cat /home/sunrise/Dev/SoundImg/build/diagnose/summary.txt
=== 运行参数 ===
project_root /home/sunrise/Dev/SoundImg
launcher /home/sunrise/Dev/SoundImg/scripts/run_private_runtime.sh
bin_name DesSoundImg
direct_mode 0
binary /home/sunrise/Dev/SoundImg/build/DesSoundImg
output_dir /home/sunrise/Dev/SoundImg/build/diagnose
run_seconds 120
target_usb 1bcf:28c4
=== 系统环境 ===
uname Linux ubuntu 6.1.83 #4 SMP PREEMPT Fri Dec 19 10:54:38 CST 2025 aarch64 aarch64 aarch64 GNU/Linux
user root
groups root
ulimit_core 0
=== USB与设备节点 ===
usb_detected yes
usb_line Bus 001 Device 006: ID 1bcf:28c4 Sunplus Innovation Technology Inc. Depstech webcam MIC
usb_node /dev/bus/usb/001/006
usb_perm crw-rw---- root:video
tty_nodes /dev/ttyACM0 /dev/ttyACM1
video_nodes /dev/video0 /dev/video1 /dev/video2 /dev/video3
tty_perm crw-rw---- 1 root dialout 166, 0 Mar 26 21:00 /dev/ttyACM0
=== 节点到硬件映射 ===
map_/dev/video0 vid:pid=04b4:f8f8 model=InfraredCamera serial=Infrared_InfraredCamera_0123456789.0123456789.0123456789
sys_/dev/video0 /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.4/1-1.4:1.0/video4linux/video0
map_/dev/video1 vid:pid=04b4:f8f8 model=InfraredCamera serial=Infrared_InfraredCamera_0123456789.0123456789.0123456789
sys_/dev/video1 /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.4/1-1.4:1.0/video4linux/video1
map_/dev/video2 vid:pid=1bcf:28c4 model=Depstech_webcam_MIC serial=RH-FAY-250612_Depstech_webcam_MIC_01.00.00
sys_/dev/video2 /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/video4linux/video2
map_/dev/video3 vid:pid=1bcf:28c4 model=Depstech_webcam_MIC serial=RH-FAY-250612_Depstech_webcam_MIC_01.00.00
sys_/dev/video3 /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/video4linux/video3
map_/dev/ttyACM0 vid:pid=04b4:f8f8 model=InfraredCamera serial_short=0123456789.0123456789.0123456789
sys_/dev/ttyACM0 /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.4/1-1.4:1.2/tty/ttyACM0
map_/dev/ttyACM1 vid:pid=0483:5740 model=DES_Acoustic_Imaging_Camera serial_short=3274387C3233
sys_/dev/ttyACM1 /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.2/1-1.2.3/1-1.2.3:1.0/tty/ttyACM1
=== USB拓扑 ===
lsusb_t /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M; |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M;/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M; |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M; |__ Port 2: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M; |__ Port 3: Dev 5, If 1, Class=CDC Data, Driver=cdc_acm, 480M; |__ Port 3: Dev 5, If 0, Class=Communications, Driver=cdc_acm, 480M; |__ Port 4: Dev 6, If 0, Class=Video, Driver=uvcvideo, 480M; |__ Port 4: Dev 6, If 1, Class=Video, Driver=uvcvideo, 480M; |__ Port 4: Dev 4, If 0, Class=Video, Driver=uvcvideo, 480M; |__ Port 4: Dev 4, If 1, Class=Video, Driver=uvcvideo, 480M; |__ Port 4: Dev 4, If 2, Class=Communications, Driver=cdc_acm, 480M; |__ Port 4: Dev 4, If 3, Class=CDC Data, Driver=cdc_acm, 480M;
=== 驱动冲突检查 ===
lsmod_ftdi_sio
dmesg_ttyusb
=== 设备占用检查 ===
tty_in_use
video_in_use
=== 运行采样 ===
run_cmd timeout 120s /home/sunrise/Dev/SoundImg/scripts/run_private_runtime.sh DesSoundImg
run_log /home/sunrise/Dev/SoundImg/build/diagnose/run.log
dmesg_tail /home/sunrise/Dev/SoundImg/build/diagnose/dmesg_tail.log
=== 关键日志提取 ===
device_found Found 2 device(s). (发现 2 个设备)
start_fail Failed to start: Start failed: Module Response Timeout (-37)
ma_start [260326 210549.319859 5705.515] ma_start err:-37
trace_last none
segfault none
timeout37 Failed to start: Start failed: Module Response Timeout (-37)
close34 [260326 210549.320781 5705.516] micArrCloseTask:0xaaaacfb36740,1 err:-34
=== 诊断结论(初判) ===
diagnose_result MODULE_RESPONSE_TIMEOUT
next_action 排查串口占用/驱动冲突/多设备干扰;先仅保留1台设备复现
