root@ubuntu:/app/cdev_demo/step5_stability_test# sudo python3 test_cam.py
=== MIPI 摄像头可用性测试 ===
注意:MIPI 摄像头不会显示在 v4l2-ctl 中
2026/06/26 12:12:47.027 !INFO [OpenCamera][0450]hbn module
set camera fps: 20,width: -1,height: -1
Camera 0:
mipi_host: 0
Camera 1:
mipi_host: 2
Camera 2:
mipi_host: 0
Camera 3:
mipi_host: 0
mipi mclk is not configed.
WARN: Sensor Name: sc035hgs, Expected Chip ID: 0x5A, Actual Chip ID Read: 0x00
WARN: Sensor Name: imx477-2016x1520-40fps, Expected Chip ID: 0x477, Actual Chip ID Read: 0x00
WARN: Sensor Name: imx586-30fps-4lane, Expected Chip ID: 0x586, Actual Chip ID Read: 0x00
WARN: Sensor Name: os08c10-30fps-2lane, Expected Chip ID: 0x53, Actual Chip ID Read: 0x00
2026/06/26 12:12:47.156 ERROR [CamInitParam][0283]No camera sensor found, please check whether the camera connection or video_idx is correct.
2026/06/26 12:12:47.156 ERROR [OpenCamera][0498]CamInitParam failed error(-1)
mipi_host 0: open_ret=-1
? 打开失败
2026/06/26 12:12:47.157 !INFO [OpenCamera][0450]hbn module
Camera 0:
mipi_host: 0
Camera 1:
mipi_host: 2
Camera 2:
mipi_host: 0
Camera 3:
mipi_host: 0
2026/06/26 12:12:47.169 ERROR [CamInitParam][0283]No camera sensor found, please check whether the camera connection or video_idx is correct.
2026/06/26 12:12:47.169 ERROR [OpenCamera][0498]CamInitParam failed error(-1)
mipi_host 2: open_ret=-1
? 打开失败
