RDK x5的imx219使用出厂固件可以打开。自己编译的打不开
编译出来的rdk-x5-ubuntu22-preinstalled-desktop-3.2.3-arm64.img烧录进去,imx219打不开。
root@ubuntu:~# i2cdetect -y -r 6
00: – – – – – – – –
10: 10 – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – – – – – – – – – – – – – – –
50: – – – – – – – – – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
root@ubuntu:~# sudo systemctl stop lightdm
root@ubuntu:~# cd /app/pydev_demo/03_mipi_camera_sample/
root@ubuntu:/app/pydev_demo/03_mipi_camera_sample# sudo python3 ./mipi_camera.py
Failed to open DRM device
Resolution 1920x1080 does not exist in the list.
[ERROR][utils/mem_log.c:94] [361.02771][4412:4412][MEM_ALLOCATOR] <hb_mem_free_buf:2222> Memory module is not found.
[ERROR][utils/mem_log.c:94] [361.02778][4412:4412][MEM_ALLOCATOR] <hb_mem_free_buf:2222> Memory module is not found.
[ERROR][utils/mem_log.c:94] [361.02781][4412:4412][MEM_ALLOCATOR] <hb_mem_free_buf:2222> Memory module is not found.
drmModeGetResources: Inappropriate ioctl for device
[ERROR][utils/mem_log.c:94] [361.02790][4412:4412][MEM_MANAGER] <hb_mem_module_close:349> Memory module has been closed.
[BPU_PLAT]BPU Platform Version(1.3.6)!
[A][DNN][packed_model.cpp:247]Model [HorizonRT] The model builder version = 1.23.5
[W][DNN]bpu_model_info.cpp:491]Version Model: fcos_efficientnetb0_512x512_nv12. Inconsistency between the hbrt library version 3.15.55.0 and the model build version 3.15.47.0 detected, in order to ensure correct model results, it is recommended to use compilation tools and the BPU SDK from the same OpenExplorer package.
— model input properties —
你好,这块可以尝试使用社区发布的最新的稳定版系统来试一试219使用是否正常,社区发布的系统是经过了完整QA测试的,我们需要先来定位一下问题,才能解决问题。
还有一个需要同步升级的点是miniboot
  1. 所有较早批次板卡板卡老系统老miniboot均可正常使用,不涉及产品质量问题。
  2. 所有较新批次板卡新系统新miniboot均可正常使用,不涉及产品质量问题。
  3. 如果出现跨代或者版本差距过大导致无法启动,请完成版本升级: 系统启动失败 / 模块失效?一文带你搞定 Miniboot 升级问题!
