NOTICE: Welcome to Horizon X5 ASIC BOOTROM - V4.1
NOTICE: OTP config:
NOTICE: otp exist: true
NOTICE: test region size: 304
NOTICE: secure region size: 120
NOTICE: none secure region size: 56
NOTICE: Enable MMU
NOTICE: BL1: v2.8(release):
NOTICE: BL1: Built : 17:42:12, Oct 19 2023
NOTICE: Enter SPI NAND-FLASH Mode…
NOTICE: Nand PAGE_SIZE_2K
NOTICE: Nand is_dummy = true
NOTICE: Nand CLK_12M
NOTICE: SPI baudrate is set to 12000000Hz
NOTICE: Nand reset
NOTICE: reg_status should = 0x18
NOTICE: Invalid enable flash buffer mode
NOTICE: Manufacturer ID 0xc8 Device ID 0x41c8
NOTICE: Enter media_source_select process(5).
NOTICE: SPI Nand flash set quad PASS
NOTICE: Get S1PK
NOTICE: [verify_signature] pass.
NOTICE: [verify_hash] pass.
NOTICE: [auth_decrypt] pass.
NOTICE: BL1: BL2 memory layout address = 0x1fe9f000
NOTICE: BL1: Booting BL2
NOTICE: OTP config:
NOTICE: origin vdd cpu:800mv, now vdd cpu: 850mv
NOTICE: BL2: v2.8(release):v1.0.8-61-g0aaad43fc
NOTICE: BL2: Built : 10:24:50, Nov 19 2024
NOTICE: dw_apb_ssi_params.apb_bus_freq: 100000000
NOTICE: SPI baudrate is set to 12500000Hz
NOTICE: BL2 config file
NOTICE: ab slot is : 0
NOTICE: fip index:0
NOTICE: start to load bl2 cfg image
NOTICE: BL2 CFG ADDR:0x1ff00000, MAGIC:0x474643324c424248
NOTICE: bypass update efuse
NOTICE: calibration_offset 12
NOTICE: trimming_value 8
NOTICE: ADC read channel[2]: 1104mv
ERROR: invalid ddr adc value:1104mv
ERROR: invalid ddr type:0 rank type:0, use 3200
ERROR: invalid ddr type:0 rank type:0 freq:3200, disable dvfs
NOTICE: ddr info:[LPDDR4X]-[DUAL_RANK]-[ECC OFF]-[DVFS OFF]-[3200M]
NOTICE: JTAG ENABLE
NOTICE: disable wdt
NOTICE: Get S1PK
NOTICE: start to load ddr image
NOTICE: run ddr Fw
NOTICE: cannot matching ddr profile with aon input
NOTICE: type: not supported ddr type, freq: 0, ecc: 0(0x00), rank: 0, dvfs: 0, version: 0.00
ERROR: choose error
这是mobaxterm上的报错。我的originbot连不上串口了,我尝试了重新烧录sd卡系统,换卡或者换系统或者换烧录软件,尝试升级miniboot但失败了很多次,请问有什么办法吗?
