llm_compression/scripts/run_pipeline.sh这个脚本似乎不支持CPU offload?
llm_compression/scripts/run_pipeline.sh这个脚本似乎不支持CPU offload?而且light_compress用的配置文件里写的Qwen3_5VL还没注册,bash scripts/run_llmc_serial.sh --cuda_devices 0 configs/released_models/qwen3_5/step_1_quarot.yml configs/released_models/qwen3_5/step_2_gptq.yml [rank0]: Traceback (most recent call last): [rank0]: File “/home/a/user/sundongdong/oellm/D-Robotics_LLM_2.0.0_S600_S100_SDK/llm_compression/lightcompress/scripts/../llmc/_main_.py”, line 282, in [rank0]: main(config) [rank0]: File “/home/a/user/sundongdong/oellm/D-Robotics_LLM_2.0.0_S600_S100_SDK/llm_compression/lightcompress/scripts/../llmc/_main_.py”, line 33, in main [rank0]: model = load_model_class(config.model.type)(config) [rank0]: File “/home/a/user/sundongdong/oellm/D-Robotics_LLM_2.0.0_S600_S100_SDK/llm_compression/lightcompress/llmc/models/_init_.py”, line 70, in load_model_class [rank0]: return MODEL_REGISTRY[name] [rank0]: File “/home/a/user/sundongdong/oellm/D-Robotics_LLM_2.0.0_S600_S100_SDK/llm_compression/lightcompress/llmc/utils/registry_factory.py”, line 27, in _getitem_ [rank0]: return self._dict[key] [rank0]: KeyError: ‘Qwen3_5VL’ ?
