如题,今天刚收到货,开机后使用 tf 卡刷了官方固件,启动后测试了 vscode,并更新了 apt 源,
后来断电重启,重启后发现无法启动,使用串口可以看到 如下日志
�^@�^@NOTICE: Enter SPI NAND-FLASH Mode…
NOTICE: Nand PAGE_SIZE_2K
NOTICE: Nand is_dummy = true
NOTICE: Nand CLK_12M
NOTICE: SPI baudrate is set to 12000000Hz
NOTICE: Nand reset
NOTICE: reg_status should = 0x18
NOTICE: Invalid enable flash buffer mode
NOTICE: Manufacturer ID 0xc8 Device ID 0x41c8
NOTICE: Enter media_source_select process(5).
NOTICE: SPI Nand flash set quad PASS
NOTICE: Get S1PK
NOTICE: [verify_signature] pass.
NOTICE: [verify_hash] pass.
NOTICE: [auth_decrypt] pass.
NOTICE: BL1: BL2 memory layout address = 0x1fe9f000
NOTICE: BL1: Booting BL2
NOTICE: OTP config:
NOTICE: otp exist: true
NOTICE: test region size: 304
NOTICE: secure region size: 120
NOTICE: none secure region size: 56
NOTICE: origin vdd cpu:800mv, now vdd cpu: 850mv
NOTICE: BL2: v2.8(release):v1.0.8-61-g0aaad43fc
NOTICE: BL2: Built : 10:24:50, Nov 19 2024
NOTICE: dw_apb_ssi_params.apb_bus_freq: 100000000
NOTICE: SPI baudrate is set to 12500000Hz
NOTICE: BL2 config file
NOTICE: ab slot is : 0
NOTICE: fip index:0
NOTICE: start to load bl2 cfg image
NOTICE: BL2 CFG ADDR:0x1ff00000, MAGIC:0x474643324c424248
NOTICE: bypass update efuse
NOTICE: calibration_offset 8
NOTICE: trimming_value 8
NOTICE: ADC read channel[2]: 1115mv
ERROR: invalid ddr adc value:1115mv
ERROR: invalid ddr type:0 rank type:0, use 3200
ERROR: invalid ddr type:0 rank type:0 freq:3200, disable dvfs
NOTICE: ddr info:[LPDDR4X]-[DUAL_RANK]-[ECC OFF]-[DVFS OFF]-[3200M]
NOTICE: JTAG ENABLE
NOTICE: disable wdt
NOTICE: Get S1PK
NOTICE: start to load ddr image
NOTICE: run ddr Fw
NOTICE: cannot matching ddr profile with aon input
NOTICE: type: not supported ddr type, freq: 0, ecc: 0(0x00), rank: 0, dvfs: 0, version: 0.00
ERROR: choose error
似乎有 ddr 无法识别问题
你好,建议先烧录最新版本的系统并且更新miniboot为最新版本
你好,尝试升级 miniboot 时依然报错,下面为执行日志
[MainThread][16:10:24] [INFO] xburn 1.1.3
[MainThread][16:10:24] [INFO] Run command: \?\C:\Users\YPF\AppData\Local\xburn-gui\xburn.exe -V info -p X5 -l serial -d xmodem_xmodem -i C:\Users\YPF\Downloads\product_20250618 --batch_num 1 --baudrate 115200 --serial COM1 --reboot
[MainThread][16:10:24] [INFO] Configuration merged with xburn config, command-line args and product config: {
“log_level”: “info”,
“product_type”: “X5”,
“link_type”: “serial”,
“dl_mode”: “xmodem_xmodem”,
“img_files”: [
“C:\Users\YPF\Downloads\product_20250618\nand_disk.img”
“erase_scrub”: false,
“security_type”: “secure”,
“boot_check”: false,
“batch_num”: 1,
“host_ip”: [
“192.168.1.100”
“board_ip”: [
“192.168.1.10”
“netmask”: [
“255.255.255.0”
“gateway”: [
“192.168.1.1”
“ipv6”: false,
“usb_port”: “usb2.0”,
“serial”: [
“COM1”
“baudrate”: [
“115200”
“mcu_serial”: [
“N/A”
“hsm_serial”: [
“N/A”
“erase_part”: ,
“select_part”: [
“all”
“backup_part”: ,
“reboot”: true,
“security”: “secure”,
“compress_image”: true,
“check_version_latest”: true,
“support_images_name”: [
“disk.img",
“disk.simg"
“support_baudrate”: [
“4800”,
“9600”,
“38400”,
“115200”,
“921600”
“xmodem_support_files”: "update files(.img)”,
“ymodem_support_files”: "update files(.img)”,
“dfu_support_files”: “update files(.img .json)",
“fastboot_support_files”: "update files(.img .json)",
“ota_support_files”: "update files(.zip)",
“mcu_support_files”: "update files(.zip)”,
“separate”: “0x08000000”,
“ota_mode”: [
“sftp”
“boot_choose”: [
“misc”
“username”: “root”,
“password”: “root”,
“uboot_prompt”: “Hobot>”,
“login_prompt”: “login:”,
“shell_prompt”: “root@”,
“recovery_prompt”: “/userdata/cache”,
“boot_timeout”: 120,
“ota_update_timeout”: 180,
“ota_app_update_timeout”: 120,
“fastboot_timeout”: 3000,
“ddr_size”: “0x190000000”,
“load_address”: “0x90000000”,
“ota_result”: “/userdata/log/ota/result”,
“backup_timeout”: 1500,
“unzip_address”: “0xa0000000”,
“download_root”: “/userdata”,
“boot_file”: “C:\Users\YPF\AppData\Local\xburn-gui\configs\product_config\x5\boot_config\x5_uart_boot.json”,
“boot_config”: [
“file”: “uart_usb/bl2_uart_ddr.bin”,
“uart”: “acore”,
“method”: “xmodem”,
“timeout”: 2
“file”: “uart_usb/bl3x_all.bin”,
“uart”: “acore”,
“method”: “xmodem”,
“timeout”: 2
“serial_prompt_info”: “[IMPORTANT] Please power on or reboot the Board!”,
“name”: “X5”,
“support_link_type”: [
“usb”,
“serial_usb”,
“serial_ethernet”,
“serial”
“support_partitions”: [
“all”,
“mbr”,
“miniboot”,
“miniboot_bak1”,
“misc”,
“uboot”,
“ubootenv”,
“vbmeta”,
“boot”,
“system”,
“hbre”,
“app”,
“private”,
“userdata”
“upfile_json”: [
“x5-soc-debug-gpt.json”,
“x5-soc-debug-nand-gpt.json”
“usb_select”: false,
“serial_into_usb”: “usb20”,
“usb_vendor”: “3652”,
“mmc_index”: “0”,
“original_img_dirs”: “C:\Users\YPF\Downloads\product_20250618”,
“storage_type”: “nand”
[MainThread][16:10:24] [INFO] ********************************************************************************
[MainThread][16:10:24] [INFO] Burning board [1/1], total boards: 1
[MainThread][16:10:24] [INFO] Product: X5
[MainThread][16:10:24] [INFO] Link type: serial
[MainThread][16:10:24] [INFO] Download mode: xmodem_xmodem
[MainThread][16:10:24] [INFO] Serial: COM1
[MainThread][16:10:24] [INFO] Baudrate: 115200
[MainThread][16:10:24] [INFO] Image File(s): [‘C:\Users\YPF\Downloads\product_20250618\nand_disk.img’]
[MainThread][16:10:24] [INFO] Burn chain:
[MainThread][16:10:24] [INFO] Step 1: check_board_status → progress: [1, 5]%
[MainThread][16:10:24] [INFO] Step 2: prepare_boot → progress: [6, 10]%
[MainThread][16:10:24] [INFO] Step 3: xmodem_boot → progress: [11, 20]%
[MainThread][16:10:24] [INFO] Step 4: prepare_burn → progress: [21, 25]%
[MainThread][16:10:24] [INFO] Step 5: xmodem_burn → progress: [26, 85]%
[MainThread][16:10:24] [INFO] Step 6: after_burn → progress: [86, 90]%
[MainThread][16:10:24] [INFO] Step 7: check_burn_result → progress: [91, 100]%
[Burn thread-1][16:10:24] [INFO] Start burning…
[Burn thread-1][16:10:24] [INFO] Start step: check_board_status
[Burn thread-1][16:10:24] [PROGRESS] Board 1 burn progress 1.0%
[Burn thread-1][16:10:24] [INFO] Check board status to confirm the burn process…
[Burn thread-1][16:10:24] [INFO] Running probe_board_state…
[Burn thread-1][16:10:24] [INFO] Probing board state…
[Burn thread-1][16:10:25] [WARNING] Operation timed out after 0.5 seconds
[Burn thread-1][16:10:25] [WARNING] Board state: UNKNOWN
[Burn thread-1][16:10:25] [INFO] Step ‘check_board_status’ completed successfully
[Burn thread-1][16:10:25] [PROGRESS] Board 1 burn progress 5.0%
[Burn thread-1][16:10:25] [INFO] Start step: prepare_boot
[Burn thread-1][16:10:25] [PROGRESS] Board 1 burn progress 6.0%
[Burn thread-1][16:10:25] [INFO] Prepare boot…
[Burn thread-1][16:10:25] [INFO] Please try enter UART download mode
[Burn thread-1][16:10:25] [INFO] Try entry UART download mode…
[Burn thread-1][16:10:25] [WARNING] [IMPORTANT] Please power on or reboot the Board!
[Burn thread-1][16:10:55] [WARNING] Entry UART download mode timed out after 30 seconds.
[Burn thread-1][16:10:55] [ERROR] Failed to enter UART download mode, Board state: UNKNOWN
[Burn thread-1][16:10:55] [ERROR] Step ‘prepare_boot’ failed
[Burn thread-1][16:10:55] [ERROR] Board-1, burn failed
[Burn thread-1][16:10:55] [ERROR] Board-1 [Storage: nand] Status: FAILED
Process terminated with status: Some(0)
我现在又测试了下,发现串口上电也完全没有输出了,是不是硬件异常了?
我更新了日志,可以再帮忙确认下吗?
是按照我发的教程烧录miniboot时出现问题,我看到已经正常进行到6%暂停,后面需要断电后重新上电,软件应该会继续烧录,是按照操作规范操作的吗,我看日志是超时没有重新上电
并不是的,我是按提示操作的,提示断电就重新插拔电源,也试过先不插电源烧录,到 6% 时重新插电源,但是都报错.
另外 即使 miniboot 有问题,会出现串口完全无输出吗? 我现在的状态是不管怎么换 usb 口,换 microusb 线,插拔电源后串口完全一点输出没有
这边可能需要联系销售渠道返厂做一个检修
我和你遇到的现象一模一样,请问最后怎么解决的呢?多谢
