RDKX5应用YOLO11部署问题
在RDKX5上部署YOLO11时出现了问题,请求各位大佬帮助
用python方法说找不到摄像头,摄像头是sc230ai,ls -l /dev/video*也说找不到,但我用tros部署官方的yolov2模型是正常的,摄像头硬件应该是没连错
can’t open camera by index
以下是原python部署代码有更改的部分
  # 日志模块配置
  # logging configs
logging.basicConfig(
level = logging.DEBUG,
format = '[%(name)s] [%(asctime)s.%(msecs)03d] [%(levelname)s] %(message)s',
datefmt='%H:%M:%S')
logger = logging.getLogger("RDK_YOLO")
parser.add_argument('--model-path', type=str, default='/home/sunrise/yolo/baitiao_modified.bin',
                help="""Path to BPU Quantized *.bin Model.
                        RDK X3(Module): Bernoulli2.
                        RDK Ultra: Bayes.
                        RDK X5(Module): Bayes-e.
                        RDK S100: Nash-e.
                        RDK S100P: Nash-m.""")
parser.add_argument('--test-img', type=str, default='/home/sunrise/yolo/2.png', help='Path to Load Test Image.')
parser.add_argument('--img-save-path', type=str, default='jupyter_result.jpg', help='Path to Load Test Image.')
parser.add_argument('--classes-num', type=int, default=1, help='Classes Num to Detect.')
parser.add_argument('--reg', type=int, default=16, help='DFL reg layer.')
parser.add_argument('--iou-thres', type=float, default=0.45, help='IoU threshold.')
parser.add_argument('--conf-thres', type=float, default=0.25, help='confidence threshold.')
opt = parser.parse_args()
logger.info(opt)
def signal_handler(signal, frame):
sys.exit(0)
def postProcess(self, outputs: list[np.ndarray]) → tuple[list]:
begin_time = time()
# reshape
s_bboxes = outputs[0].reshape(-1, 64)
m_bboxes = outputs[1].reshape(-1, 64)
l_bboxes = outputs[2].reshape(-1, 64)
s_clses = outputs[3].reshape(-1, 1)
m_clses = outputs[4].reshape(-1, 1)
l_clses = outputs[5].reshape(-1, 1)
coco_names = [
“BAITIAO”
#if name == ‘main’: #主函数
# 打开 mipi camera
cap = cv2.VideoCapture(6) # 使用摄像头6
if not cap.isOpened():
print(“Cannot open camera”)
#sys.exit()
# 设置 camera的输出图像格式为 MJPEG, 分辨率 1920 x 1080
codec = cv2.VideoWriter_fourcc('M', 'J', 'P', 'G')
cap.set(cv2.CAP_PROP_FOURCC, codec)
cap.set(cv2.CAP_PROP_FPS, 30)
cap.set(cv2.CAP_PROP_FRAME_WIDTH, 640)
cap.set(cv2.CAP_PROP_FRAME_HEIGHT, 640)
# Get HDMI display object
# 获取HDMI显示对象
#disp = srcampy.Display()
# For the meaning of parameters, please refer to the relevant documents of HDMI display
#disp_w, disp_h = get_display_res()
#disp.display(0, 640, 480)
#disp.display(0, disp_w, disp_h)
#print(disp_w,disp_h)
#显示输入尺寸
#model = dnn.load('./byolo11n_detect_bayese_640x640_nv12.bin')
model = YOLO11_Detect(opt.model_path, opt.conf_thres, opt.iou_thres)
start_time = time()
image_counter = 0
while True: #主循环
#读取摄像头帧
ret, frame = cap.read()
if not ret:
print(“Can’t receive frame (stream end?). Exiting …”)
break
nv12_data = model.bgr2nv12(frame)
#outputs = model[0].forward(nv12_data)
outputs = model.c2numpy(model.forward(nv12_data)) # 模型推理
ids, scores, bboxes = model.postProcess(outputs) # 后处理
    # 在处理检测结果之前添加检查
    if len(ids) == 0:
        logger.info("No objects detected.")
        for class_id, score, bbox in zip(ids, scores, bboxes):
            x1, y1, x2, y2 = bbox
            logger.info("(%d, %d, %d, %d) -> %s: %.2f" % (x1, y1, x2, y2, coco_names[class_id], score))
            draw_detection(frame, (x1, y1, x2, y2), score, class_id)
# 保存结果
    #tensor = <dnnpy.PyDNNTensor object at 0xffff74e48ad0>
    #print(dir(tensor))
    #prediction_bbox = postprocess(outputs, input_shape, origin_img_shape=(1080,1920))
	HDMI输出
    #resized_data = cv2.resize(frame,(1920,1080))#如果压缩或者1拉升只有十五帧左右
    #resized_data = frame
    #nv12_data = bgr2nv12_opencv(resized_data)#通过上面函数转化成HDMI显示屏可输出格式
    #print("is ok")
    #disp.set_img(nv12_data.tobytes())
    #cv2.imshow("frame",frame)
	over
    # 显示图像
    #cv2.imshow('Original', frame)
    #if ser.in_waiting:
    #   data_receive_from_uart = ser.read_until(b"\n").decode('UTF-8')
    #   print("\033[31m" + "--> RDK X3 Received Message From ESP32: \n%s"%data_receive_from_uart + "\033[0m")
    # 计算帧率
    finish_time = time()
    image_counter = image_counter + 1
    #print(finish_time-begin_time)
    if finish_time - start_time > 5:
        print("FPS: {:.2f}".format(image_counter / (finish_time - start_time)))
        start_time = finish_time
        image_counter = 0
    if cv2.waitKey(1) == ord('q'):
        break
cap.release()
cv2.destroyAllWindows()
用tros会报错,而且我之前用config_file=/config/yolov2workconfig可以实现今天也报错了(可能因为今天我重新烧录了一次系统?)这是官方示例的报错
Camera calibration file is not exist
下面也是Websocket did not receive AI data
这是我自己的模型报错
Camera calibration file is not exist!
这是我的baitiao.json
“model_file”: “/home/sunrise/yolo/baitiao3_modified.bin”,
“task_num”: 4,
“dnn_Parser”: “yolov8”,
“model_output_count”: 6,
“reg_max”: 16,
“class_num”: 1,
“cls_names_list”: “/home/sunrise/yolo/baitiao.list”,
“strides”: [8, 16, 32],
“score_threshold”: 0.25,
“nms_threshold”: 0.7,
“nms_top_k”: 300,
# “output_order”: [0,1,2,3,4,5]
我的转换过程如下:
按教程先删ultralytics
优化block里的attention模块
def _forward(self, x):
Forward pass of the Attention module.
    Args:
        x (torch.Tensor): The input tensor.
    Returns:
        (torch.Tensor): The output tensor after self-attention.
    B, C, H, W = x.shape
    N = H * W
    qkv = self.qkv(x)
    q, k, v = qkv.view(B, self.num_heads, self.key_dim * 2 + self.head_dim, N).split(
        [self.key_dim, self.key_dim, self.head_dim], dim=2
    attn = (q.transpose(-2, -1) @ k) * self.scale
    attn = attn.softmax(dim=-1)
    x = (v @ attn.transpose(-2, -1)).view(B, C, H, W) + self.pe(v.reshape(B, C, H, W))
    x = self.proj(x)
    return x
def forward(self, x):
    print(f"{x.shape = }")
    N = H * W
    qkv = self.qkv(x)
    attn = attn.permute(0, 3, 1, 2).contiguous()  # CHW2HWC like
    max_attn = attn.max(dim=1, keepdim=True).values
    exp_attn = torch.exp(attn - max_attn)
    sum_attn = exp_attn.sum(dim=1, keepdim=True)
    attn = exp_attn / sum_attn
    attn = attn.permute(0, 2, 3, 1).contiguous()  # HWC2CHW like
    x = self.proj(x)
    return x
再修改head里面的输出头,两个顺序我都试过了都不行
“”“Concatenates and returns predicted bounding boxes and class probabilities.”“”
if self.end2end:
return self.forward_end2end(x)
    for i in range(self.nl):
        x[i] = torch.cat((self.cv2[i](x[i]), self.cv3[i](x[i])), 1)
    if self.training:  # Training path
        return x
    y = self._inference(x)
    return y if self.export else (y, x)
    result = []
        result.append(self.cv2[i](x[i]).permute(0, 2, 3, 1).contiguous())
        result.append(self.cv3[i](x[i]).permute(0, 2, 3, 1).contiguous())
    return result
然后编译成.onnx
这是编译成.bin的yaml文件
onnx_model: ‘./baitiao.onnx’
march: “bayes-e”
layer_out_dump: False
working_dir: ‘datasetworkenv’
output_model_file_prefix: ‘baitiao’
# YOLO11 n, s, m
node_info: {“/model.10/m/m.0/attn/Softmax”: {‘ON’: ‘BPU’,‘InputType’: ‘int16’,‘OutputType’: ‘int16’}}
# YOLO11 l, x
# node_info: {“/model.10/m/m.0/attn/Softmax”: {‘ON’: ‘BPU’,‘InputType’: ‘int16’,‘OutputType’: ‘int16’},
# “/model.10/m/m.1/attn/Softmax”: {‘ON’: ‘BPU’,‘InputType’: ‘int16’,‘OutputType’: ‘int16’}}
input_name: “”
input_type_rt: ‘nv12’
input_type_train: ‘rgb’
input_layout_train: ‘NCHW’
norm_type: ‘data_scale’
cal_data_dir: ‘./dataset’
cal_data_type: ‘float32’
compile_mode: ‘latency’
debug: False
optimize_level: ‘O3’
编译出.bin后删除反量化系数,这是bin文件输出
[baitiao]
input[0]:
input source: HB_DNN_INPUT_FROM_PYRAMID
valid shape: (1,3,640,640,)
aligned shape: (1,3,640,640,)
aligned byte size: 614400
tensor type: HB_DNN_IMG_TYPE_NV12
quanti type: NONE
stride: (0,0,0,0,)
output[0]:
valid shape: (1,80,80,64,)
aligned shape: (1,80,80,64,)
aligned byte size: 1638400
quanti type: SCALE
scale data: 0.000400265,0.000335505,0.000401362,0.000324712,0.000252452,0.000259953,0.000339713,0.000298552,0.000256294,0.000217145,0.000184949,0.000199218,0.000225743,0.000214218,0.000266172,0.000240378,0.000334408,0.000330383,0.00029032,0.000300199,0.000313553,0.000273673,0.0002766,0.000258489,0.000255928,0.000264343,0.000277149,0.000346299,0.000594909,0.000507466,0.00067723,0.000257391,0.000380142,0.000354897,0.000374288,0.000292881,0.000294711,0.000343189,0.000421485,0.00032087,0.000276234,0.000249891,0.000242391,0.00025355,0.000228305,0.000218792,0.000234342,0.000210743,0.000394777,0.000381605,0.000308248,0.000266172,0.000348677,0.000347762,0.000288308,0.000250257,0.000202693,0.000207267,0.000241659,0.000266538,0.000143605,0.000151837,0.000195193,0.000183028,
quantizeAxis: 3
output[1]:
valid shape: (1,80,80,1,)
aligned shape: (1,80,80,1,)
aligned byte size: 25600
quanti type: NONE
stride: (25600,320,4,4,)
output[2]:
valid shape: (1,40,40,64,)
aligned shape: (1,40,40,64,)
aligned byte size: 409600
quanti type: SCALE
stride: (409600,10240,256,4,)
scale data: 0.000508657,0.00054944,0.000411608,0.000367427,0.000378944,0.000305685,0.000269622,0.000298133,0.000259993,0.000253762,0.000243189,0.000274154,0.000234692,0.000225629,0.000249608,0.000271133,0.000453147,0.000453147,0.000368559,0.00032721,0.000344958,0.000279252,0.000281517,0.000269056,0.000304552,0.000246399,0.000263014,0.000270566,0.000265468,0.000253196,0.000238091,0.000242622,0.000424447,0.000490154,0.000394615,0.000343447,0.000346846,0.00034628,0.000337972,0.000306818,0.000313427,0.000316825,0.000332685,0.000315315,0.000285294,0.000278685,0.000309084,0.000291902,0.000396881,0.00038272,0.000327965,0.000341937,0.000263203,0.00031286,0.000284161,0.000278874,0.000280196,0.00030814,0.000295678,0.00030021,0.000276042,0.000259049,0.000280762,0.000310028,
quantizeAxis: 3
output[3]:
valid shape: (1,40,40,1,)
aligned shape: (1,40,40,1,)
aligned byte size: 6400
quanti type: NONE
stride: (6400,160,4,4,)
output[4]:
valid shape: (1,20,20,64,)
aligned shape: (1,20,20,64,)
aligned byte size: 102400
quanti type: SCALE
stride: (102400,5120,256,4,)
scale data: 0.000407474,0.000465104,0.000411778,0.000406278,0.0003673,0.000494995,0.000385235,0.000395757,0.000343866,0.000359887,0.000446213,0.000414169,0.000443104,0.00126164,0.00189294,0.00188241,0.0004333,0.000430191,0.000398148,0.000370409,0.000346974,0.000380452,0.000395517,0.000309671,0.000401257,0.000436169,0.000358692,0.00032091,0.000543777,0.00263615,0.0289249,0.0149139,0.000379257,0.0004003,0.000375909,0.000453865,0.000385952,0.00034267,0.000335975,0.000318757,0.000296519,0.000361083,0.000368735,0.000411539,0.000862773,0.0016079,0.00237406,0.00736896,0.000381409,0.000395278,0.000362518,0.000382126,0.00031541,0.000391931,0.000327127,0.000333822,0.0003893,0.000380452,0.000309192,0.000333344,0.000431626,0.000755166,0.00100912,0.00110955,
quantizeAxis: 3
output[5]:
valid shape: (1,20,20,1,)
aligned shape: (1,20,20,1,)
aligned byte size: 1600
quanti type: NONE
stride: (1600,80,4,4,)
纯小白第一次接触开发板,只好跟着教程一步步走,如有低级错误请多多海涵,python部署部分仿照了 RDKx5板载yolov11我也是成功了! - 板卡使用 / 新手上路 - 地瓜机器人论坛 (d-robotics.cc)
请问我的问题出在了哪里,或者还需要我提供些什么来查错?
非常感谢!
总结
此文本将被隐藏
你好,模型量化过程严格按照model zoo的流程走即可,转化后的模型也可以使用model zoo中的脚本进行本地图片回灌测试,测试正常模型便是正常的,您所说的摄像头找不到问题,首先请您仔细检测摄像头连接,参考手册测试mipi摄像头 3.1.1 MIPI摄像头使用 | RDK DOC
用rdk studio的示例是能用的,所以硬件连接应该没有问题
i2cdetect结果如下
但是测试mipi摄像头会报以下错
用推理代码改图片路径后模型测试会报以下错
请问我还需要提供什么吗
现在用TROS部署官方模型也可以了,但部署我自己的模型还是报错
严格按照这个流程走 :rdk_model_zoo/demos/detect/YOLO11/YOLO11-Detect_YUV420SP/README_cn.md at main · D-Robotics/rdk_model_zoo
感谢解答!我确实是严格按照这个教程走的rdk_model_zoo/demos/detect/YOLO11/YOLO11-Detect_YUV420SP 在主 ·D-机器人/rdk_model_zoo ·GitHub的
不过可能有疏漏,那请问我这个是模型转换出错了吗,如果是的话我再按流程走一遍,如果不是的话我还需要提供什么来找到问题
  1. 确保使用的是最新的系统
    目前社区对RDK X5提供的最新系统版本为3.2.3, 请烧录最新的系统后再试。
    miniBoot版本也需要保持最新, 升级方法为, 给板卡连接可访问互联网的网络, 在系统的终端命令行中, 输入 sudo srpi-config命令,1-SystemOptions,S7-UpdateMiniBoot,来升级miniboot。
  2. TROS在运行一次YOLO功能后,在当前目录的config文件夹内有若干workconfig.json文件,在这个workconfig.json文件中,有TROS使用的bin模型的路径,这些模型都是RDK板子上自带的. 您可以使用上述方法来比对自己的模型和板子上自带的能跑的模型的区别。对比的项目有:输出头的顺序,tensor type,量化与反量化类型.
