut2Layer 0.999750 21.0226 int16
/model.23/cv2.1/cv2.1.2/Conv BPU id(0) HzSQuantizedConv 0.999638 18.917 int16
/model.23/cv3.1/cv3.1.0/cv3.1.0.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999426 9.46953 int16
variable_1518_Requantize BPU id(0) HzRequantize -- -- int16
/model.23/cv3.1/cv3.1.0/cv3.1.0.0/act/Mul BPU id(0) HzLut2Layer 0.998906 14.4263 int16
/model.23/cv3.1/cv3.1.0/cv3.1.0.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999214 14.0629 int16
/model.23/cv3.1/cv3.1.0/cv3.1.0.1/act/Mul BPU id(0) HzLut2Layer 0.998382 12.3661 int16
/model.23/cv3.1/cv3.1.1/cv3.1.1.0/conv/Conv BPU id(0) HzSQuantizedConv 0.998658 10.4945 int16
variable_1517_Requantize BPU id(0) HzRequantize -- -- int16
/model.23/cv3.1/cv3.1.1/cv3.1.1.0/act/Mul BPU id(0) HzLut2Layer 0.999097 16.7999 int16
/model.23/cv3.1/cv3.1.1/cv3.1.1.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999127 16.7974 int16
variable_1516_Requantize BPU id(0) HzRequantize -- -- int16
/model.23/cv3.1/cv3.1.1/cv3.1.1.1/act/Mul BPU id(0) HzLut2Layer 0.998978 12.1447 int16
/model.23/cv3.1/cv3.1.2/Conv BPU id(0) HzSQuantizedConv 0.999655 10.7644 int16
/model.23/cv2.2/cv2.2.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999981 4.1543 int16
/model.23/cv2.2/cv2.2.0/act/Mul BPU id(0) HzLut2Layer 0.999986 3.94107 int16
/model.23/cv2.2/cv2.2.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999991 3.86597 int16
/model.23/cv2.2/cv2.2.1/act/Mul BPU id(0) HzLut2Layer 0.999993 9.29677 int16
/model.23/cv2.2/cv2.2.2/Conv BPU id(0) HzSQuantizedConv 0.999994 9.29592 int16
/model.23/cv3.2/cv3.2.0/cv3.2.0.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999894 4.1543 int16
variable_1519_Requantize BPU id(0) HzRequantize -- -- int16
/model.23/cv3.2/cv3.2.0/cv3.2.0.0/act/Mul BPU id(0) HzLut2Layer 0.999871 5.73797 int16
/model.23/cv3.2/cv3.2.0/cv3.2.0.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999976 5.52132 int16
/model.23/cv3.2/cv3.2.0/cv3.2.0.1/act/Mul BPU id(0) HzLut2Layer 0.999970 4.15109 int16
/model.23/cv3.2/cv3.2.1/cv3.2.1.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999956 3.51646 int16
variable_1520_Requantize BPU id(0) HzRequantize -- -- int16
/model.23/cv3.2/cv3.2.1/cv3.2.1.0/act/Mul BPU id(0) HzLut2Layer 0.999942 4.95618 int16
/model.23/cv3.2/cv3.2.1/cv3.2.1.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999990 4.87833 int16
/model.23/cv3.2/cv3.2.1/cv3.2.1.1/act/Mul BPU id(0) HzLut2Layer 0.999995 2.40979 int16
/model.23/cv3.2/cv3.2.2/Conv BPU id(0) HzSQuantizedConv 1.000000 2.21115 int16
/model.23/cv4.0/cv4.0.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999747 6.31286 int16
/model.23/cv4.0/cv4.0.0/act/Mul BPU id(0) HzLut2Layer 0.999775 7.39706 int16
/model.23/cv4.0/cv4.0.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999792 6.41294 int16
/model.23/cv4.0/cv4.0.1/act/Mul BPU id(0) HzLut2Layer 0.999818 6.24632 int16
/model.23/cv4.0/cv4.0.2/Conv BPU id(0) HzSQuantizedConv 0.999709 5.32095 int16
/model.23/cv4.1/cv4.1.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999753 9.46953 int16
/model.23/cv4.1/cv4.1.0/act/Mul BPU id(0) HzLut2Layer 0.999716 12.2983 int16
/model.23/cv4.1/cv4.1.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999542 12.2983 int16
/model.23/cv4.1/cv4.1.1/act/Mul BPU id(0) HzLut2Layer 0.999684 12.4688 int16
/model.23/cv4.1/cv4.1.2/Conv BPU id(0) HzSQuantizedConv 0.999681 4.65696 int16
/model.23/cv4.2/cv4.2.0/conv/Conv BPU id(0) HzSQuantizedConv 0.999985 4.1543 int16
/model.23/cv4.2/cv4.2.0/act/Mul BPU id(0) HzLut2Layer 0.999983 3.70609 int16
/model.23/cv4.2/cv4.2.1/conv/Conv BPU id(0) HzSQuantizedConv 0.999988 3.6172 int16
/model.23/cv4.2/cv4.2.1/act/Mul BPU id(0) HzLut2Layer 0.999990 5.0963 int16
/model.23/cv4.2/cv4.2.2/Conv BPU id(0) HzSQuantizedConv 0.999993 5.0653 int16
2026-09-10 15:42:20,335 file: print_info_dict.py func: print_info_dict line No: 72 The quantized model output:
Output Cosine Similarity L1 Distance L2 Distance Chebyshev Distance
output0 0.999887 0.050813 0.000282 0.643241
993 0.999888 0.377364 0.016036 2.547115
1001 0.999638 0.109006 0.002876 36.145599
1015 0.999655 0.367411 0.051000 6.770432
1023 0.999994 0.028827 0.000536 0.126464
1037 1.000000 0.015130 0.002092 0.031256
1045 0.999709 0.062489 0.001190 1.533571
1053 0.999681 0.047652 0.001811 0.615585
1061 0.999993 0.005040 0.000304 0.036991
2026-09-10 15:42:20,355 file: model_builder.py func: model_builder line No: 38 End to Horizon NN Model Convert.
2026-09-10 15:42:20,512 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 601 start convert to *.bin file....
2026-09-10 15:42:20,529 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4326 ONNX model output num : 9
2026-09-10 15:42:20,538 file: layout_util.py func: layout_util line No: 15 set_featuremap_layout start
2026-09-10 15:42:20,539 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4060 model_deps_info: {'hb_mapper_version': '1.24.3', 'hbdk_version': '3.49.15', 'hbdk_runtime_version': ' 3.15.55.0', 'horizon_nn_version': '1.1.0', 'onnx_model': '/open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/yolov11x_court_keypoint_256x256.onnx', 'march': 'bayes-e', 'layer_out_dump': False, 'log_level': 'DEBUG', 'working_dir': '/open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/yolov11x_court_keypoint_model_256x256_output', 'model_prefix': 'yolov11x_court_keypoint_bayese_256x256_nv12', 'input_names': ['images'], 'input_type_rt': ['nv12'], 'input_space_and_range': ['regular'], 'input_type_train': ['rgb'], 'input_layout_rt': ['NCHW'], 'input_layout_train': ['NCHW'], 'norm_type': ['data_scale'], 'scale_value': ['0.003921568627451,'], 'mean_value': [''], 'input_shape': ['1x3x256x256'], 'input_batch': [], 'cal_dir': ['/open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/court_keypoint_calibration_data_rgb_f32_256x256'], 'cal_data_type': ['float32'], 'preprocess_on': False, 'calibration_type': 'max', 'per_channel': 'True', 'max_percentile': 0.99995, 'optimization': ['set_all_nodes_int16'], 'hbdk_params': {'hbdk_pass_through_params': '--O3 --core-num 1 --fast --max-time-per-fc 1000 ', 'input-source': {'images': 'pyramid', '_default_value': 'ddr'}}, 'debug': False, 'compile_mode': 'latency'}
2026-09-10 15:42:20,540 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4183 ############# model deps info #############
2026-09-10 15:42:20,541 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4184 hb_mapper version : 1.24.3
2026-09-10 15:42:20,542 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4187 hbdk version : 3.49.15
2026-09-10 15:42:20,543 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4189 hbdk runtime version: 3.15.55.0
2026-09-10 15:42:20,544 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4192 horizon_nn version : 1.1.0
2026-09-10 15:42:20,545 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4196 ############# model_parameters info #############
2026-09-10 15:42:20,548 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4202 onnx_model : /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/yolov11x_court_keypoint_256x256.onnx
2026-09-10 15:42:20,549 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4203 BPU march : bayes-e
2026-09-10 15:42:20,550 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4204 layer_out_dump : False
2026-09-10 15:42:20,551 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4205 log_level : DEBUG
2026-09-10 15:42:20,552 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4206 working dir : /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/yolov11x_court_keypoint_model_256x256_output
2026-09-10 15:42:20,552 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4207 output_model_file_prefix: yolov11x_court_keypoint_bayese_256x256_nv12
2026-09-10 15:42:20,553 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4228 ############# input_parameters info #############
2026-09-10 15:42:20,554 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4246 ------------------------------------------
2026-09-10 15:42:20,555 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4248 ---------input info : images ---------
2026-09-10 15:42:20,555 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4249 input_name : images
2026-09-10 15:42:20,556 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4250 input_type_rt : nv12
2026-09-10 15:42:20,557 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4252 input_space&range : regular
2026-09-10 15:42:20,557 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4254 input_layout_rt : NCHW
2026-09-10 15:42:20,558 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4255 input_type_train : rgb
2026-09-10 15:42:20,559 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4256 input_layout_train : NCHW
2026-09-10 15:42:20,560 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4257 norm_type : data_scale
2026-09-10 15:42:20,561 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4258 input_shape : 1x3x256x256
2026-09-10 15:42:20,561 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4266 scale_value : 0.003921568627451,
2026-09-10 15:42:20,562 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4268 cal_data_dir : /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/16_yolov11_pose/mapper/court_keypoint_calibration_data_rgb_f32_256x256
2026-09-10 15:42:20,563 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4270 cal_data_type : float32
2026-09-10 15:42:20,564 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4271 ---------input info : images end -------
2026-09-10 15:42:20,565 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4272 ------------------------------------------
2026-09-10 15:42:20,566 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4274 ############# calibration_parameters info #############
2026-09-10 15:42:20,567 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4275 preprocess_on : False
2026-09-10 15:42:20,567 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4276 calibration_type: : max
2026-09-10 15:42:20,568 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4278 optimization : set_all_nodes_int16;
2026-09-10 15:42:20,568 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4281 max_percentile : 0.99995
2026-09-10 15:42:20,569 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4284 per_channel : True
2026-09-10 15:42:20,570 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4303 ############# compiler_parameters info #############
2026-09-10 15:42:20,570 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4305 debug : False
2026-09-10 15:42:20,571 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4307 compile_mode : latency
2026-09-10 15:42:20,571 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4310 hbdk_pass_through_params: --O3 --core-num 1 --fast --max-time-per-fc 1000
2026-09-10 15:42:20,572 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4310 input-source : {'images': 'pyramid', '_default_value': 'ddr'}
2026-09-10 15:42:20,721 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 783 Convert to runtime bin file successfully!
2026-09-10 15:42:20,722 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 784 End Model Convert
