motionbert模型量化后精度损失
部署motionbert模型(输入:2D人体关键点,输出:3D人体关键点),使用50个训练集数据进行校准,将部分算子转为int16,PTQ后模型输出的3D关键点存在抖动(浮点模型则没有),精度损失较大。部分算子余弦相似度较低,特别是Softmax(有的小于0.9),请问如何提高。PTQ还有什么改进的地方,或者是否需要进行QAT?
模型转换日志Part1:
2026-05-07 11:55:17,995 file: hb_mapper.py func: hb_mapper line No: 132 Start hb_mapper....
2026-05-07 11:55:17,996 file: hb_mapper.py func: hb_mapper line No: 133 hbdk version 3.49.15
2026-05-07 11:55:17,998 file: hb_mapper.py func: hb_mapper line No: 134 horizon_nn version 1.1.0
2026-05-07 11:55:18,000 file: hb_mapper.py func: hb_mapper line No: 135 hb_mapper version 1.24.3
2026-05-07 11:55:18,002 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 530 Start Model Convert....
2026-05-07 11:55:18,222 file: mapper_conf_parser.py func: mapper_conf_parser line No: 105 validating model_parameters...
2026-05-07 11:55:18,224 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1347 Using abs path /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/motionbert_lite_120.onnx
2026-05-07 11:55:18,227 file: mapper_conf_parser.py func: mapper_conf_parser line No: 260 Using onnx model file: /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/motionbert_lite_120.onnx
2026-05-07 11:55:18,891 file: onnx_parser.py func: onnx_parser line No: 39 Model input names: ['input']
2026-05-07 11:55:18,893 file: mapper_conf_parser.py func: mapper_conf_parser line No: 264 Model has 1 inputs according to model file
2026-05-07 11:55:18,895 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1347 Using abs path /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/motionbert_lite_model_output
2026-05-07 11:55:18,897 file: mapper_conf_parser.py func: mapper_conf_parser line No: 287 working_dir does not exist. Creating working_dir: /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/motionbert_lite_model_output
2026-05-07 11:55:18,901 file: mapper_conf_parser.py func: mapper_conf_parser line No: 438 node_dict: {self.node_dict}
2026-05-07 11:55:18,902 file: mapper_conf_parser.py func: mapper_conf_parser line No: 119 validating model_parameters finished
2026-05-07 11:55:18,902 file: mapper_conf_parser.py func: mapper_conf_parser line No: 123 validating input_parameters...
2026-05-07 11:55:18,903 file: mapper_conf_parser.py func: mapper_conf_parser line No: 492 Model name not given in yaml_file, using model name from model file: ['input']
2026-05-07 11:55:18,904 file: mapper_conf_parser.py func: mapper_conf_parser line No: 536 Model input shape not given in yaml_file, using shape from model file: [[1, 120, 17, 3]]
2026-05-07 11:55:18,905 file: mapper_conf_parser.py func: mapper_conf_parser line No: 135 validating input_parameters finished
2026-05-07 11:55:18,907 file: mapper_conf_parser.py func: mapper_conf_parser line No: 139 validating calibration_parameters...
2026-05-07 11:55:18,907 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1347 Using abs path /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/calibration_data_120
2026-05-07 11:55:18,908 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1007 The calibration dir name suffix is not the same as the value float32 of the parameter cal_data_type, the parameter setting will prevail
2026-05-07 11:55:18,909 file: mapper_conf_parser.py func: mapper_conf_parser line No: 155 validating calibration_parameters finished
2026-05-07 11:55:18,910 file: mapper_conf_parser.py func: mapper_conf_parser line No: 159 validating custom_op...
2026-05-07 11:55:18,910 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1076 custom_op does not exist, skipped
2026-05-07 11:55:18,911 file: mapper_conf_parser.py func: mapper_conf_parser line No: 165 validating custom_op finished
2026-05-07 11:55:18,911 file: mapper_conf_parser.py func: mapper_conf_parser line No: 168 validating compiler_parameters...
2026-05-07 11:55:18,912 file: mapper_conf_parser.py func: mapper_conf_parser line No: 1157 Input node input's input_source not set, it will be set to ddr by default
2026-05-07 11:55:18,913 file: mapper_conf_parser.py func: mapper_conf_parser line No: 183 validating compiler_parameters finished
2026-05-07 11:55:18,913 file: mapper_conf_parser.py func: mapper_conf_parser line No: 187 validating deprecated parameters...
2026-05-07 11:55:18,914 file: mapper_conf_parser.py func: mapper_conf_parser line No: 193 validating deprecated parameters finished
2026-05-07 11:55:18,914 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 54 Dump config:
2026-05-07 11:55:18,915 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 55 calibration_parameters:
  cal_data_dir: ./calibration_data_120
  cal_data_type: float32
  calibration_type: default
  max_percentile: 0.99999
  per_channel: true
  compile_mode: latency
  debug: true
  max_time_per_fc: 1000
  optimize_level: O3
  input_layout_rt: NHWC
  input_layout_train: NHWC
  input_name: ''
  input_type_rt: featuremap
  input_type_train: featuremap
  norm_type: no_preprocess
  layer_out_dump: false
  march: bayes-e
  node_info: ...
  onnx_model: ./motionbert_lite_120.onnx
  output_model_file_prefix: motionbert_lite
  working_dir: motionbert_lite_model_output
2026-05-07 11:55:19,039 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 60 input 'input' : original model shape: [1, 120, 17, 3]
2026-05-07 11:55:19,043 file: loader.py func: loader line No: 204 *******************************************
2026-05-07 11:55:19,044 file: loader.py func: loader line No: 205 First calibration picture name: calib_000.bin
2026-05-07 11:55:19,046 file: loader.py func: loader line No: 207 First calibration picture md5:
2026-05-07 11:55:19,057 file: loader.py func: loader line No: 211 *******************************************
2026-05-07 11:55:19,059 file: loader.py func: loader line No: 282 created RawImageDirLoader of shape:[1, 120, 17, 3]
2026-05-07 11:55:19,060 file: loader.py func: loader line No: 287 Read raw file: /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/calibration_data_120/calib_000.bin
2026-05-07 11:55:19,478 file: loader.py func: loader line No: 287 Read raw file: /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/calibration_data_120/calib_049.bin
2026-05-07 11:55:19,480 file: tool_utils.py func: tool_utils line No: 368 num of calibration data: 50
2026-05-07 11:55:19,481 file: tool_utils.py func: tool_utils line No: 369 calibration data shape: (1, 120, 17, 3)
2026-05-07 11:55:19,504 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 519 call build params:
2026-05-07 11:55:19,517 file: model_builder.py func: model_builder line No: 35 Start to Horizon NN Model Convert.
2026-05-07 11:55:20,138 file: model_debugger.py func: model_debugger line No: 67 Loading horizon_nn debug methods:set()
2026-05-07 11:55:20,163 file: quantization_config.py func: quantization_config line No: 305 The activation calibration parameters:
    calibration_type:     ['max', 'kl']
    max_percentile:       [0.99995, 1.0]
    per_channel:          [True, False]
    asymmetric:           [True, False]
The modelwise search parameters:
    similarity:           0.995
    metric:               cosine-similarity
The input of node /blocks_st.0/attn_s/Softmax are set to : int16
The output of node /blocks_st.0/attn_s/Softmax are set to : int16
The input of node /Reshape_3 are set to : int16
The output of node /Reshape_3 are set to : int16
There are 10 nodes designated to run on the bpu: ['/blocks_st.0/attn_s/Softmax', '/blocks_st.0/attn_t/Softmax', '/blocks_ts.0/attn_s/Softmax', '/blocks_ts.0/attn_t/Softmax', '/ts_attn.0/Add/ts_attn.0/Add_output_0_Reshape_0', '/Softmax', '/ts_attn.1/Add/ts_attn.1/Add_output_0_Reshape_0', '/Softmax_1', '/ts_attn.2/Add/ts_attn.2/Add_output_0_Reshape_0', '/Softmax_2'].
2026-05-07 11:55:20,168 file: model_builder.py func: model_builder line No: 197 The specified model compilation architecture: bayes-e.
2026-05-07 11:55:20,174 file: model_builder.py func: model_builder line No: 207 The specified model compilation optimization parameters: [].
2026-05-07 11:55:20,176 file: model_builder.py func: model_builder line No: 35 Start to prepare the onnx model.
2026-05-07 11:55:20,244 file: prepare.py func: prepare line No: 106 Input ONNX Model Information:
ONNX IR version:          6
Opset version:            ['ai.onnx v11', 'horizon v1']
Producer:                 pytorch v1.13.1
Domain:                   None
Version:                  None
Graph input:
    input:                shape=[1, 120, 17, 3], dtype=FLOAT32
Graph output:
    output:               shape=[1, 120, 17, 3], dtype=FLOAT32
2026-05-07 11:55:20,762 file: model_builder.py func: model_builder line No: 38 End to prepare the onnx model.
2026-05-07 11:55:21,539 file: model_builder.py func: model_builder line No: 265 Saving model to: motionbert_lite_original_float_model.onnx.
2026-05-07 11:55:21,541 file: model_builder.py func: model_builder line No: 35 Start to optimize the onnx model.
2026-05-07 11:55:22,499 file: constant_folding.py func: constant_folding line No: 66 Summary info for constant_folding:
2026-05-07 11:55:22,507 file: constant_folding.py func: constant_folding line No: 67   After constant_folding, the number of nodes has changed from 1423 to 1107.
2026-05-07 11:55:22,525 file: constant_folding.py func: constant_folding line No: 71   After constant_folding, the number of parameters has changed from 15970727 to 15970727.
2026-05-07 11:55:22,536 file: constant_folding.py func: constant_folding line No: 76 Detailed info for constant_folding:
2026-05-07 11:55:22,552 file: constant_folding.py func: constant_folding line No: 88
2026-05-07 11:55:25,772 file: model_builder.py func: model_builder line No: 38 End to optimize the onnx model.
2026-05-07 11:55:26,383 file: model_builder.py func: model_builder line No: 265 Saving model to: motionbert_lite_optimized_float_model.onnx.
2026-05-07 11:55:26,384 file: model_builder.py func: model_builder line No: 35 Start to calibrate the model.
2026-05-07 11:55:27,999 file: tool_utils.py func: tool_utils line No: 321 The input0 of Node(name:/blocks_st.0/attn_t/MatMul, type:MatMul) does not support data type: int16
2026-05-07 11:55:28,083 file: tool_utils.py func: tool_utils line No: 321 The input1 of Node(name:/blocks_st.0/attn_t/MatMul, type:MatMul) does not support data type: int16
2026-05-07 11:55:28,158 file: calibration_data_set.py func: calibration_data_set line No: 111 input name: input,  number_of_samples: 50
2026-05-07 11:55:28,158 file: tool_utils.py func: tool_utils line No: 321 The input0 of Node(name:/blocks_ts.0/attn_s/MatMul_1, type:MatMul) does not support data type: int16
2026-05-07 11:55:28,159 file: calibration_data_set.py func: calibration_data_set line No: 123 There are 50 samples in the data set.
2026-05-07 11:55:28,161 file: tool_utils.py func: tool_utils line No: 321 The input1 of Node(name:/blocks_ts.0/attn_s/MatMul_1, type:MatMul) does not support data type: int16
2026-05-07 11:55:28,162 file: infer_thresholds.py func: infer_thresholds line No: 84 Run calibration model with modelwise search method.
2026-05-07 11:55:28,164 file: tool_utils.py func: tool_utils line No: 321 The input1 of Node(name:/blocks_st.1/attn_s/MatMul_1, type:MatMul) does not support data type: int16
2026-05-07 11:55:32,967 file: tool_utils.py func: tool_utils line No: 321 The output of Node(name:/blocks_ts.4/attn_s/Transpose_1) is int16, then requantized to int8
2026-05-07 11:55:33,573 file: ort.py func: ort line No: 207 Reset batch_size=1 and execute forward again...
2026-05-07 12:15:59,834 file: modelwise_search.py func: modelwise_search line No: 75 Select max-percentile:percentile=0.99995 method.
2026-05-07 12:16:04,892 file: model_builder.py func: model_builder line No: 38 End to calibrate the model.
2026-05-07 12:16:06,040 file: model_builder.py func: model_builder line No: 265 Saving model to: motionbert_lite_calibrated_model.onnx.
2026-05-07 12:16:06,048 file: model_builder.py func: model_builder line No: 35 Start to quantize the model.
2026-05-07 12:16:17,617 file: tool_utils.py func: tool_utils line No: 321 the quantization parameters of conv int16 is not supported, the input datatype of node:/ts_attn.3/MatMul will be set back to int8.
2026-05-07 12:16:17,768 file: tool_utils.py func: tool_utils line No: 321 the quantization parameters of conv int16 is not supported, the input datatype of node:/ts_attn.4/MatMul will be set back to int8.
2026-05-07 12:16:21,643 file: constant_folding.py func: constant_folding line No: 66 Summary info for constant_folding:
2026-05-07 12:16:21,644 file: constant_folding.py func: constant_folding line No: 67   After constant_folding, the number of nodes has changed from 990 to 988.
2026-05-07 12:16:21,645 file: constant_folding.py func: constant_folding line No: 71   After constant_folding, the number of parameters has changed from 16012525 to 16012525.
2026-05-07 12:16:21,652 file: constant_folding.py func: constant_folding line No: 76 Detailed info for constant_folding:
2026-05-07 12:16:21,653 file: constant_folding.py func: constant_folding line No: 88   After folding node (op_name: /Add_NCHW2NHWC_LayoutConvert_Input1, op_type: Transpose), the number of increased parameters is 0.
  After folding node (op_name: /Add_1_NCHW2NHWC_LayoutConvert_Input1, op_type: Transpose), the number of increased parameters is 0.
2026-05-07 12:16:22,224 file: model_builder.py func: model_builder line No: 38 End to quantize the model.
2026-05-07 12:16:22,939 file: model_builder.py func: model_builder line No: 265 Saving model to: motionbert_lite_quantized_model.onnx.
2026-05-07 12:16:22,940 file: model_builder.py func: model_builder line No: 35 Start to compile the model with march bayes-e.
2026-05-07 12:16:26,512 file: hybrid_build.py func: hybrid_build line No: 111 Compile submodel: torch_jit_subgraph_0
2026-05-07 12:16:26,559 file: hbdk_cc.py func: hbdk_cc line No: 126 hbdk-cc parameters:['--O3', '--debug', '--core-num', '1', '--fast', '--max-time-per-fc', '1000', '--input-layout', 'NHWC', '--output-layout', 'NHWC', '--input-source', 'ddr']
2026-05-07 12:16:26,567 file: hbdk_cc.py func: hbdk_cc line No: 127 hbdk-cc command used:hbdk-cc -f hbir -m /tmp/tmpsgwwz0h7/torch_jit_subgraph_0.hbir -o /tmp/tmpsgwwz0h7/torch_jit_subgraph_0.hbm --march bayes-e --progressbar --O3 --debug --core-num 1 --fast --max-time-per-fc 1000 --input-layout NHWC --output-layout NHWC --input-source ddr
2026-05-07 12:29:16,874 file: tool_utils.py func: tool_utils line No: 326 consumed time 770.246
2026-05-07 12:29:17,628 file: tool_utils.py func: tool_utils line No: 326 FPS=9.98, latency = 100193.0 us, DDR = 496390784 bytes   (see torch_jit_subgraph_0.html)
2026-05-07 13:15:51,901 file: hybrid_build.py func: hybrid_build line No: 111 Compile submodel: torch_jit_subgraph_14
2026-05-07 13:15:51,920 file: hbdk_cc.py func: hbdk_cc line No: 126 hbdk-cc parameters:['--O3', '--debug', '--core-num', '1', '--fast', '--max-time-per-fc', '1000', '--input-layout', 'NHWC', '--output-layout', 'NHWC', '--input-source', 'ddr,ddr,ddr,ddr']
2026-05-07 13:15:51,921 file: hbdk_cc.py func: hbdk_cc line No: 127 hbdk-cc command used:hbdk-cc -f hbir -m /tmp/tmpsgwwz0h7/torch_jit_subgraph_14.hbir -o /tmp/tmpsgwwz0h7/torch_jit_subgraph_14.hbm --march bayes-e --progressbar --O3 --debug --core-num 1 --fast --max-time-per-fc 1000 --input-layout NHWC --output-layout NHWC --input-source ddr,ddr,ddr,ddr
2026-05-07 13:16:35,641 file: tool_utils.py func: tool_utils line No: 326 consumed time 43.6972
2026-05-07 13:16:35,733 file: tool_utils.py func: tool_utils line No: 326 FPS=680.02, latency = 1470.5 us, DDR = 8220608 bytes   (see torch_jit_subgraph_14.html)
2026-05-07 13:16:37,940 file: model_builder.py func: model_builder line No: 38 End to compile the model with march bayes-e.
我来帮你分析这个 MotionBERT 量化精度损失问题。先搜索社区中相关的量化案例和解决方案。
根据你的问题描述和日志分析,这是典型的 Transformer 类模型量化精度损失问题,特别是 Softmax 算子在量化后表现不佳。结合社区已有案例,给出以下解决方案:
核心结论
Softmax 是量化不友好算子,在 Transformer 架构中多层累积会导致严重精度损失。你遇到的抖动和余弦相似度低(<0.9)是典型症状。
解决方案(按优先级排序)
方案 1:Softmax 保持 FP32 计算(推荐首选)
从你的日志看到,Softmax 已被指定为 int16 计算:
修改 YAML 配置,将 Softmax 算子强制为 FP32:
  march: bayes-e
  # 添加 node_info 配置,将 Softmax 保持 FP32
  node_info:
    /blocks_st.0/attn_s/Softmax:
      ON: CPU  # 或 BPU,但保持 FP32
      InputType: float32
      OutputType: float32
    /blocks_st.0/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.0/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.0/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /Softmax_1:
      ON: CPU
      InputType: float32
      OutputType: float32
    /Softmax_2:
      ON: CPU
      InputType: float32
      OutputType: float32
参考案例:社区中 量化 ViT 时 Softmax 掉点严重 的帖子明确指出:“Softmax 本身就量化不友好,建议 FP32 计算”。
方案 2:增加校准数据量 + 优化校准策略
你目前使用 50 条校准数据,对于 MotionBERT 这种时序模型可能不足。
改进步骤
# 1. 增加校准数据到 200-500 条(覆盖更多动作场景)
# 2. 调整校准参数
  calibration_type: default  # 或尝试 'kl'
  max_percentile: 0.99995    # 当前是 0.99999,可尝试降低
  per_channel: true
校准数据要求
  • 覆盖完整动作空间(静止、快速运动、遮挡等场景)
  • 确保 2D 关键点输入分布与真实推理场景一致
  • 检查校准数据前处理是否与推理时完全对齐
方案 3:调整 int16 算子策略
从日志看到部分 MatMul 算子不支持 int16:
建议
  1. 不要强制指定过多算子为 int16,让工具链自动选择
  2. 移除 YAML 中对 Attention 相关算子的 int16 强制配置
  3. 仅对确实需要高精度的算子(如坐标回归头)使用 int16
方案 4:QAT(量化感知训练)
如果 PTQ 调优后精度仍不满足要求,考虑 QAT:
# 使用 horizon_plugin_pytorch 进行 QAT
from horizon_plugin_pytorch.quantization import prepare_qat, convert
# 1. 定义 QAT 配置
qconfig = {
    'default': {'activation': {'dtype': 'int8'}, 'weight': {'dtype': 'int8'}},
    'op_specific': {
        'Softmax': {'activation': {'dtype': 'float32'}},  # Softmax 保持 FP32
        'MatMul': {'activation': {'dtype': 'int16'}}      # 关键算子用 int16
# 2. 准备模型
model = prepare_qat(model, qconfig)
# 3. 微调训练(需要原训练数据集)
# ... 训练代码 ...
# 4. 导出 QAT 模型
model = convert(model)
torch.onnx.export(model, ...)
参考:社区有 QAT 之 qconfig 使用指南J5 算法工具链 int16 配置方式 精华帖。
快速排查清单
# 1. 验证浮点模型精度
hb_mapper --config config_float.yaml  # 不量化,验证 ONNX 精度
# 2. 分层对比量化前后输出
# 在 YAML 中开启 layer_out_dump
  layer_out_dump: true
# 3. 检查量化报告
cat motionbert_lite_model_output/motionbert_lite_quant_info.json
# 重点关注余弦相似度 < 0.95 的算子
# 4. 板端验证
# 使用 HB_ONNXRuntime 在开发机验证 quantized ONNX
# 确认精度损失发生在转换阶段还是板端部署阶段
预期效果
方案 预计提升 实施难度
Softmax 改 FP32 余弦相似度 0.9+
增加校准数据 稳定性提升
QAT 接近浮点精度 高(需训练)
建议先尝试方案 1,通常能解决 80% 的 Softmax 量化问题。如果仍有抖动,再结合方案 2 和 4。
需要进一步帮助可以补充:
  1. 当前使用的工具链版本
  2. 量化后具体精度指标(如 MPJPE 误差)
  3. 是否已在开发机验证过 quantized_model.onnx
余弦相似度Part1:
2026-05-07 13:17:03,920 file: print_info_dict.py func: print_info_dict line No: 72 The main quantized node information:
Node                                                ON   Subgraph  Type                    Cosine Similarity  Threshold  DataType
/joints_embed/MatMul                                BPU  id(0)     HzSQuantizedConv        0.999907           1.04534    int8
/Add                                                BPU  id(0)     HzSElementwiseAdd       0.999858           0.269862   int8
/Add_1                                              BPU  id(0)     HzSElementwiseAdd       0.999782           0.37162    int8
/blocks_st.0/norm1_s/ReduceMean                     BPU  id(0)     HzSQuantizedReduceMean  0.997970           0.497921   int8
/blocks_st.0/norm1_s/Sub                            BPU  id(0)     HzSElementwiseSub       0.999715           0.497921   int8
/blocks_st.0/norm1_s/Pow                            BPU  id(0)     HzLut                   0.999395           0.496986   int8
/blocks_st.0/norm1_s/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999952           0.246996   int8
/blocks_st.0/norm1_s/Div_reciprocal                 BPU  id(0)     HzLut                   0.999987           0.014549   int8
/blocks_st.0/norm1_s/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.999652           0.496986   int8
/blocks_st.0/norm1_s/Mul                            BPU  id(0)     HzSQuantizedConv        0.999556           5.30593    int8
/blocks_st.0/attn_s/q_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999645           3.46812    int8
...cks_st.0/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999643           0.892336   int8
/blocks_st.0/attn_s/Transpose                       BPU  id(0)     Transpose               0.999643           0.892336   int8
/blocks_st.0/attn_s/k_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999501           3.46812    int8
...cks_st.0/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999504           0.838327   int8
/blocks_st.0/attn_s/v_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999952           3.46812    int8
...cks_st.0/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999953           2.28054    int8
/blocks_st.0/attn_s/Transpose_1                     BPU  id(0)     Transpose               0.999953           2.28054    int8
/blocks_st.0/attn_s/Transpose_2                     BPU  id(0)     Transpose               0.999502           0.838327   int8
/blocks_st.0/attn_s/MatMul                          BPU  id(0)     HzSQuantizedMatmul      0.999357           0.892336   int8
/blocks_st.0/attn_s/Mul                             BPU  id(0)     HzSElementwiseMul       0.999354           2.16351    int8
...attn_s/Softmax_reducemax_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzQuantizedReduceMax    0.999756           0.382458   int16
..._st.0/attn_s/Softmax_sub_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSElementwiseSub       0.999550           0.382458   int16
..._st.0/attn_s/Softmax_exp_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzLut2Layer             0.999992           11.0903    int16
...attn_s/Softmax_reducesum_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSQuantizedReduceSum   0.999999           1.0        int16
...ttn_s/Softmax_reciprocal_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzLut2Layer             0.999999           16.9623    int16
..._st.0/attn_s/Softmax_mul_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSElementwiseMul       1.000002           1.0        int16
...0/attn_s/Softmax_output_0_calibrated_Requantize  BPU  id(0)     HzRequantize            --                 --         int16
/blocks_st.0/attn_s/MatMul_1                        BPU  id(0)     HzSQuantizedMatmul      0.999979           1.0        int8
/blocks_st.0/attn_s/Transpose_3                     BPU  id(0)     Transpose               0.999980           2.09693    int8
/blocks_st.0/attn_s/Reshape_3                       BPU  id(0)     Reshape                 0.999980           2.09693    int8
/blocks_st.0/attn_s/proj/MatMul                     BPU  id(0)     HzSQuantizedConv        0.999996           2.09693    int8
/blocks_st.0/norm2_s/ReduceMean                     BPU  id(0)     HzSQuantizedReduceMean  0.999718           5.06603    int8
/blocks_st.0/norm2_s/Sub                            BPU  id(0)     HzSElementwiseSub       0.999951           5.06603    int8
/blocks_st.0/norm2_s/Pow                            BPU  id(0)     HzLut                   0.999798           5.02722    int8
/blocks_st.0/norm2_s/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999969           25.273     int8
/blocks_st.0/norm2_s/Div_reciprocal                 BPU  id(0)     HzLut                   0.999968           4.21128    int8
/blocks_st.0/norm2_s/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.999919           5.02722    int8
/blocks_st.0/mlp_s/fc1/MatMul                       BPU  id(0)     HzSQuantizedConv        0.999935           2.74609    int8
/blocks_st.0/mlp_s/act/Mul_1                        BPU  id(0)     HzLut                   0.999877           4.02034    int8
/blocks_st.0/mlp_s/fc2/MatMul                       BPU  id(0)     HzSQuantizedConv        0.999983           4.02023    int8
/blocks_st.0/norm1_t/ReduceMean                     BPU  id(0)     HzSQuantizedReduceMean  0.999885           12.667     int8
/blocks_st.0/norm1_t/Sub                            BPU  id(0)     HzSElementwiseSub       0.999945           12.667     int8
/blocks_st.0/norm1_t/Pow                            BPU  id(0)     HzLut                   0.999822           12.528     int8
/blocks_st.0/norm1_t/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999966           156.951    int8
/blocks_st.0/norm1_t/Div_reciprocal                 BPU  id(0)     HzLut                   0.999988           26.4855    int8
/blocks_st.0/norm1_t/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.999940           12.528     int8
/blocks_st.0/norm1_t/Mul                            BPU  id(0)     HzSQuantizedConv        0.999928           2.47882    int8
/blocks_st.0/attn_t/q_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999955           1.46684    int8
...cks_st.0/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999960           0.624985   int8
/blocks_st.0/attn_t/k_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999965           1.46684    int8
...cks_st.0/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999962           1.17858    int8
/blocks_st.0/attn_t/v_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999991           1.46684    int8
...cks_st.0/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999991           2.05356    int8
/blocks_st.0/attn_t/Transpose_3                     BPU  id(0)     Transpose               0.999957           0.624985   int8
/blocks_st.0/attn_t/Transpose_4                     BPU  id(0)     Transpose               0.999985           2.05356    int8
/blocks_st.0/attn_t/Transpose_5                     BPU  id(0)     Transpose               0.999964           1.17858    int8
/blocks_st.0/attn_t/MatMul                          BPU  id(0)     HzSQuantizedMatmul      0.999984           0.624985   int8
/blocks_st.0/attn_t/Mul                             BPU  id(0)     HzSElementwiseMul       0.999984           3.22676    int16
...attn_t/Softmax_reducemax_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzQuantizedReduceMax    0.999990           0.570415   int16
..._st.0/attn_t/Softmax_sub_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSElementwiseSub       0.974463           0.570415   int16
..._st.0/attn_t/Softmax_exp_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzLut2Layer             0.999982           11.0903    int16
...attn_t/Softmax_reducesum_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSQuantizedReduceSum   1.000000           1.0        int16
...ttn_t/Softmax_reciprocal_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzLut2Layer             0.999999           119.599    int16
..._st.0/attn_t/Softmax_mul_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSElementwiseMul       1.000007           1.0        int16
...0/attn_t/Softmax_output_0_calibrated_Requantize  BPU  id(0)     HzRequantize            --                 --         int16
/blocks_st.0/attn_t/MatMul_1                        BPU  id(0)     HzSQuantizedMatmul      0.999997           1.0        int8
/blocks_st.0/attn_t/Transpose_6                     BPU  id(0)     Transpose               0.999999           2.03963    int16
/blocks_st.0/attn_t/Reshape_6                       BPU  id(0)     Reshape                 0.999999           2.03963    int16
/blocks_st.0/attn_t/proj/MatMul                     BPU  id(0)     HzSQuantizedConv        0.999997           2.03963    int16
/blocks_st.0/Add_2                                  BPU  id(0)     HzSElementwiseAdd       0.999963           12.667     int16
/blocks_st.0/norm2_t/ReduceMean                     BPU  id(0)     HzSQuantizedReduceMean  0.999850           15.5143    int8
/blocks_st.0/norm2_t/Sub                            BPU  id(0)     HzSElementwiseSub       0.999946           15.5143    int8
/blocks_st.0/norm2_t/Pow                            BPU  id(0)     HzLut                   0.999838           15.3245    int8
/blocks_st.0/norm2_t/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999979           234.84     int8
/blocks_st.0/norm2_t/Div_reciprocal                 BPU  id(0)     HzLut                   0.999991           45.5864    int8
/blocks_st.0/norm2_t/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.999943           15.3245    int8
/blocks_st.0/mlp_t/fc1/MatMul                       BPU  id(0)     HzSQuantizedConv        0.999939           2.31034    int8
/blocks_st.0/mlp_t/act/Mul_1                        BPU  id(0)     HzLut                   0.999805           1.71804    int8
/blocks_st.0/mlp_t/fc2/MatMul                       BPU  id(0)     HzSQuantizedConv        0.999989           1.64434    int8
...st.0/Add_3/blocks_st.0/Add_3_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999973           17.3469    int16
/blocks_ts.0/norm1_t/Pow                            BPU  id(0)     HzLut                   0.999395           0.496986   int8
/blocks_ts.0/norm1_t/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999952           0.246996   int8
/blocks_ts.0/norm1_t/Div_reciprocal                 BPU  id(0)     HzLut                   0.999987           0.014549   int8
/blocks_ts.0/norm1_t/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.999652           0.496986   int8
/blocks_ts.0/norm1_t/Mul                            BPU  id(0)     HzSQuantizedConv        0.999496           5.30593    int8
/blocks_ts.0/attn_t/q_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999834           2.87495    int8
...cks_ts.0/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999841           4.50985    int8
/blocks_ts.0/attn_t/k_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999866           2.87495    int8
...cks_ts.0/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999863           6.19321    int8
/blocks_ts.0/attn_t/v_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999752           2.87495    int8
...cks_ts.0/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999754           5.45307    int8
/blocks_ts.0/attn_t/Transpose_3                     BPU  id(0)     Transpose               0.999836           4.50985    int8
/blocks_ts.0/attn_t/Transpose_4                     BPU  id(0)     Transpose               0.999754           5.45307    int8
/blocks_ts.0/attn_t/Transpose_5                     BPU  id(0)     Transpose               0.999866           6.19321    int8
/blocks_ts.0/attn_t/MatMul                          BPU  id(0)     HzSQuantizedMatmul      0.999777           4.50985    int8
/blocks_ts.0/attn_t/Mul                             BPU  id(0)     HzSElementwiseMul       0.999770           89.3218    int8
...attn_t/Softmax_reducemax_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzQuantizedReduceMax    0.999694           15.79      int16
..._ts.0/attn_t/Softmax_sub_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSElementwiseSub       0.982076           15.79      int16
..._ts.0/attn_t/Softmax_exp_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzLut2Layer             0.996998           11.0903    int16
...attn_t/Softmax_reducesum_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSQuantizedReduceSum   0.998679           1.0        int16
...ttn_t/Softmax_reciprocal_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzLut2Layer             0.993653           57.7442    int16
..._ts.0/attn_t/Softmax_mul_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSElementwiseMul       0.995162           1.0        int16
/blocks_ts.0/attn_t/MatMul_1                        BPU  id(0)     HzSQuantizedMatmul      0.999860           1.0        int8
/blocks_ts.0/attn_t/Transpose_6                     BPU  id(0)     Transpose               0.999859           5.4259     int8
/blocks_ts.0/attn_t/Reshape_6                       BPU  id(0)     Reshape                 0.999859           5.4259     int8
/blocks_ts.0/attn_t/proj/MatMul                     BPU  id(0)     HzSQuantizedConv        0.999945           5.4259     int8
/blocks_ts.0/norm2_t/ReduceMean                     BPU  id(0)     HzSQuantizedReduceMean  0.998562           27.7693    int8
/blocks_ts.0/norm2_t/Sub                            BPU  id(0)     HzSElementwiseSub       0.999624           27.7693    int8
/blocks_ts.0/norm2_t/Pow                            BPU  id(0)     HzLut2Layer             0.999759           28.0677    int16
/blocks_ts.0/norm2_t/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999956           787.797    int16
/blocks_ts.0/norm2_t/Div_reciprocal                 BPU  id(0)     HzLut2Layer             0.999986           19.1965    int16
/blocks_ts.0/norm2_t/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.999470           28.0677    int16
/blocks_ts.0/mlp_t/fc1/MatMul                       BPU  id(0)     HzSQuantizedConv        0.999963           7.07843    int8
/blocks_ts.0/mlp_t/act/Mul_1                        BPU  id(0)     HzLut                   0.999395           9.15035    int8
/blocks_ts.0/mlp_t/fc2/MatMul                       BPU  id(0)     HzSQuantizedConv        0.999889           3.29545    int8
/blocks_ts.0/norm1_s/ReduceMean                     BPU  id(0)     HzSQuantizedReduceMean  0.997459           27.7651    int8
/blocks_ts.0/norm1_s/Sub                            BPU  id(0)     HzSElementwiseSub       0.999062           27.7651    int8
/blocks_ts.0/norm1_s/Pow                            BPU  id(0)     HzLut                   0.999335           27.9528    int8
/blocks_ts.0/norm1_s/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999828           781.36     int8
/blocks_ts.0/norm1_s/Div_reciprocal                 BPU  id(0)     HzLut                   0.999951           19.0365    int8
/blocks_ts.0/norm1_s/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.998855           27.9528    int8
/blocks_ts.0/norm1_s/Mul                            BPU  id(0)     HzSQuantizedConv        0.997771           9.18244    int8
/blocks_ts.0/attn_s/q_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999698           3.07801    int8
...cks_ts.0/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999699           5.01775    int8
/blocks_ts.0/attn_s/Transpose                       BPU  id(0)     Transpose               0.999699           5.01775    int8
/blocks_ts.0/attn_s/k_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999592           3.07801    int8
...cks_ts.0/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999592           6.38677    int8
/blocks_ts.0/attn_s/v_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999327           3.07801    int8
...cks_ts.0/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999332           6.48562    int8
/blocks_ts.0/attn_s/Transpose_1                     BPU  id(0)     Transpose               0.999332           6.48562    int8
/blocks_ts.0/attn_s/Transpose_2                     BPU  id(0)     Transpose               0.999593           6.38677    int8
/blocks_ts.0/attn_s/MatMul                          BPU  id(0)     HzSQuantizedMatmul      0.999479           5.01775    int8
/blocks_ts.0/attn_s/Mul                             BPU  id(0)     HzSElementwiseMul       0.999480           136.677    int8
...attn_s/Softmax_reducemax_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzQuantizedReduceMax    0.999471           24.1613    int16
..._ts.0/attn_s/Softmax_sub_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSElementwiseSub       0.987048           24.1613    int16
..._ts.0/attn_s/Softmax_exp_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzLut2Layer             0.992812           11.0903    int16
...attn_s/Softmax_reducesum_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSQuantizedReduceSum   0.995673           1.0        int16
...ttn_s/Softmax_reciprocal_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzLut2Layer             0.997292           11.3152    int16
..._ts.0/attn_s/Softmax_mul_FROM_QUANTIZED_SOFTMAX  BPU  id(0)     HzSElementwiseMul       0.995578           1.0        int16
/blocks_ts.0/attn_s/MatMul_1                        BPU  id(0)     HzSQuantizedMatmul      0.996438           1.0        int8
/blocks_ts.0/attn_s/Transpose_3                     BPU  id(0)     Transpose               0.996438           5.75428    int16
/blocks_ts.0/attn_s/Reshape_3                       BPU  id(0)     Reshape                 0.996438           5.75428    int16
/blocks_ts.0/attn_s/proj/MatMul                     BPU  id(0)     HzSQuantizedConv        0.996492           5.75428    int16
/blocks_ts.0/Add_2                                  BPU  id(0)     HzSElementwiseAdd       0.998636           27.7651    int8
/blocks_ts.0/norm2_s/ReduceMean                     BPU  id(0)     HzSQuantizedReduceMean  0.994303           29.7446    int16
/blocks_ts.0/norm2_s/Sub                            BPU  id(0)     HzSElementwiseSub       0.998298           29.7446    int16
/blocks_ts.0/norm2_s/Pow                            BPU  id(0)     HzLut                   0.999239           29.7548    int8
/blocks_ts.0/norm2_s/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999833           885.347    int8
/blocks_ts.0/norm2_s/Div_reciprocal                 BPU  id(0)     HzLut                   0.999954           10.5331    int8
/blocks_ts.0/norm2_s/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.998085           29.7548    int8
/blocks_ts.0/mlp_s/fc1/MatMul                       BPU  id(0)     HzSQuantizedConv        0.999263           11.3859    int8
/blocks_ts.0/mlp_s/act/Mul_1                        BPU  id(0)     HzLut2Layer             0.993073           6.1995     int16
/blocks_ts.0/mlp_s/fc2/MatMul                       BPU  id(0)     HzSQuantizedConv        0.997007           2.88       int16
/blocks_ts.0/Add_3                                  BPU  id(0)     HzSElementwiseAdd       0.998138           29.7446    int16
...ts.0/Add_3/blocks_ts.0/Add_3_output_0_Reshape_0  BPU  id(0)     Reshape                 0.998137           34.1012    int16
/blocks_st.0/Add_3_output_0_calibrated_Requantize   BPU  id(0)     HzRequantize            --                 --         int16
/blocks_ts.0/Add_3_output_0_calibrated_Requantize   BPU  id(0)     HzRequantize            --                 --         int16
/Concat                                             BPU  id(0)     Concat                  0.999791           17.3469    int16
/ts_attn.0/MatMul_reshape_input                     BPU  id(0)     Reshape                 0.999791           28.2995    int16
/ts_attn.0/MatMul                                   BPU  id(0)     HzSQuantizedConv        0.999985           28.2995    int16
/ts_attn.0/Add/ts_attn.0/Add_output_0_Reshape_0     BPU  id(0)     Reshape                 0.999985           20.1228    int16
/Softmax_reducemax_FROM_QUANTIZED_SOFTMAX           BPU  id(0)     HzQuantizedReduceMax    0.999986           20.1228    int16
/Softmax_sub_FROM_QUANTIZED_SOFTMAX                 BPU  id(0)     HzSElementwiseSub       0.999248           20.1228    int16
/Softmax_exp_FROM_QUANTIZED_SOFTMAX                 BPU  id(0)     HzLut2Layer             1.000000           11.0903    int16
/Softmax_reciprocal_FROM_QUANTIZED_SOFTMAX          BPU  id(0)     HzLut2Layer             1.000000           1.0        int16
/Softmax_mul_FROM_QUANTIZED_SOFTMAX                 BPU  id(0)     HzSElementwiseMul       1.000000           1.0        int16
/Slice                                              BPU  id(0)     Slice                   1.000000           1.0        int16
/Mul                                                BPU  id(0)     HzSElementwiseMul       1.000000           17.3469    int16
/Slice_1                                            BPU  id(0)     Slice                   1.000000           1.0        int16
/Mul_1                                              BPU  id(0)     HzSElementwiseMul       0.997611           34.1012    int16
/Add_2                                              BPU  id(0)     HzSElementwiseAdd       0.997610           0.0        int16
/blocks_st.1/norm1_s/ReduceMean                     BPU  id(0)     HzSQuantizedReduceMean  0.989789           34.1012    int16
/blocks_st.1/norm1_s/Sub                            BPU  id(0)     HzSElementwiseSub       0.997610           34.1012    int16
/blocks_st.1/norm1_s/Pow                            BPU  id(0)     HzLut2Layer             0.999023           34.1144    int16
/blocks_st.1/norm1_s/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999772           1163.79    int8
/blocks_st.1/norm1_s/Div_reciprocal                 BPU  id(0)     HzLut2Layer             0.999945           10.366     int16
/blocks_st.1/norm1_s/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.997575           34.1144    int16
/blocks_st.1/norm1_s/Mul                            BPU  id(0)     HzSElementwiseMul       0.995655           12.7367    int16
/blocks_st.1/norm1_s/Add_1                          BPU  id(0)     HzSElementwiseAdd       0.995229           4.22804    int16
/blocks_st.1/attn_s/q_linear/MatMul_reshape_input   BPU  id(0)     Reshape                 0.995229           4.21493    int16
/blocks_st.1/attn_s/q_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.998440           4.21493    int16
...cks_st.1/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.998442           4.6026     int8
/blocks_st.1/attn_s/Transpose                       BPU  id(0)     Transpose               0.998442           4.6026     int8
/blocks_st.1/attn_s/k_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.997875           4.21493    int16
...cks_st.1/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.997876           4.21625    int8
/blocks_st.1/attn_s/v_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.996713           4.21493    int16
...cks_st.1/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.996712           4.56625    int16
/blocks_st.1/attn_s/Transpose_2                     BPU  id(0)     Transpose               0.997876           4.21625    int8
/blocks_st.1/attn_s/MatMul                          BPU  id(0)     HzSQuantizedMatmul      0.997702           4.6026     int8
/blocks_st.1/attn_s/Mul                             BPU  id(0)     HzSElementwiseMul       0.997705           94.6692    int8
/blocks_st.1/attn_s/Softmax                         CPU  --        Softmax                 0.994248           18.4088    float
...tn_s/Transpose_1_output_0_calibrated_Requantize  BPU  id(0)     HzRequantize            --                 --         int16
/blocks_st.1/attn_s/MatMul_1                        BPU  id(1)     HzSQuantizedMatmul      0.980428           0.993412   int8
/blocks_st.1/attn_s/Transpose_3                     BPU  id(1)     Transpose               0.980428           2.87552    int16
/blocks_st.1/attn_s/Reshape_3                       BPU  id(1)     Reshape                 0.980428           2.87552    int16
/blocks_st.1/attn_s/proj/MatMul                     BPU  id(1)     HzSQuantizedConv        0.980798           2.87552    int16
.../blocks_st.1/attn_s/proj/Add_output_0_Reshape_0  BPU  id(1)     Reshape                 0.980799           5.74052    int16
/blocks_st.1/Add                                    BPU  id(1)     HzSElementwiseAdd       0.996432           34.1012    int16
/blocks_st.1/norm2_s/ReduceMean                     BPU  id(1)     HzSQuantizedReduceMean  0.988433           34.2874    int16
/blocks_st.1/norm2_s/Sub                            BPU  id(1)     HzSElementwiseSub       0.996435           34.2874    int16
/blocks_st.1/norm2_s/Pow                            BPU  id(1)     HzLut2Layer             0.998697           34.2849    int16
/blocks_st.1/norm2_s/ReduceMean_1                   BPU  id(1)     HzSQuantizedReduceMean  0.999596           1175.45    int8
/blocks_st.1/norm2_s/Div_reciprocal                 BPU  id(1)     HzLut2Layer             0.999918           10.3922    int16
/blocks_st.1/norm2_s/Div_mul                        BPU  id(1)     HzSElementwiseMul       0.996390           34.2849    int16
/blocks_st.1/mlp_s/fc1/MatMul_reshape_input         BPU  id(1)     Reshape                 0.996390           12.8971    int16
/blocks_st.1/mlp_s/fc1/MatMul                       BPU  id(1)     HzSQuantizedConv        0.997988           12.8971    int16
/blocks_st.1/mlp_s/act/Mul_1                        BPU  id(1)     HzLut2Layer             0.983094           5.31713    int16
/blocks_st.1/mlp_s/fc2/MatMul                       BPU  id(1)     HzSQuantizedConv        0.984745           2.33557    int16
...dd/blocks_st.1/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(1)     Reshape                 0.984745           2.77527    int16
/blocks_st.1/Add_1                                  BPU  id(1)     HzSElementwiseAdd       0.995902           34.2874    int16
/blocks_st.1/norm1_t/ReduceMean                     BPU  id(1)     HzSQuantizedReduceMean  0.988217           34.3696    int16
/blocks_st.1/norm1_t/Sub                            BPU  id(1)     HzSElementwiseSub       0.995905           34.3696    int16
/blocks_st.1/norm1_t/Pow                            BPU  id(1)     HzLut2Layer             0.998646           34.3518    int16
/blocks_st.1/norm1_t/ReduceMean_1                   BPU  id(1)     HzSQuantizedReduceMean  0.999455           1180.05    int8
/blocks_st.1/norm1_t/Div_reciprocal                 BPU  id(1)     HzLut2Layer             0.999892           11.2835    int16
/blocks_st.1/norm1_t/Div_mul                        BPU  id(1)     HzSElementwiseMul       0.995864           34.3518    int16
/blocks_st.1/norm1_t/Mul                            BPU  id(1)     HzSElementwiseMul       0.993439           12.8693    int16
/blocks_st.1/norm1_t/Add_1                          BPU  id(1)     HzSElementwiseAdd       0.992779           5.88774    int16
/blocks_st.1/attn_t/q_linear/MatMul_reshape_input   BPU  id(1)     Reshape                 0.992779           5.89253    int16
/blocks_st.1/attn_t/q_linear/MatMul                 BPU  id(1)     HzSQuantizedConv        0.997469           5.89253    int16
...cks_st.1/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(1)     Reshape                 0.997470           5.05108    int16
/blocks_st.1/attn_t/k_linear/MatMul                 BPU  id(1)     HzSQuantizedConv        0.996105           5.89253    int16
...cks_st.1/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(1)     Reshape                 0.996104           4.59191    int16
/blocks_st.1/attn_t/v_linear/MatMul                 BPU  id(1)     HzSQuantizedConv        0.985740           5.89253    int16
...cks_st.1/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(1)     Reshape                 0.985740           2.54813    int16
/blocks_st.1/attn_t/Transpose_3                     BPU  id(1)     Transpose               0.997469           5.05108    int16
/blocks_st.1/attn_t/Transpose_4                     BPU  id(1)     Transpose               0.985740           2.54813    int16
/blocks_st.1/attn_t/Transpose_5                     BPU  id(1)     Transpose               0.996105           4.59191    int16
...tn_t/Transpose_3_output_0_calibrated_Requantize  BPU  id(1)     HzRequantize            --                 --         int16
...tn_t/Transpose_5_output_0_calibrated_Requantize  BPU  id(1)     HzRequantize            --                 --         int16
/blocks_st.1/attn_t/MatMul                          BPU  id(1)     HzSQuantizedMatmul      0.998738           5.05108    int8
/blocks_st.1/attn_t/Mul                             BPU  id(1)     HzSElementwiseMul       0.998727           131.658    int8
/blocks_st.1/attn_t/Softmax                         CPU  --        Softmax                 0.961618           25.6015    float
...tn_t/Transpose_4_output_0_calibrated_Requantize  BPU  id(1)     HzRequantize            --                 --         int16
/blocks_st.1/attn_t/MatMul_1                        BPU  id(3)     HzSQuantizedMatmul      0.989581           0.396495   int8
/blocks_st.1/attn_t/Transpose_6                     BPU  id(3)     Transpose               0.989582           2.4066     int16
/blocks_st.1/attn_t/Reshape_6                       BPU  id(3)     Reshape                 0.989582           2.4066     int16
/blocks_st.1/attn_t/proj/MatMul                     BPU  id(3)     HzSQuantizedConv        0.993405           2.4066     int16
.../blocks_st.1/attn_t/proj/Add_output_0_Reshape_0  BPU  id(3)     Reshape                 0.993404           5.42267    int16
/blocks_st.1/Add_2                                  BPU  id(3)     HzSElementwiseAdd       0.995681           34.3696    int16
/blocks_st.1/norm2_t/ReduceMean                     BPU  id(3)     HzSQuantizedReduceMean  0.980681           34.4782    int16
/blocks_st.1/norm2_t/Sub                            BPU  id(3)     HzSElementwiseSub       0.995686           34.4782    int16
/blocks_st.1/norm2_t/Pow                            BPU  id(3)     HzLut2Layer             0.998652           34.4164    int16
/blocks_st.1/norm2_t/ReduceMean_1                   BPU  id(3)     HzSQuantizedReduceMean  0.999298           1184.49    int8
/blocks_st.1/norm2_t/Div_reciprocal                 BPU  id(3)     HzLut2Layer             0.999868           9.77819    int16
/blocks_st.1/norm2_t/Div_mul                        BPU  id(3)     HzSElementwiseMul       0.995640           34.4164    int16
/blocks_st.1/mlp_t/fc1/MatMul_reshape_input         BPU  id(3)     Reshape                 0.995640           13.0623    int16
/blocks_st.1/mlp_t/fc1/MatMul                       BPU  id(3)     HzSQuantizedConv        0.996580           13.0623    int16
/blocks_st.1/mlp_t/act/Mul_1                        BPU  id(3)     HzLut2Layer             0.974790           5.22338    int16
/blocks_st.1/mlp_t/fc2/MatMul                       BPU  id(3)     HzSQuantizedConv        0.974455           2.12832    int16
...dd/blocks_st.1/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(3)     Reshape                 0.974456           2.84474    int16
/blocks_st.1/Add_3                                  BPU  id(3)     HzSElementwiseAdd       0.994324           34.4782    int16
/blocks_ts.1/norm1_t/Pow                            BPU  id(0)     HzLut2Layer             0.999023           34.1144    int16
/blocks_ts.1/norm1_t/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999772           1163.79    int8
/blocks_ts.1/norm1_t/Div_reciprocal                 BPU  id(0)     HzLut2Layer             0.999945           10.366     int16
/blocks_ts.1/norm1_t/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.997575           34.1144    int16
/blocks_ts.1/norm1_t/Mul                            BPU  id(0)     HzSElementwiseMul       0.992624           12.7367    int16
/blocks_ts.1/norm1_t/Add_1                          BPU  id(0)     HzSElementwiseAdd       0.990840           2.24713    int16
/blocks_ts.1/attn_t/q_linear/MatMul_reshape_input   BPU  id(0)     Reshape                 0.990840           2.19987    int16
/blocks_ts.1/attn_t/q_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.998772           2.19987    int16
...cks_ts.1/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.998775           4.49259    int8
/blocks_ts.1/attn_t/k_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.992625           2.19987    int16
...cks_ts.1/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.992626           3.84948    int16
/blocks_ts.1/attn_t/v_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.981918           2.19987    int16
...cks_ts.1/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.981918           1.66263    int16
/blocks_ts.1/attn_t/Transpose_3                     BPU  id(0)     Transpose               0.998775           4.49259    int8
/blocks_ts.1/attn_t/Transpose_4                     BPU  id(0)     Transpose               0.981917           1.66263    int16
/blocks_ts.1/attn_t/Transpose_5                     BPU  id(0)     Transpose               0.992624           3.84948    int16
...tn_t/Transpose_5_output_0_calibrated_Requantize  BPU  id(0)     HzRequantize            --                 --         int16
/blocks_ts.1/attn_t/MatMul                          BPU  id(0)     HzSQuantizedMatmul      0.991293           4.49259    int8
/blocks_ts.1/attn_t/Mul                             BPU  id(0)     HzSElementwiseMul       0.991294           205.061    int16
/blocks_ts.1/attn_t/Softmax                         CPU  --        Softmax                 0.927612           39.8751    float
...tn_t/Transpose_4_output_0_calibrated_Requantize  BPU  id(0)     HzRequantize            --                 --         int16
/blocks_ts.1/attn_t/MatMul_1                        BPU  id(2)     HzSQuantizedMatmul      0.975467           0.749935   int8
/blocks_ts.1/attn_t/Transpose_6                     BPU  id(2)     Transpose               0.975468           1.50974    int16
/blocks_ts.1/attn_t/Reshape_6                       BPU  id(2)     Reshape                 0.975468           1.50974    int16
/blocks_ts.1/attn_t/proj/MatMul                     BPU  id(2)     HzSQuantizedConv        0.980328           1.50974    int16
.../blocks_ts.1/attn_t/proj/Add_output_0_Reshape_0  BPU  id(2)     Reshape                 0.980328           3.57198    int16
/blocks_ts.1/Add                                    BPU  id(2)     HzSElementwiseAdd       0.997329           34.1012    int16
/blocks_ts.1/norm2_t/ReduceMean                     BPU  id(2)     HzSQuantizedReduceMean  0.990481           34.1078    int16
/blocks_ts.1/norm2_t/Sub                            BPU  id(2)     HzSElementwiseSub       0.997332           34.1078    int16
/blocks_ts.1/norm2_t/Pow                            BPU  id(2)     HzLut2Layer             0.999024           34.1047    int16
/blocks_ts.1/norm2_t/ReduceMean_1                   BPU  id(2)     HzSQuantizedReduceMean  0.999758           1163.13    int8
/blocks_ts.1/norm2_t/Div_reciprocal                 BPU  id(2)     HzLut2Layer             0.999920           10.3497    int16
/blocks_ts.1/norm2_t/Div_mul                        BPU  id(2)     HzSElementwiseMul       0.997276           34.1047    int16
/blocks_ts.1/mlp_t/fc1/MatMul_reshape_input         BPU  id(2)     Reshape                 0.997276           12.7469    int16
/blocks_ts.1/mlp_t/fc1/MatMul                       BPU  id(2)     HzSQuantizedConv        0.997964           12.7469    int16
/blocks_ts.1/mlp_t/act/Mul_1                        BPU  id(2)     HzLut2Layer             0.982482           5.60403    int16
/blocks_ts.1/mlp_t/fc2/MatMul                       BPU  id(2)     HzSQuantizedConv        0.990319           2.92492    int16
...dd/blocks_ts.1/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(2)     Reshape                 0.990318           3.73434    int16
/blocks_ts.1/Add_1                                  BPU  id(2)     HzSElementwiseAdd       0.996965           34.1078    int16
/blocks_ts.1/norm1_s/ReduceMean                     BPU  id(2)     HzSQuantizedReduceMean  0.989302           34.1345    int16
/blocks_ts.1/norm1_s/Sub                            BPU  id(2)     HzSElementwiseSub       0.996971           34.1345    int16
/blocks_ts.1/norm1_s/Pow                            BPU  id(2)     HzLut2Layer             0.999046           34.1097    int16
/blocks_ts.1/norm1_s/ReduceMean_1                   BPU  id(2)     HzSQuantizedReduceMean  0.999748           1163.47    int8
/blocks_ts.1/norm1_s/Div_reciprocal                 BPU  id(2)     HzLut2Layer             0.999927           11.123     int16
/blocks_ts.1/norm1_s/Div_mul                        BPU  id(2)     HzSElementwiseMul       0.996927           34.1097    int16
/blocks_ts.1/norm1_s/Mul                            BPU  id(2)     HzSElementwiseMul       0.993371           12.569     int16
/blocks_ts.1/norm1_s/Add_1                          BPU  id(2)     HzSElementwiseAdd       0.992536           5.51876    int16
/blocks_ts.1/attn_s/q_linear/MatMul_reshape_input   BPU  id(2)     Reshape                 0.992536           5.45528    int16
/blocks_ts.1/attn_s/q_linear/MatMul                 BPU  id(2)     HzSQuantizedConv        0.996828           5.45528    int16
...cks_ts.1/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(2)     Reshape                 0.996827           4.48945    int8
/blocks_ts.1/attn_s/Transpose                       BPU  id(2)     Transpose               0.996827           4.48945    int8
/blocks_ts.1/attn_s/k_linear/MatMul                 BPU  id(2)     HzSQuantizedConv        0.995840           5.45528    int16
...cks_ts.1/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(2)     Reshape                 0.995840           4.60515    int16
/blocks_ts.1/attn_s/v_linear/MatMul                 BPU  id(2)     HzSQuantizedConv        0.993957           5.45528    int16
...cks_ts.1/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(2)     Reshape                 0.993956           4.11752    int16
...tn_s/Transpose_2_output_0_calibrated_Requantize  BPU  id(2)     HzRequantize            --                 --         int16
/blocks_ts.1/attn_s/MatMul                          BPU  id(2)     HzSQuantizedMatmul      0.996176           4.48945    int8
/blocks_ts.1/attn_s/Mul                             BPU  id(2)     HzSElementwiseMul       0.996176           98.0349    int16
/blocks_ts.1/attn_s/Softmax                         CPU  --        Softmax                 0.993245           19.0633    float
...tn_s/Transpose_1_output_0_calibrated_Requantize  BPU  id(2)     HzRequantize            --                 --         int16
/blocks_ts.1/attn_s/MatMul_1                        BPU  id(3)     HzSQuantizedMatmul      0.975762           0.997101   int8
/blocks_ts.1/attn_s/Transpose_3                     BPU  id(3)     Transpose               0.975762           3.14133    int16
/blocks_ts.1/attn_s/Reshape_3                       BPU  id(3)     Reshape                 0.975762           3.14133    int16
/blocks_ts.1/attn_s/proj/MatMul                     BPU  id(3)     HzSQuantizedConv        0.976462           3.14133    int16
.../blocks_ts.1/attn_s/proj/Add_output_0_Reshape_0  BPU  id(3)     Reshape                 0.976462           5.53955    int16
/blocks_ts.1/Add_2                                  BPU  id(3)     HzSElementwiseAdd       0.995415           34.1345    int16
/blocks_ts.1/norm2_s/ReduceMean                     BPU  id(3)     HzSQuantizedReduceMean  0.990465           34.2543    int16
/blocks_ts.1/norm2_s/Sub                            BPU  id(3)     HzSElementwiseSub       0.995418           34.2543    int16
/blocks_ts.1/norm2_s/Pow                            BPU  id(3)     HzLut2Layer             0.998648           34.2075    int16
/blocks_ts.1/norm2_s/ReduceMean_1                   BPU  id(3)     HzSQuantizedReduceMean  0.999457           1170.16    int8
/blocks_ts.1/norm2_s/Div_reciprocal                 BPU  id(3)     HzLut2Layer             0.999902           11.8936    int16
/blocks_ts.1/norm2_s/Div_mul                        BPU  id(3)     HzSElementwiseMul       0.995386           34.2075    int16
/blocks_ts.1/mlp_s/fc1/MatMul_reshape_input         BPU  id(3)     Reshape                 0.995386           12.5507    int16
/blocks_ts.1/mlp_s/fc1/MatMul                       BPU  id(3)     HzSQuantizedConv        0.994238           12.5507    int16
/blocks_ts.1/mlp_s/act/Mul_1                        BPU  id(3)     HzLut2Layer             0.973270           6.42202    int16
/blocks_ts.1/mlp_s/fc2/MatMul                       BPU  id(3)     HzSQuantizedConv        0.976088           3.0277     int16
...dd/blocks_ts.1/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(3)     Reshape                 0.976089           3.81109    int16
/blocks_ts.1/Add_3                                  BPU  id(3)     HzSElementwiseAdd       0.993539           34.2543    int16
/blocks_st.1/Add_3_output_0_calibrated_Requantize   BPU  id(3)     HzRequantize            --                 --         int16
/blocks_ts.1/Add_3_output_0_calibrated_Requantize   BPU  id(3)     HzRequantize            --                 --         int16
/Concat_1                                           BPU  id(3)     Concat                  0.993918           34.4475    int16
/ts_attn.1/MatMul_reshape_input                     BPU  id(3)     Reshape                 0.993918           34.4127    int16
/ts_attn.1/MatMul                                   BPU  id(3)     HzSQuantizedConv        0.998315           34.4127    int16
/ts_attn.1/Add/ts_attn.1/Add_output_0_Reshape_0     BPU  id(3)     Reshape                 0.998315           2.67168    int16
/Softmax_1_reducemax_FROM_QUANTIZED_SOFTMAX         BPU  id(3)     HzQuantizedReduceMax    0.999062           2.67168    int16
/Softmax_1_sub_FROM_QUANTIZED_SOFTMAX               BPU  id(3)     HzSElementwiseSub       0.997476           2.67168    int16
/Softmax_1_exp_FROM_QUANTIZED_SOFTMAX               BPU  id(3)     HzLut2Layer             0.999395           11.0903    int16
/Softmax_1_reducesum_FROM_QUANTIZED_SOFTMAX         BPU  id(3)     HzSQuantizedReduceSum   0.999697           1.0        int16
/Softmax_1_reciprocal_FROM_QUANTIZED_SOFTMAX        BPU  id(3)     HzLut2Layer             0.999785           1.99982    int16
/Softmax_1_mul_FROM_QUANTIZED_SOFTMAX               BPU  id(3)     HzSElementwiseMul       0.999661           1.0        int16
/Slice_2                                            BPU  id(3)     Slice                   0.999745           0.991322   int16
/Mul_2                                              BPU  id(3)     HzSElementwiseMul       0.994129           34.4475    int16
/Slice_3                                            BPU  id(3)     Slice                   0.999525           0.991322   int16
/Mul_3                                              BPU  id(3)     HzSElementwiseMul       0.992686           34.3497    int16
/Add_3                                              BPU  id(3)     HzSElementwiseAdd       0.995166           31.4844    int16
/blocks_st.2/norm1_s/ReduceMean                     BPU  id(3)     HzSQuantizedReduceMean  0.985122           34.428     int16
/blocks_st.2/norm1_s/Sub                            BPU  id(3)     HzSElementwiseSub       0.995171           34.428     int16
/blocks_st.2/norm1_s/Pow                            BPU  id(3)     HzLut2Layer             0.998716           34.334     int16
/blocks_st.2/norm1_s/ReduceMean_1                   BPU  id(3)     HzSQuantizedReduceMean  0.999429           1178.82    int8
/blocks_st.2/norm1_s/Div_reciprocal                 BPU  id(3)     HzLut2Layer             0.999895           9.82323    int16
/blocks_st.2/norm1_s/Div_mul                        BPU  id(3)     HzSElementwiseMul       0.995136           34.334     int16
/blocks_st.2/norm1_s/Mul                            BPU  id(3)     HzSElementwiseMul       0.990744           13.0925    int16
/blocks_st.2/norm1_s/Add_1                          BPU  id(3)     HzSElementwiseAdd       0.990070           7.27168    int16
/blocks_st.2/attn_s/q_linear/MatMul_reshape_input   BPU  id(3)     Reshape                 0.990070           7.22077    int16
/blocks_st.2/attn_s/q_linear/MatMul                 BPU  id(3)     HzSQuantizedConv        0.996619           7.22077    int16
...cks_st.2/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(3)     Reshape                 0.996619           4.6685     int16
/blocks_st.2/attn_s/k_linear/MatMul                 BPU  id(3)     HzSQuantizedConv        0.994619           7.22077    int16
...cks_st.2/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(3)     Reshape                 0.994619           4.60512    int16
/blocks_st.2/attn_s/v_linear/MatMul                 BPU  id(3)     HzSQuantizedConv        0.991407           7.22077    int16
...cks_st.2/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(3)     Reshape                 0.991406           4.19918    int16
...attn_s/Transpose_output_0_calibrated_Requantize  BPU  id(3)     HzRequantize            --                 --         int16
...tn_s/Transpose_2_output_0_calibrated_Requantize  BPU  id(3)     HzRequantize            --                 --         int16
/blocks_st.2/attn_s/MatMul                          BPU  id(3)     HzSQuantizedMatmul      0.994741           4.6685     int8
/blocks_st.2/attn_s/Mul                             BPU  id(3)     HzSElementwiseMul       0.994741           62.5756    int16
/blocks_st.2/attn_s/Softmax                         CPU  --        Softmax                 0.994184           12.1681    float
...tn_s/Transpose_1_output_0_calibrated_Requantize  BPU  id(3)     HzRequantize            --                 --         int16
/blocks_st.2/attn_s/MatMul_1                        BPU  id(4)     HzSQuantizedMatmul      0.973563           0.995631   int8
/blocks_st.2/attn_s/Transpose_3                     BPU  id(4)     Transpose               0.973563           3.52822    int16
/blocks_st.2/attn_s/Reshape_3                       BPU  id(4)     Reshape                 0.973563           3.52822    int16
/blocks_st.2/attn_s/proj/MatMul                     BPU  id(4)     HzSQuantizedConv        0.976395           3.52822    int16
.../blocks_st.2/attn_s/proj/Add_output_0_Reshape_0  BPU  id(4)     Reshape                 0.976395           4.70203    int16
/blocks_st.2/Add                                    BPU  id(4)     HzSElementwiseAdd       0.993797           34.428     int16
/blocks_st.2/norm2_s/ReduceMean                     BPU  id(4)     HzSQuantizedReduceMean  0.984028           34.4504    int16
/blocks_st.2/norm2_s/Sub                            BPU  id(4)     HzSElementwiseSub       0.993801           34.4504    int16
/blocks_st.2/norm2_s/Pow                            BPU  id(4)     HzLut2Layer             0.998421           34.3717    int16
/blocks_st.2/norm2_s/ReduceMean_1                   BPU  id(4)     HzSQuantizedReduceMean  0.999189           1181.41    int8
/blocks_st.2/norm2_s/Div_reciprocal                 BPU  id(4)     HzLut2Layer             0.999827           10.4082    int16
/blocks_st.2/norm2_s/Div_mul                        BPU  id(4)     HzSElementwiseMul       0.993707           34.3717    int16
/blocks_st.2/mlp_s/fc1/MatMul_reshape_input         BPU  id(4)     Reshape                 0.993707           12.9819    int16
/blocks_st.2/mlp_s/fc1/MatMul                       BPU  id(4)     HzSQuantizedConv        0.993967           12.9819    int16
/blocks_st.2/mlp_s/act/Mul_1                        BPU  id(4)     HzLut2Layer             0.967785           6.3369     int16
/blocks_st.2/mlp_s/fc2/MatMul                       BPU  id(4)     HzSQuantizedConv        0.968684           3.42935    int16
...dd/blocks_st.2/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(4)     Reshape                 0.968684           5.48906    int16
/blocks_st.2/Add_1                                  BPU  id(4)     HzSElementwiseAdd       0.992566           34.4504    int16
/blocks_st.2/norm1_t/ReduceMean                     BPU  id(4)     HzSQuantizedReduceMean  0.979584           34.4441    int16
/blocks_st.2/norm1_t/Sub                            BPU  id(4)     HzSElementwiseSub       0.992568           34.4441    int16
/blocks_st.2/norm1_t/Pow                            BPU  id(4)     HzLut2Layer             0.998222           34.3273    int16
/blocks_st.2/norm1_t/ReduceMean_1                   BPU  id(4)     HzSQuantizedReduceMean  0.999215           1178.36    int8
/blocks_st.2/norm1_t/Div_reciprocal                 BPU  id(4)     HzLut2Layer             0.999824           12.484     int16
/blocks_st.2/norm1_t/Div_mul                        BPU  id(4)     HzSElementwiseMul       0.992362           34.3273    int16
/blocks_st.2/norm1_t/Mul                            BPU  id(4)     HzSElementwiseMul       0.983840           13.0558    int16
/blocks_st.2/norm1_t/Add_1                          BPU  id(4)     HzSElementwiseAdd       0.982847           3.29553    int16
/blocks_st.2/attn_t/q_linear/MatMul_reshape_input   BPU  id(4)     Reshape                 0.982847           3.03116    int16
/blocks_st.2/attn_t/q_linear/MatMul                 BPU  id(4)     HzSQuantizedConv        0.991906           3.03116    int16
...cks_st.2/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(4)     Reshape                 0.991907           4.33446    int16
/blocks_st.2/attn_t/k_linear/MatMul                 BPU  id(4)     HzSQuantizedConv        0.983889           3.03116    int16
...cks_st.2/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(4)     Reshape                 0.983889           4.28053    int16
/blocks_st.2/attn_t/v_linear/MatMul                 BPU  id(4)     HzSQuantizedConv        0.969661           3.03116    int16
...cks_st.2/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(4)     Reshape                 0.969662           2.21512    int16
/blocks_st.2/attn_t/Transpose_3                     BPU  id(4)     Transpose               0.991906           4.33446    int16
/blocks_st.2/attn_t/Transpose_4                     BPU  id(4)     Transpose               0.969661           2.21512    int16
/blocks_st.2/attn_t/Transpose_5                     BPU  id(4)     Transpose               0.983889           4.28053    int16
...tn_t/Transpose_3_output_0_calibrated_Requantize  BPU  id(4)     HzRequantize            --                 --         int16
...tn_t/Transpose_5_output_0_calibrated_Requantize  BPU  id(4)     HzRequantize            --                 --         int16
/blocks_st.2/attn_t/MatMul                          BPU  id(4)     HzSQuantizedMatmul      0.985767           4.33446    int8
/blocks_st.2/attn_t/Mul                             BPU  id(4)     HzSElementwiseMul       0.985767           101.316    int16
/blocks_st.2/attn_t/Softmax                         CPU  --        Softmax                 0.920934           19.7014    float
...tn_t/Transpose_4_output_0_calibrated_Requantize  BPU  id(4)     HzRequantize            --                 --         int16
/blocks_st.2/attn_t/MatMul_1                        BPU  id(6)     HzSQuantizedMatmul      0.972252           0.492234   int8
/blocks_st.2/attn_t/Transpose_6                     BPU  id(6)     Transpose               0.972253           1.91532    int16
/blocks_st.2/attn_t/Reshape_6                       BPU  id(6)     Reshape                 0.972253           1.91532    int16
/blocks_st.2/attn_t/proj/MatMul                     BPU  id(6)     HzSQuantizedConv        0.969222           1.91532    int16
.../blocks_st.2/attn_t/proj/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.969223           4.06978    int16
/blocks_st.2/Add_2                                  BPU  id(6)     HzSElementwiseAdd       0.992006           34.4441    int16
/blocks_st.2/norm2_t/ReduceMean                     BPU  id(6)     HzSQuantizedReduceMean  0.979713           34.4763    int16
/blocks_st.2/norm2_t/Sub                            BPU  id(6)     HzSElementwiseSub       0.992010           34.4763    int16
/blocks_st.2/norm2_t/Pow                            BPU  id(6)     HzLut2Layer             0.998242           34.3566    int16
/blocks_st.2/norm2_t/ReduceMean_1                   BPU  id(6)     HzSQuantizedReduceMean  0.999248           1180.37    int8
/blocks_st.2/norm2_t/Div_reciprocal                 BPU  id(6)     HzLut2Layer             0.999825           11.0553    int16
/blocks_st.2/norm2_t/Div_mul                        BPU  id(6)     HzSElementwiseMul       0.991855           34.3566    int16
/blocks_st.2/mlp_t/fc1/MatMul_reshape_input         BPU  id(6)     Reshape                 0.991855           13.1506    int16
/blocks_st.2/mlp_t/fc1/MatMul                       BPU  id(6)     HzSQuantizedConv        0.990193           13.1506    int16
variable_2569_Requantize                            BPU  id(6)     HzRequantize            --                 --         int16
/blocks_st.2/mlp_t/act/Mul_1                        BPU  id(6)     HzLut2Layer             0.954998           6.21287    int16
/blocks_st.2/mlp_t/fc2/MatMul                       BPU  id(6)     HzSQuantizedConv        0.953976           3.35643    int16
...dd/blocks_st.2/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.953977           5.02322    int16
/blocks_st.2/Add_3                                  BPU  id(6)     HzSElementwiseAdd       0.990480           34.4763    int16
/blocks_ts.2/norm1_t/Pow                            BPU  id(3)     HzLut2Layer             0.998716           34.334     int16
/blocks_ts.2/norm1_t/ReduceMean_1                   BPU  id(3)     HzSQuantizedReduceMean  0.999429           1178.82    int8
/blocks_ts.2/norm1_t/Div_reciprocal                 BPU  id(3)     HzLut2Layer             0.999895           9.82323    int16
/blocks_ts.2/norm1_t/Div_mul                        BPU  id(3)     HzSElementwiseMul       0.995136           34.334     int16
/blocks_ts.2/norm1_t/Mul                            BPU  id(3)     HzSElementwiseMul       0.991575           13.0925    int16
/blocks_ts.2/norm1_t/Add_1                          BPU  id(3)     HzSElementwiseAdd       0.990976           6.49592    int16
/blocks_ts.2/attn_t/q_linear/MatMul_reshape_input   BPU  id(3)     Reshape                 0.990976           6.48442    int16
/blocks_ts.2/attn_t/q_linear/MatMul                 BPU  id(3)     HzSQuantizedConv        0.994873           6.48442    int16
...cks_ts.2/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(3)     Reshape                 0.994873           4.98615    int16
/blocks_ts.2/attn_t/k_linear/MatMul                 BPU  id(3)     HzSQuantizedConv        0.993180           6.48442    int16
...cks_ts.2/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(3)     Reshape                 0.993179           4.77879    int16
/blocks_ts.2/attn_t/v_linear/MatMul                 BPU  id(3)     HzSQuantizedConv        0.967400           6.48442    int16
...cks_ts.2/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(3)     Reshape                 0.967402           2.40943    int16
/blocks_ts.2/attn_t/Transpose_3                     BPU  id(3)     Transpose               0.994873           4.98615    int16
/blocks_ts.2/attn_t/Transpose_4                     BPU  id(3)     Transpose               0.967401           2.40943    int16
/blocks_ts.2/attn_t/Transpose_5                     BPU  id(3)     Transpose               0.993180           4.77879    int16
...tn_t/Transpose_3_output_0_calibrated_Requantize  BPU  id(3)     HzRequantize            --                 --         int16
...tn_t/Transpose_5_output_0_calibrated_Requantize  BPU  id(3)     HzRequantize            --                 --         int16
/blocks_ts.2/attn_t/MatMul                          BPU  id(3)     HzSQuantizedMatmul      0.994248           4.98615    int8
/blocks_ts.2/attn_t/Mul                             BPU  id(3)     HzSElementwiseMul       0.994248           124.806    int16
/blocks_ts.2/attn_t/Softmax                         CPU  --        Softmax                 0.930808           24.269     float
...tn_t/Transpose_4_output_0_calibrated_Requantize  BPU  id(3)     HzRequantize            --                 --         int16
/blocks_ts.2/attn_t/MatMul_1                        BPU  id(5)     HzSQuantizedMatmul      0.968644           0.581744   int8
/blocks_ts.2/attn_t/Transpose_6                     BPU  id(5)     Transpose               0.968644           1.99688    int16
/blocks_ts.2/attn_t/Reshape_6                       BPU  id(5)     Reshape                 0.968644           1.99688    int16
/blocks_ts.2/attn_t/proj/MatMul                     BPU  id(5)     HzSQuantizedConv        0.964977           1.99688    int16
.../blocks_ts.2/attn_t/proj/Add_output_0_Reshape_0  BPU  id(5)     Reshape                 0.964976           3.68667    int16
/blocks_ts.2/Add                                    BPU  id(5)     HzSElementwiseAdd       0.994524           34.428     int16
/blocks_ts.2/norm2_t/ReduceMean                     BPU  id(5)     HzSQuantizedReduceMean  0.978422           34.4415    int16
/blocks_ts.2/norm2_t/Sub                            BPU  id(5)     HzSElementwiseSub       0.994529           34.4415    int16
/blocks_ts.2/norm2_t/Pow                            BPU  id(5)     HzLut2Layer             0.998559           34.3419    int16
/blocks_ts.2/norm2_t/ReduceMean_1                   BPU  id(5)     HzSQuantizedReduceMean  0.999370           1179.36    int8
/blocks_ts.2/norm2_t/Div_reciprocal                 BPU  id(5)     HzLut2Layer             0.999869           10.2401    int16
/blocks_ts.2/norm2_t/Div_mul                        BPU  id(5)     HzSElementwiseMul       0.994480           34.3419    int16
/blocks_ts.2/mlp_t/fc1/MatMul_reshape_input         BPU  id(5)     Reshape                 0.994480           13.0545    int16
/blocks_ts.2/mlp_t/fc1/MatMul                       BPU  id(5)     HzSQuantizedConv        0.994112           13.0545    int16
/blocks_ts.2/mlp_t/act/Mul_1                        BPU  id(5)     HzLut2Layer             0.961905           5.79273    int16
/blocks_ts.2/mlp_t/fc2/MatMul                       BPU  id(5)     HzSQuantizedConv        0.964115           2.73106    int16
...dd/blocks_ts.2/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(5)     Reshape                 0.964115           3.38518    int16
/blocks_ts.2/Add_1                                  BPU  id(5)     HzSElementwiseAdd       0.993536           34.4415    int16
/blocks_ts.2/norm1_s/ReduceMean                     BPU  id(5)     HzSQuantizedReduceMean  0.979013           34.2674    int16
/blocks_ts.2/norm1_s/Sub                            BPU  id(5)     HzSElementwiseSub       0.993541           34.2674    int16
/blocks_ts.2/norm1_s/Pow                            BPU  id(5)     HzLut2Layer             0.998471           34.1776    int16
/blocks_ts.2/norm1_s/ReduceMean_1                   BPU  id(5)     HzSQuantizedReduceMean  0.999386           1168.11    int8
/blocks_ts.2/norm1_s/Div_reciprocal                 BPU  id(5)     HzLut2Layer             0.999872           10.2396    int16
/blocks_ts.2/norm1_s/Div_mul                        BPU  id(5)     HzSElementwiseMul       0.993472           34.1776    int16
/blocks_ts.2/norm1_s/Mul                            BPU  id(5)     HzSElementwiseMul       0.987843           12.8955    int16
/blocks_ts.2/norm1_s/Add_1                          BPU  id(5)     HzSElementwiseAdd       0.987067           6.36175    int16
/blocks_ts.2/attn_s/q_linear/MatMul_reshape_input   BPU  id(5)     Reshape                 0.987067           6.24382    int16
/blocks_ts.2/attn_s/q_linear/MatMul                 BPU  id(5)     HzSQuantizedConv        0.994764           6.24382    int16
...cks_ts.2/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(5)     Reshape                 0.994764           4.61991    int16
/blocks_ts.2/attn_s/k_linear/MatMul                 BPU  id(5)     HzSQuantizedConv        0.994217           6.24382    int16
...cks_ts.2/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(5)     Reshape                 0.994216           5.1095     int16
/blocks_ts.2/attn_s/v_linear/MatMul                 BPU  id(5)     HzSQuantizedConv        0.987265           6.24382    int16
...cks_ts.2/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(5)     Reshape                 0.987267           4.35011    int16
...attn_s/Transpose_output_0_calibrated_Requantize  BPU  id(5)     HzRequantize            --                 --         int16
...tn_s/Transpose_2_output_0_calibrated_Requantize  BPU  id(5)     HzRequantize            --                 --         int16
/blocks_ts.2/attn_s/MatMul                          BPU  id(5)     HzSQuantizedMatmul      0.994940           4.61991    int8
/blocks_ts.2/attn_s/Mul                             BPU  id(5)     HzSElementwiseMul       0.994940           124.825    int16
/blocks_ts.2/attn_s/Softmax                         CPU  --        Softmax                 0.985381           24.2728    float
...tn_s/Transpose_1_output_0_calibrated_Requantize  BPU  id(5)     HzRequantize            --                 --         int16
/blocks_ts.2/attn_s/MatMul_1                        BPU  id(6)     HzSQuantizedMatmul      0.971887           0.999724   int8
/blocks_ts.2/attn_s/Transpose_3                     BPU  id(6)     Transpose               0.971887           3.51414    int16
/blocks_ts.2/attn_s/Reshape_3                       BPU  id(6)     Reshape                 0.971887           3.51414    int16
/blocks_ts.2/attn_s/proj/MatMul                     BPU  id(6)     HzSQuantizedConv        0.973991           3.51414    int16
.../blocks_ts.2/attn_s/proj/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.973992           5.0915     int16
/blocks_ts.2/Add_2                                  BPU  id(6)     HzSElementwiseAdd       0.991640           34.2674    int16
/blocks_ts.2/norm2_s/ReduceMean                     BPU  id(6)     HzSQuantizedReduceMean  0.970380           34.2915    int16
/blocks_ts.2/norm2_s/Sub                            BPU  id(6)     HzSElementwiseSub       0.991643           34.2915    int16
/blocks_ts.2/norm2_s/Pow                            BPU  id(6)     HzLut2Layer             0.998052           34.1908    int16
/blocks_ts.2/norm2_s/ReduceMean_1                   BPU  id(6)     HzSQuantizedReduceMean  0.999253           1169.01    int8
/blocks_ts.2/norm2_s/Div_reciprocal                 BPU  id(6)     HzLut2Layer             0.999832           10.9545    int16
/blocks_ts.2/norm2_s/Div_mul                        BPU  id(6)     HzSElementwiseMul       0.991554           34.1908    int16
/blocks_ts.2/mlp_s/fc1/MatMul_reshape_input         BPU  id(6)     Reshape                 0.991554           12.6485    int16
/blocks_ts.2/mlp_s/fc1/MatMul                       BPU  id(6)     HzSQuantizedConv        0.992878           12.6485    int16
/blocks_ts.2/mlp_s/act/Mul_1                        BPU  id(6)     HzLut2Layer             0.963732           6.34081    int16
/blocks_ts.2/mlp_s/fc2/MatMul                       BPU  id(6)     HzSQuantizedConv        0.969647           3.19171    int16
...dd/blocks_ts.2/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.969647           5.00815    int16
/blocks_ts.2/Add_3                                  BPU  id(6)     HzSElementwiseAdd       0.990296           34.2915    int16
/blocks_st.2/Add_3_output_0_calibrated_Requantize   BPU  id(6)     HzRequantize            --                 --         int16
/blocks_ts.2/Add_3_output_0_calibrated_Requantize   BPU  id(6)     HzRequantize            --                 --         int16
/Concat_2                                           BPU  id(6)     Concat                  0.990387           34.5156    int16
/ts_attn.2/MatMul_reshape_input                     BPU  id(6)     Reshape                 0.990387           34.4111    int16
/ts_attn.2/MatMul                                   BPU  id(6)     HzSQuantizedConv        0.997322           34.4111    int16
/ts_attn.2/Add/ts_attn.2/Add_output_0_Reshape_0     BPU  id(6)     Reshape                 0.997322           3.25079    int16
/Softmax_2_reducemax_FROM_QUANTIZED_SOFTMAX         BPU  id(6)     HzQuantizedReduceMax    0.998450           3.25079    int16
/Softmax_2_sub_FROM_QUANTIZED_SOFTMAX               BPU  id(6)     HzSElementwiseSub       0.996572           3.25079    int16
/Softmax_2_exp_FROM_QUANTIZED_SOFTMAX               BPU  id(6)     HzLut2Layer             0.998917           11.0903    int16
/Softmax_2_reducesum_FROM_QUANTIZED_SOFTMAX         BPU  id(6)     HzSQuantizedReduceSum   0.999412           1.0        int16
/Softmax_2_reciprocal_FROM_QUANTIZED_SOFTMAX        BPU  id(6)     HzLut2Layer             0.999620           2.0        int16
/Softmax_2_mul_FROM_QUANTIZED_SOFTMAX               BPU  id(6)     HzSElementwiseMul       0.999351           1.0        int16
/Slice_4                                            BPU  id(6)     Slice                   0.999502           0.967237   int16
/Mul_4                                              BPU  id(6)     HzSElementwiseMul       0.989360           34.5156    int16
/Slice_5                                            BPU  id(6)     Slice                   0.999268           0.967237   int16
/Mul_5                                              BPU  id(6)     HzSElementwiseMul       0.989532           34.2697    int16
/Add_4                                              BPU  id(6)     HzSElementwiseAdd       0.991711           31.0626    int16
根据你提供的量化信息日志,我找到了核心问题所在
:magnifying_glass_tilted_left: 关键问题分析
1. Softmax 精度损失严重(即使已跑在 CPU 上)
Softmax 节点 余弦相似度 数据类型 问题
/blocks_st.0/attn_t/Softmax_sub 0.974 int16 量化路径
/blocks_st.1/attn_t/Softmax 0.961 float CPU 但输入已量化
/blocks_ts.1/attn_t/Softmax 0.927 float :cross_mark: 严重损失
/blocks_st.2/attn_t/Softmax 0.920 float :cross_mark: 严重损失
/blocks_ts.2/attn_t/Softmax 0.930 float :cross_mark: 严重损失
2. 误差累积效应明显
blocks_st.0: 大部分算子 0.999+  ✅
blocks_st.1: 开始下降到 0.98-0.99  ⚠️
blocks_st.2: 部分算子跌破 0.96  ❌
  - /blocks_st.2/mlp_t/fc2/MatMul: 0.953976
  - /blocks_st.2/mlp_t/act/Mul_1: 0.954998
:hammer_and_wrench: 针对性解决方案
方案 A:完全绕过量化 Softmax(推荐优先尝试)
虽然日志显示 Softmax 已在 CPU 上运行,但输入数据经过了 requantize,导致精度损失。需要彻底隔离:
# config.yaml
  march: bayes-e
  # 关键:将所有 Softmax 相关节点强制 FP32 且不走 BPU
  node_info:
    # blocks_st.0 层
      ON: CPU
      InputType: float32
      OutputType: float32
      ON: CPU
      InputType: float32
      OutputType: float32
    # blocks_st.1 层
    /blocks_st.1/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.1/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    # blocks_st.2 层
    /blocks_st.2/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.2/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    # blocks_ts 层同理
      ON: CPU
      InputType: float32
      OutputType: float32
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.1/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.2/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    # 顶层 Softmax
    /Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /Softmax_1:
      ON: CPU
      InputType: float32
      OutputType: float32
    /Softmax_2:
      ON: CPU
      InputType: float32
      OutputType: float32
  max_percentile: 0.99995  # 从 0.99999 降低,减少异常值影响
  per_channel: true
方案 B:增加校准数据 + 分层校准
50 条校准数据对时序模型明显不足
# 1. 准备 200-500 条校准数据(覆盖不同动作场景)
# 2. 确保数据分布与真实推理场景一致
# 3. 修改校准策略
  cal_data_dir: ./calibration_data_500  # 增加数据量
  calibration_type: kl  # 尝试 KL 散度方法
  per_channel: true
方案 C:关键层保持 int16,其他用 int8
从日志看,后期层的 MatMul 精度下降明显,可以针对性保护:
# 仅对坐标回归头和最后几层使用 int16
  node_info:
    # 最后几层保持 int16
    /blocks_st.2/attn_t/proj/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_ts.2/attn_t/proj/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    # 输出头保持 int16
    /Concat:
      ON: BPU
      InputType: int16
      OutputType: int16
    /Concat_1:
      ON: BPU
      InputType: int16
      OutputType: int16
    /Concat_2:
      ON: BPU
      InputType: int16
      OutputType: int16
:clipboard: 快速验证步骤
# 1. 先验证浮点模型精度(基准)
# 2. 应用方案 A 后重新量化
hb_mapper --config config_softmax_fp32.yaml
# 3. 分层对比输出
# 开启 layer_out_dump 对比各层输出
# 4. 在开发机验证 quantized ONNX
python3 -c "
import onnxruntime as ort
# 加载量化模型
session = ort.InferenceSession('motionbert_lite_quantized_model.onnx')
# 对比输入输出...
# 5. 查看量化报告
cat motionbert_lite_model_output/motionbert_lite_quant_info.json | grep -A2 "Softmax"
:bar_chart: 预期效果
方案 预计 Softmax 相似度 实施难度 优先级
方案 A(Softmax 完全 FP32) 0.99+ :star::star::star:
方案 B(增加校准数据) 0.97-0.99 :star::star:
方案 C(关键层 int16) 0.96-0.98 :star::star:
QAT(量化感知训练) 0.99+ :star:(最后手段)
:red_question_mark: 需要补充的信息
如果上述方案仍无法解决,请提供:
  1. 具体精度指标:MPJPE 误差从多少降到多少?
  2. 工具链版本hbdk version 3.49.15 是较新版本,确认是否有更新
  3. 抖动表现:是时间序列上的抖动还是单帧精度下降?
  4. 是否已验证quantized_model.onnx 在开发机的精度 vs 板端 .bin 精度
建议先执行方案 A,通常能解决 70% 以上的 Transformer 量化精度问题。如果仍有问题,再考虑 QAT 方案。
余弦相似度Part2:
/blocks_st.3/norm1_s/ReduceMean                     BPU  id(6)     HzSQuantizedReduceMean  0.975907           34.4717    int16
/blocks_st.3/norm1_s/Sub                            BPU  id(6)     HzSElementwiseSub       0.991714           34.4717    int16
/blocks_st.3/norm1_s/Pow                            BPU  id(6)     HzLut2Layer             0.998350           34.3459    int16
/blocks_st.3/norm1_s/ReduceMean_1                   BPU  id(6)     HzSQuantizedReduceMean  0.999348           1179.64    int8
/blocks_st.3/norm1_s/Div_reciprocal                 BPU  id(6)     HzLut2Layer             0.999864           10.5989    int16
/blocks_st.3/norm1_s/Div_mul                        BPU  id(6)     HzSElementwiseMul       0.991618           34.3459    int16
/blocks_st.3/norm1_s/Mul                            BPU  id(6)     HzSElementwiseMul       0.986287           13.1644    int16
/blocks_st.3/norm1_s/Add_1                          BPU  id(6)     HzSElementwiseAdd       0.985616           8.26771    int16
/blocks_st.3/attn_s/q_linear/MatMul_reshape_input   BPU  id(6)     Reshape                 0.985616           8.20993    int16
/blocks_st.3/attn_s/q_linear/MatMul                 BPU  id(6)     HzSQuantizedConv        0.993633           8.20993    int16
...cks_st.3/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.993633           4.48911    int16
/blocks_st.3/attn_s/k_linear/MatMul                 BPU  id(6)     HzSQuantizedConv        0.992168           8.20993    int16
...cks_st.3/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.992167           5.70474    int16
/blocks_st.3/attn_s/v_linear/MatMul                 BPU  id(6)     HzSQuantizedConv        0.981992           8.20993    int16
...cks_st.3/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.981993           4.22247    int16
...attn_s/Transpose_output_0_calibrated_Requantize  BPU  id(6)     HzRequantize            --                 --         int16
...tn_s/Transpose_2_output_0_calibrated_Requantize  BPU  id(6)     HzRequantize            --                 --         int16
/blocks_st.3/attn_s/MatMul                          BPU  id(6)     HzSQuantizedMatmul      0.993648           4.48911    int8
/blocks_st.3/attn_s/Mul                             BPU  id(6)     HzSElementwiseMul       0.993648           96.617     int16
/blocks_st.3/attn_s/Softmax                         CPU  --        Softmax                 0.986769           18.7876    float
...tn_s/Transpose_1_output_0_calibrated_Requantize  BPU  id(6)     HzRequantize            --                 --         int16
/blocks_st.3/attn_s/MatMul_1                        BPU  id(7)     HzSQuantizedMatmul      0.962585           0.988206   int8
/blocks_st.3/attn_s/Transpose_3                     BPU  id(7)     Transpose               0.962584           3.01828    int16
/blocks_st.3/attn_s/Reshape_3                       BPU  id(7)     Reshape                 0.962584           3.01828    int16
/blocks_st.3/attn_s/proj/MatMul                     BPU  id(7)     HzSQuantizedConv        0.969185           3.01828    int16
.../blocks_st.3/attn_s/proj/Add_output_0_Reshape_0  BPU  id(7)     Reshape                 0.969185           4.72354    int16
/blocks_st.3/Add                                    BPU  id(7)     HzSElementwiseAdd       0.990184           34.4717    int16
/blocks_st.3/norm2_s/ReduceMean                     BPU  id(7)     HzSQuantizedReduceMean  0.977547           34.4963    int16
/blocks_st.3/norm2_s/Sub                            BPU  id(7)     HzSElementwiseSub       0.990188           34.4963    int16
/blocks_st.3/norm2_s/Pow                            BPU  id(7)     HzLut2Layer             0.998056           34.3788    int16
/blocks_st.3/norm2_s/ReduceMean_1                   BPU  id(7)     HzSQuantizedReduceMean  0.999218           1181.9     int8
/blocks_st.3/norm2_s/Div_reciprocal                 BPU  id(7)     HzLut2Layer             0.999821           12.3266    int16
/blocks_st.3/norm2_s/Div_mul                        BPU  id(7)     HzSElementwiseMul       0.989919           34.3788    int16
/blocks_st.3/mlp_s/fc1/MatMul_reshape_input         BPU  id(7)     Reshape                 0.989919           13.1187    int16
/blocks_st.3/mlp_s/fc1/MatMul                       BPU  id(7)     HzSQuantizedConv        0.989563           13.1187    int16
/blocks_st.3/mlp_s/act/Mul_1                        BPU  id(7)     HzLut2Layer             0.954577           6.02802    int16
/blocks_st.3/mlp_s/fc2/MatMul                       BPU  id(7)     HzSQuantizedConv        0.956246           3.43642    int16
...dd/blocks_st.3/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(7)     Reshape                 0.956246           6.09295    int16
/blocks_st.3/Add_1                                  BPU  id(7)     HzSElementwiseAdd       0.987126           34.4963    int16
/blocks_st.3/norm1_t/ReduceMean                     BPU  id(7)     HzSQuantizedReduceMean  0.972939           34.4509    int16
/blocks_st.3/norm1_t/Sub                            BPU  id(7)     HzSElementwiseSub       0.987130           34.4509    int16
/blocks_st.3/norm1_t/Pow                            BPU  id(7)     HzLut2Layer             0.997795           34.3204    int16
/blocks_st.3/norm1_t/ReduceMean_1                   BPU  id(7)     HzSQuantizedReduceMean  0.999176           1177.89    int8
/blocks_st.3/norm1_t/Div_reciprocal                 BPU  id(7)     HzLut2Layer             0.999802           13.9396    int16
/blocks_st.3/norm1_t/Div_mul                        BPU  id(7)     HzSElementwiseMul       0.986841           34.3204    int16
/blocks_st.3/norm1_t/Mul                            BPU  id(7)     HzSElementwiseMul       0.977741           12.8744    int16
/blocks_st.3/norm1_t/Add_1                          BPU  id(7)     HzSElementwiseAdd       0.976974           5.58479    int16
/blocks_st.3/attn_t/q_linear/MatMul_reshape_input   BPU  id(7)     Reshape                 0.976974           5.53403    int16
/blocks_st.3/attn_t/q_linear/MatMul                 BPU  id(7)     HzSQuantizedConv        0.982574           5.53403    int16
...cks_st.3/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(7)     Reshape                 0.982574           5.74567    int16
/blocks_st.3/attn_t/k_linear/MatMul                 BPU  id(7)     HzSQuantizedConv        0.983041           5.53403    int16
...cks_st.3/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(7)     Reshape                 0.983041           5.47457    int16
/blocks_st.3/attn_t/v_linear/MatMul                 BPU  id(7)     HzSQuantizedConv        0.939688           5.53403    int16
...cks_st.3/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(7)     Reshape                 0.939688           3.1467     int16
/blocks_st.3/attn_t/Transpose_3                     BPU  id(7)     Transpose               0.982574           5.74567    int16
/blocks_st.3/attn_t/Transpose_4                     BPU  id(7)     Transpose               0.939688           3.1467     int16
/blocks_st.3/attn_t/Transpose_5                     BPU  id(7)     Transpose               0.983041           5.47457    int16
...tn_t/Transpose_3_output_0_calibrated_Requantize  BPU  id(7)     HzRequantize            --                 --         int16
...tn_t/Transpose_5_output_0_calibrated_Requantize  BPU  id(7)     HzRequantize            --                 --         int16
/blocks_st.3/attn_t/MatMul                          BPU  id(7)     HzSQuantizedMatmul      0.992118           5.74567    int8
/blocks_st.3/attn_t/Mul                             BPU  id(7)     HzSElementwiseMul       0.992118           142.11     int16
/blocks_st.3/attn_t/Softmax                         CPU  --        Softmax                 0.882698           27.6339    float
...tn_t/Transpose_4_output_0_calibrated_Requantize  BPU  id(7)     HzRequantize            --                 --         int16
/blocks_st.3/attn_t/MatMul_1                        BPU  id(9)     HzSQuantizedMatmul      0.954870           0.410473   int8
/blocks_st.3/attn_t/Transpose_6                     BPU  id(9)     Transpose               0.954871           2.9177     int16
/blocks_st.3/attn_t/Reshape_6                       BPU  id(9)     Reshape                 0.954871           2.9177     int16
/blocks_st.3/attn_t/proj/MatMul                     BPU  id(9)     HzSQuantizedConv        0.955101           2.9177     int16
.../blocks_st.3/attn_t/proj/Add_output_0_Reshape_0  BPU  id(9)     Reshape                 0.955101           5.46119    int16
/blocks_st.3/Add_2                                  BPU  id(9)     HzSElementwiseAdd       0.985984           34.4509    int16
/blocks_st.3/norm2_t/ReduceMean                     BPU  id(9)     HzSQuantizedReduceMean  0.975372           34.4814    int16
/blocks_st.3/norm2_t/Sub                            BPU  id(9)     HzSElementwiseSub       0.985987           34.4814    int16
/blocks_st.3/norm2_t/Pow                            BPU  id(9)     HzLut2Layer             0.997885           34.3343    int16
/blocks_st.3/norm2_t/ReduceMean_1                   BPU  id(9)     HzSQuantizedReduceMean  0.999266           1178.84    int8
/blocks_st.3/norm2_t/Div_reciprocal                 BPU  id(9)     HzLut2Layer             0.999821           12.7656    int16
/blocks_st.3/norm2_t/Div_mul                        BPU  id(9)     HzSElementwiseMul       0.985671           34.3343    int16
/blocks_st.3/mlp_t/fc1/MatMul_reshape_input         BPU  id(9)     Reshape                 0.985671           12.9692    int16
/blocks_st.3/mlp_t/fc1/MatMul                       BPU  id(9)     HzSQuantizedConv        0.979855           12.9692    int16
/blocks_st.3/mlp_t/act/Mul_1                        BPU  id(9)     HzLut2Layer             0.907779           5.53115    int16
/blocks_st.3/mlp_t/fc2/MatMul                       BPU  id(9)     HzSQuantizedConv        0.903864           2.96054    int16
...dd/blocks_st.3/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(9)     Reshape                 0.903864           4.54376    int16
/blocks_st.3/Add_3                                  BPU  id(9)     HzSElementwiseAdd       0.983261           34.4814    int16
/blocks_ts.3/norm1_t/Pow                            BPU  id(6)     HzLut2Layer             0.998350           34.3459    int16
/blocks_ts.3/norm1_t/ReduceMean_1                   BPU  id(6)     HzSQuantizedReduceMean  0.999348           1179.64    int8
/blocks_ts.3/norm1_t/Div_reciprocal                 BPU  id(6)     HzLut2Layer             0.999864           10.5989    int16
/blocks_ts.3/norm1_t/Div_mul                        BPU  id(6)     HzSElementwiseMul       0.991618           34.3459    int16
/blocks_ts.3/norm1_t/Mul                            BPU  id(6)     HzSElementwiseMul       0.981575           13.1644    int16
/blocks_ts.3/norm1_t/Add_1                          BPU  id(6)     HzSElementwiseAdd       0.980696           3.80758    int16
/blocks_ts.3/attn_t/q_linear/MatMul_reshape_input   BPU  id(6)     Reshape                 0.980696           3.74397    int16
/blocks_ts.3/attn_t/q_linear/MatMul                 BPU  id(6)     HzSQuantizedConv        0.991648           3.74397    int16
...cks_ts.3/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.991649           5.13368    int16
/blocks_ts.3/attn_t/k_linear/MatMul                 BPU  id(6)     HzSQuantizedConv        0.979968           3.74397    int16
...cks_ts.3/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.979968           4.20606    int16
/blocks_ts.3/attn_t/v_linear/MatMul                 BPU  id(6)     HzSQuantizedConv        0.948536           3.74397    int16
...cks_ts.3/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.948537           1.92768    int16
/blocks_ts.3/attn_t/Transpose_3                     BPU  id(6)     Transpose               0.991649           5.13368    int16
/blocks_ts.3/attn_t/Transpose_4                     BPU  id(6)     Transpose               0.948536           1.92768    int16
/blocks_ts.3/attn_t/Transpose_5                     BPU  id(6)     Transpose               0.979968           4.20606    int16
...tn_t/Transpose_3_output_0_calibrated_Requantize  BPU  id(6)     HzRequantize            --                 --         int16
...tn_t/Transpose_5_output_0_calibrated_Requantize  BPU  id(6)     HzRequantize            --                 --         int16
/blocks_ts.3/attn_t/MatMul                          BPU  id(6)     HzSQuantizedMatmul      0.982539           5.13368    int8
/blocks_ts.3/attn_t/Mul                             BPU  id(6)     HzSElementwiseMul       0.982539           95.2591    int16
/blocks_ts.3/attn_t/Softmax                         CPU  --        Softmax                 0.890938           18.5235    float
...tn_t/Transpose_4_output_0_calibrated_Requantize  BPU  id(6)     HzRequantize            --                 --         int16
/blocks_ts.3/attn_t/MatMul_1                        BPU  id(8)     HzSQuantizedMatmul      0.954770           0.49009    int8
/blocks_ts.3/attn_t/Transpose_6                     BPU  id(8)     Transpose               0.954769           1.66865    int16
/blocks_ts.3/attn_t/Reshape_6                       BPU  id(8)     Reshape                 0.954769           1.66865    int16
/blocks_ts.3/attn_t/proj/MatMul                     BPU  id(8)     HzSQuantizedConv        0.946176           1.66865    int16
.../blocks_ts.3/attn_t/proj/Add_output_0_Reshape_0  BPU  id(8)     Reshape                 0.946176           2.68311    int16
/blocks_ts.3/Add                                    BPU  id(8)     HzSElementwiseAdd       0.991210           34.4717    int16
/blocks_ts.3/norm2_t/ReduceMean                     BPU  id(8)     HzSQuantizedReduceMean  0.975858           34.499     int16
/blocks_ts.3/norm2_t/Sub                            BPU  id(8)     HzSElementwiseSub       0.991211           34.499     int16
/blocks_ts.3/norm2_t/Pow                            BPU  id(8)     HzLut2Layer             0.998299           34.3659    int16
/blocks_ts.3/norm2_t/ReduceMean_1                   BPU  id(8)     HzSQuantizedReduceMean  0.999343           1181.02    int8
/blocks_ts.3/norm2_t/Div_reciprocal                 BPU  id(8)     HzLut2Layer             0.999865           11.0782    int16
/blocks_ts.3/norm2_t/Div_mul                        BPU  id(8)     HzSElementwiseMul       0.991103           34.3659    int16
/blocks_ts.3/mlp_t/fc1/MatMul_reshape_input         BPU  id(8)     Reshape                 0.991103           13.1824    int16
/blocks_ts.3/mlp_t/fc1/MatMul                       BPU  id(8)     HzSQuantizedConv        0.991406           13.1824    int16
/blocks_ts.3/mlp_t/act/Mul_1                        BPU  id(8)     HzLut2Layer             0.951319           5.5826     int16
/blocks_ts.3/mlp_t/fc2/MatMul                       BPU  id(8)     HzSQuantizedConv        0.954051           2.75089    int16
...dd/blocks_ts.3/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(8)     Reshape                 0.954052           4.71572    int16
/blocks_ts.3/Add_1                                  BPU  id(8)     HzSElementwiseAdd       0.990398           34.499     int16
/blocks_ts.3/norm1_s/ReduceMean                     BPU  id(8)     HzSQuantizedReduceMean  0.973494           34.4204    int16
/blocks_ts.3/norm1_s/Sub                            BPU  id(8)     HzSElementwiseSub       0.990401           34.4204    int16
/blocks_ts.3/norm1_s/Pow                            BPU  id(8)     HzLut2Layer             0.998229           34.3022    int16
/blocks_ts.3/norm1_s/ReduceMean_1                   BPU  id(8)     HzSQuantizedReduceMean  0.999371           1176.64    int8
/blocks_ts.3/norm1_s/Div_reciprocal                 BPU  id(8)     HzLut2Layer             0.999856           12.014     int16
/blocks_ts.3/norm1_s/Div_mul                        BPU  id(8)     HzSElementwiseMul       0.990266           34.3022    int16
/blocks_ts.3/norm1_s/Mul                            BPU  id(8)     HzSElementwiseMul       0.982850           13.1183    int16
/blocks_ts.3/norm1_s/Add_1                          BPU  id(8)     HzSElementwiseAdd       0.982191           6.66249    int16
/blocks_ts.3/attn_s/q_linear/MatMul_reshape_input   BPU  id(8)     Reshape                 0.982191           6.63736    int16
/blocks_ts.3/attn_s/q_linear/MatMul                 BPU  id(8)     HzSQuantizedConv        0.990858           6.63736    int16
...cks_ts.3/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(8)     Reshape                 0.990857           4.9937     int16
/blocks_ts.3/attn_s/k_linear/MatMul                 BPU  id(8)     HzSQuantizedConv        0.988684           6.63736    int16
...cks_ts.3/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(8)     Reshape                 0.988684           4.75502    int16
/blocks_ts.3/attn_s/v_linear/MatMul                 BPU  id(8)     HzSQuantizedConv        0.980990           6.63736    int16
...cks_ts.3/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(8)     Reshape                 0.980991           4.71636    int16
...attn_s/Transpose_output_0_calibrated_Requantize  BPU  id(8)     HzRequantize            --                 --         int16
...tn_s/Transpose_2_output_0_calibrated_Requantize  BPU  id(8)     HzRequantize            --                 --         int16
/blocks_ts.3/attn_s/MatMul                          BPU  id(8)     HzSQuantizedMatmul      0.989200           4.9937     int8
/blocks_ts.3/attn_s/Mul                             BPU  id(8)     HzSElementwiseMul       0.989200           84.8712    int16
/blocks_ts.3/attn_s/Softmax                         CPU  --        Softmax                 0.985912           16.5036    float
...tn_s/Transpose_1_output_0_calibrated_Requantize  BPU  id(8)     HzRequantize            --                 --         int16
/blocks_ts.3/attn_s/MatMul_1                        BPU  id(9)     HzSQuantizedMatmul      0.964014           0.998304   int8
/blocks_ts.3/attn_s/Transpose_3                     BPU  id(9)     Transpose               0.964014           3.81192    int16
/blocks_ts.3/attn_s/Reshape_3                       BPU  id(9)     Reshape                 0.964014           3.81192    int16
/blocks_ts.3/attn_s/proj/MatMul                     BPU  id(9)     HzSQuantizedConv        0.969816           3.81192    int16
.../blocks_ts.3/attn_s/proj/Add_output_0_Reshape_0  BPU  id(9)     Reshape                 0.969816           5.44356    int16
/blocks_ts.3/Add_2                                  BPU  id(9)     HzSElementwiseAdd       0.988706           34.4204    int16
/blocks_ts.3/norm2_s/ReduceMean                     BPU  id(9)     HzSQuantizedReduceMean  0.970235           34.4721    int16
/blocks_ts.3/norm2_s/Sub                            BPU  id(9)     HzSElementwiseSub       0.988710           34.4721    int16
/blocks_ts.3/norm2_s/Pow                            BPU  id(9)     HzLut2Layer             0.998007           34.3521    int16
/blocks_ts.3/norm2_s/ReduceMean_1                   BPU  id(9)     HzSQuantizedReduceMean  0.999384           1180.07    int8
/blocks_ts.3/norm2_s/Div_reciprocal                 BPU  id(9)     HzLut2Layer             0.999859           12.0928    int16
/blocks_ts.3/norm2_s/Div_mul                        BPU  id(9)     HzSElementwiseMul       0.988435           34.3521    int16
/blocks_ts.3/mlp_s/fc1/MatMul_reshape_input         BPU  id(9)     Reshape                 0.988435           12.9064    int16
/blocks_ts.3/mlp_s/fc1/MatMul                       BPU  id(9)     HzSQuantizedConv        0.990180           12.9064    int16
/blocks_ts.3/mlp_s/act/Mul_1                        BPU  id(9)     HzLut2Layer             0.946370           6.45857    int16
/blocks_ts.3/mlp_s/fc2/MatMul                       BPU  id(9)     HzSQuantizedConv        0.953579           3.21159    int16
...dd/blocks_ts.3/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(9)     Reshape                 0.953580           5.60383    int16
/blocks_ts.3/Add_3                                  BPU  id(9)     HzSElementwiseAdd       0.987025           34.4721    int16
/blocks_st.3/Add_3_output_0_calibrated_Requantize   BPU  id(9)     HzRequantize            --                 --         int16
/blocks_ts.3/Add_3_output_0_calibrated_Requantize   BPU  id(9)     HzRequantize            --                 --         int16
/Concat_3                                           BPU  id(9)     Concat                  0.985181           34.5075    int16
/ts_attn.3/MatMul_reshape_input                     BPU  id(9)     Reshape                 0.985181           34.4836    int16
...0_reshape_in_transpose_in_calibrated_Requantize  BPU  id(9)     HzRequantize            --                 --         int16
/ts_attn.3/MatMul                                   BPU  id(9)     HzSQuantizedConv        0.993991           34.4836    int8
/ts_attn.3/Add/ts_attn.3/Add_output_0_Reshape_0     CPU  --        Reshape                 0.993991           --         float
/Softmax_3                                          CPU  --        Softmax                 0.999095           --         float
/Slice_6                                            BPU  id(10)    Slice                   0.999382           --         int16
/Mul_6                                              BPU  id(10)    HzSElementwiseMul       0.982915           34.5075    int16
/Slice_7                                            BPU  id(10)    Slice                   0.998821           --         int16
/Mul_7                                              BPU  id(10)    HzSElementwiseMul       0.985799           34.4571    int16
/Add_5                                              BPU  id(10)    HzSElementwiseAdd       0.987879           25.9291    int16
/blocks_st.4/norm1_s/ReduceMean                     BPU  id(10)    HzSQuantizedReduceMean  0.971237           34.4984    int16
/blocks_st.4/norm1_s/Sub                            BPU  id(10)    HzSElementwiseSub       0.987881           34.4984    int16
/blocks_st.4/norm1_s/Pow                            BPU  id(10)    HzLut2Layer             0.998312           34.3595    int16
/blocks_st.4/norm1_s/ReduceMean_1                   BPU  id(10)    HzSQuantizedReduceMean  0.999358           1180.57    int8
/blocks_st.4/norm1_s/Div_reciprocal                 BPU  id(10)    HzLut2Layer             0.999853           12.1186    int16
/blocks_st.4/norm1_s/Div_mul                        BPU  id(10)    HzSElementwiseMul       0.987609           34.3595    int16
/blocks_st.4/norm1_s/Mul                            BPU  id(10)    HzSElementwiseMul       0.979006           13.1528    int16
/blocks_st.4/norm1_s/Add_1                          BPU  id(10)    HzSElementwiseAdd       0.978256           6.384      int16
/blocks_st.4/attn_s/q_linear/MatMul_reshape_input   BPU  id(10)    Reshape                 0.978256           6.37724    int16
/blocks_st.4/attn_s/q_linear/MatMul                 BPU  id(10)    HzSQuantizedConv        0.988986           6.37724    int16
...cks_st.4/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(10)    Reshape                 0.988986           4.97312    int16
/blocks_st.4/attn_s/k_linear/MatMul                 BPU  id(10)    HzSQuantizedConv        0.985424           6.37724    int16
...cks_st.4/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(10)    Reshape                 0.985424           4.7223     int16
/blocks_st.4/attn_s/v_linear/MatMul                 BPU  id(10)    HzSQuantizedConv        0.975110           6.37724    int16
...cks_st.4/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(10)    Reshape                 0.975111           4.01532    int16
...attn_s/Transpose_output_0_calibrated_Requantize  BPU  id(10)    HzRequantize            --                 --         int16
...tn_s/Transpose_2_output_0_calibrated_Requantize  BPU  id(10)    HzRequantize            --                 --         int16
/blocks_st.4/attn_s/MatMul                          BPU  id(10)    HzSQuantizedMatmul      0.988902           4.97312    int8
/blocks_st.4/attn_s/Mul                             BPU  id(10)    HzSElementwiseMul       0.988902           108.179    int16
/blocks_st.4/attn_s/Softmax                         CPU  --        Softmax                 0.975592           21.0358    float
...tn_s/Transpose_1_output_0_calibrated_Requantize  BPU  id(10)    HzRequantize            --                 --         int16
/blocks_st.4/attn_s/MatMul_1                        BPU  id(11)    HzSQuantizedMatmul      0.952534           0.999803   int8
/blocks_st.4/attn_s/Transpose_3                     BPU  id(11)    Transpose               0.952534           3.57417    int16
/blocks_st.4/attn_s/Reshape_3                       BPU  id(11)    Reshape                 0.952534           3.57417    int16
/blocks_st.4/attn_s/proj/MatMul                     BPU  id(11)    HzSQuantizedConv        0.959719           3.57417    int16
.../blocks_st.4/attn_s/proj/Add_output_0_Reshape_0  BPU  id(11)    Reshape                 0.959718           5.1063     int16
/blocks_st.4/Add                                    BPU  id(11)    HzSElementwiseAdd       0.985374           34.4984    int16
/blocks_st.4/norm2_s/ReduceMean                     BPU  id(11)    HzSQuantizedReduceMean  0.968237           34.4279    int16
/blocks_st.4/norm2_s/Sub                            BPU  id(11)    HzSElementwiseSub       0.985376           34.4279    int16
/blocks_st.4/norm2_s/Pow                            BPU  id(11)    HzLut2Layer             0.998062           34.295     int16
/blocks_st.4/norm2_s/ReduceMean_1                   BPU  id(11)    HzSQuantizedReduceMean  0.999438           1176.15    int8
/blocks_st.4/norm2_s/Div_reciprocal                 BPU  id(11)    HzLut2Layer             0.999862           12.9591    int16
/blocks_st.4/norm2_s/Div_mul                        BPU  id(11)    HzSElementwiseMul       0.984961           34.295     int16
/blocks_st.4/mlp_s/fc1/MatMul_reshape_input         BPU  id(11)    Reshape                 0.984961           13.0069    int16
/blocks_st.4/mlp_s/fc1/MatMul                       BPU  id(11)    HzSQuantizedConv        0.984462           13.0069    int16
/blocks_st.4/mlp_s/act/Mul_1                        BPU  id(11)    HzLut2Layer             0.936040           6.08161    int16
/blocks_st.4/mlp_s/fc2/MatMul                       BPU  id(11)    HzSQuantizedConv        0.941773           4.0232     int16
...dd/blocks_st.4/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(11)    Reshape                 0.941772           15.4819    int16
/blocks_st.4/Add_1                                  BPU  id(11)    HzSElementwiseAdd       0.982902           34.4279    int16
/blocks_st.4/norm1_t/ReduceMean                     BPU  id(11)    HzSQuantizedReduceMean  0.971296           34.5231    int16
/blocks_st.4/norm1_t/Sub                            BPU  id(11)    HzSElementwiseSub       0.982906           34.5231    int16
/blocks_st.4/norm1_t/Pow                            BPU  id(11)    HzLut2Layer             0.998072           34.4126    int16
/blocks_st.4/norm1_t/ReduceMean_1                   BPU  id(11)    HzSQuantizedReduceMean  0.999301           1184.23    int8
/blocks_st.4/norm1_t/Div_reciprocal                 BPU  id(11)    HzLut2Layer             0.999814           17.0866    int16
/blocks_st.4/norm1_t/Div_mul                        BPU  id(11)    HzSElementwiseMul       0.982635           34.4126    int16
/blocks_st.4/norm1_t/Mul                            BPU  id(11)    HzSElementwiseMul       0.975960           12.8189    int16
/blocks_st.4/norm1_t/Add_1                          BPU  id(11)    HzSElementwiseAdd       0.975837           7.99605    int16
/blocks_st.4/attn_t/q_linear/MatMul_reshape_input   BPU  id(11)    Reshape                 0.975837           7.96914    int16
/blocks_st.4/attn_t/q_linear/MatMul                 BPU  id(11)    HzSQuantizedConv        0.975445           7.96914    int16
...cks_st.4/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(11)    Reshape                 0.975445           5.89198    int16
/blocks_st.4/attn_t/k_linear/MatMul                 BPU  id(11)    HzSQuantizedConv        0.984919           7.96914    int16
...cks_st.4/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(11)    Reshape                 0.984919           7.54389    int16
/blocks_st.4/attn_t/v_linear/MatMul                 BPU  id(11)    HzSQuantizedConv        0.948955           7.96914    int16
...cks_st.4/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(11)    Reshape                 0.948956           4.70458    int16
/blocks_st.4/attn_t/Transpose_3                     BPU  id(11)    Transpose               0.975445           5.89198    int16
/blocks_st.4/attn_t/Transpose_4                     BPU  id(11)    Transpose               0.948956           4.70458    int16
/blocks_st.4/attn_t/Transpose_5                     BPU  id(11)    Transpose               0.984919           7.54389    int16
...tn_t/Transpose_3_output_0_calibrated_Requantize  BPU  id(11)    HzRequantize            --                 --         int16
...tn_t/Transpose_5_output_0_calibrated_Requantize  BPU  id(11)    HzRequantize            --                 --         int16
/blocks_st.4/attn_t/MatMul                          BPU  id(11)    HzSQuantizedMatmul      0.995734           5.89198    int8
/blocks_st.4/attn_t/Mul                             BPU  id(11)    HzSElementwiseMul       0.995732           199.22     int16
/blocks_st.4/attn_t/Softmax                         CPU  --        Softmax                 0.906202           38.7392    float
...tn_t/Transpose_4_output_0_calibrated_Requantize  BPU  id(11)    HzRequantize            --                 --         int16
/blocks_st.4/attn_t/MatMul_1                        BPU  id(13)    HzSQuantizedMatmul      0.967922           0.28819    int8
/blocks_st.4/attn_t/Transpose_6                     BPU  id(13)    Transpose               0.967921           4.32369    int16
/blocks_st.4/attn_t/Reshape_6                       BPU  id(13)    Reshape                 0.967921           4.32369    int16
/blocks_st.4/attn_t/proj/MatMul                     BPU  id(13)    HzSQuantizedConv        0.974401           4.32369    int16
.../blocks_st.4/attn_t/proj/Add_output_0_Reshape_0  BPU  id(13)    Reshape                 0.974401           9.94501    int16
/blocks_st.4/Add_2                                  BPU  id(13)    HzSElementwiseAdd       0.985516           34.5231    int16
/blocks_st.4/norm2_t/ReduceMean                     BPU  id(13)    HzSQuantizedReduceMean  0.961555           36.5351    int16
/blocks_st.4/norm2_t/Sub                            BPU  id(13)    HzSElementwiseSub       0.985522           36.5351    int16
/blocks_st.4/norm2_t/Pow                            BPU  id(13)    HzLut2Layer             0.998692           36.4742    int16
/blocks_st.4/norm2_t/ReduceMean_1                   BPU  id(13)    HzSQuantizedReduceMean  0.999596           1330.37    int8
/blocks_st.4/norm2_t/Div_reciprocal                 BPU  id(13)    HzLut2Layer             0.999891           19.2063    int16
/blocks_st.4/norm2_t/Div_mul                        BPU  id(13)    HzSElementwiseMul       0.985314           36.4742    int16
/blocks_st.4/mlp_t/fc1/MatMul_reshape_input         BPU  id(13)    Reshape                 0.985314           12.3949    int16
/blocks_st.4/mlp_t/fc1/MatMul                       BPU  id(13)    HzSQuantizedConv        0.982969           12.3949    int16
/blocks_st.4/mlp_t/act/Mul_1                        BPU  id(13)    HzLut2Layer             0.984367           5.09496    int16
/blocks_st.4/mlp_t/fc2/MatMul                       BPU  id(13)    HzSQuantizedConv        0.987451           4.01236    int16
...dd/blocks_st.4/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(13)    Reshape                 0.987452           19.7648    int16
/blocks_st.4/Add_3                                  BPU  id(13)    HzSElementwiseAdd       0.993146           36.5351    int16
/blocks_ts.4/norm1_t/Pow                            BPU  id(10)    HzLut2Layer             0.998312           34.3595    int16
/blocks_ts.4/norm1_t/ReduceMean_1                   BPU  id(10)    HzSQuantizedReduceMean  0.999358           1180.57    int8
/blocks_ts.4/norm1_t/Div_reciprocal                 BPU  id(10)    HzLut2Layer             0.999853           12.1186    int16
/blocks_ts.4/norm1_t/Div_mul                        BPU  id(10)    HzSElementwiseMul       0.987609           34.3595    int16
/blocks_ts.4/norm1_t/Mul                            BPU  id(10)    HzSElementwiseMul       0.978617           13.1528    int16
/blocks_ts.4/norm1_t/Add_1                          BPU  id(10)    HzSElementwiseAdd       0.978401           6.19336    int16
/blocks_ts.4/attn_t/q_linear/MatMul_reshape_input   BPU  id(10)    Reshape                 0.978401           6.10149    int16
/blocks_ts.4/attn_t/q_linear/MatMul                 BPU  id(10)    HzSQuantizedConv        0.981760           6.10149    int16
...cks_ts.4/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(10)    Reshape                 0.981759           5.68013    int16
/blocks_ts.4/attn_t/k_linear/MatMul                 BPU  id(10)    HzSQuantizedConv        0.981159           6.10149    int16
...cks_ts.4/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(10)    Reshape                 0.981159           5.25172    int16
/blocks_ts.4/attn_t/v_linear/MatMul                 BPU  id(10)    HzSQuantizedConv        0.935786           6.10149    int16
...cks_ts.4/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(10)    Reshape                 0.935786           2.59465    int16
/blocks_ts.4/attn_t/Transpose_3                     BPU  id(10)    Transpose               0.981760           5.68013    int16
/blocks_ts.4/attn_t/Transpose_4                     BPU  id(10)    Transpose               0.935785           2.59465    int16
/blocks_ts.4/attn_t/Transpose_5                     BPU  id(10)    Transpose               0.981159           5.25172    int16
...tn_t/Transpose_3_output_0_calibrated_Requantize  BPU  id(10)    HzRequantize            --                 --         int16
...tn_t/Transpose_5_output_0_calibrated_Requantize  BPU  id(10)    HzRequantize            --                 --         int16
/blocks_ts.4/attn_t/MatMul                          BPU  id(10)    HzSQuantizedMatmul      0.989712           5.68013    int8
/blocks_ts.4/attn_t/Mul                             BPU  id(10)    HzSElementwiseMul       0.989713           142.067    int16
/blocks_ts.4/attn_t/Softmax                         CPU  --        Softmax                 0.877235           27.6256    float
...tn_t/Transpose_4_output_0_calibrated_Requantize  BPU  id(10)    HzRequantize            --                 --         int16
/blocks_ts.4/attn_t/MatMul_1                        BPU  id(12)    HzSQuantizedMatmul      0.959877           0.421339   int8
/blocks_ts.4/attn_t/Transpose_6                     BPU  id(12)    Transpose               0.959877           2.23082    int16
/blocks_ts.4/attn_t/Reshape_6                       BPU  id(12)    Reshape                 0.959877           2.23082    int16
/blocks_ts.4/attn_t/proj/MatMul                     BPU  id(12)    HzSQuantizedConv        0.967280           2.23082    int16
.../blocks_ts.4/attn_t/proj/Add_output_0_Reshape_0  BPU  id(12)    Reshape                 0.967279           4.55793    int16
/blocks_ts.4/Add                                    BPU  id(12)    HzSElementwiseAdd       0.987779           34.4984    int16
/blocks_ts.4/norm2_t/ReduceMean                     BPU  id(12)    HzSQuantizedReduceMean  0.970195           34.503     int16
/blocks_ts.4/norm2_t/Sub                            BPU  id(12)    HzSElementwiseSub       0.987781           34.503     int16
/blocks_ts.4/norm2_t/Pow                            BPU  id(12)    HzLut2Layer             0.998307           34.3534    int16
/blocks_ts.4/norm2_t/ReduceMean_1                   BPU  id(12)    HzSQuantizedReduceMean  0.999390           1180.16    int8
/blocks_ts.4/norm2_t/Div_reciprocal                 BPU  id(12)    HzLut2Layer             0.999862           13.8202    int16
/blocks_ts.4/norm2_t/Div_mul                        BPU  id(12)    HzSElementwiseMul       0.987377           34.3534    int16
/blocks_ts.4/mlp_t/fc1/MatMul_reshape_input         BPU  id(12)    Reshape                 0.987377           13.0177    int16
/blocks_ts.4/mlp_t/fc1/MatMul                       BPU  id(12)    HzSQuantizedConv        0.987712           13.0177    int16
variable_2571_Requantize                            BPU  id(12)    HzRequantize            --                 --         int16
/blocks_ts.4/mlp_t/act/Mul_1                        BPU  id(12)    HzLut2Layer             0.964137           5.2335     int16
/blocks_ts.4/mlp_t/fc2/MatMul                       BPU  id(12)    HzSQuantizedConv        0.974696           3.6629     int16
...dd/blocks_ts.4/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(12)    Reshape                 0.974695           5.31888    int16
/blocks_ts.4/Add_1                                  BPU  id(12)    HzSElementwiseAdd       0.989454           34.503     int16
/blocks_ts.4/norm1_s/ReduceMean                     BPU  id(12)    HzSQuantizedReduceMean  0.969710           34.486     int16
/blocks_ts.4/norm1_s/Sub                            BPU  id(12)    HzSElementwiseSub       0.989460           34.486     int16
/blocks_ts.4/norm1_s/Pow                            BPU  id(12)    HzLut2Layer             0.998711           34.2909    int16
/blocks_ts.4/norm1_s/ReduceMean_1                   BPU  id(12)    HzSQuantizedReduceMean  0.999451           1175.87    int8
/blocks_ts.4/norm1_s/Div_reciprocal                 BPU  id(12)    HzLut2Layer             0.999880           17.278     int16
/blocks_ts.4/norm1_s/Div_mul                        BPU  id(12)    HzSElementwiseMul       0.989006           34.2909    int16
/blocks_ts.4/norm1_s/Mul                            BPU  id(12)    HzSElementwiseMul       0.986179           12.6156    int16
/blocks_ts.4/norm1_s/Add_1                          BPU  id(12)    HzSElementwiseAdd       0.986001           7.04195    int16
/blocks_ts.4/attn_s/q_linear/MatMul_reshape_input   BPU  id(12)    Reshape                 0.986001           7.03395    int16
/blocks_ts.4/attn_s/q_linear/MatMul                 BPU  id(12)    HzSQuantizedConv        0.991901           7.03395    int16
...cks_ts.4/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(12)    Reshape                 0.991901           5.01714    int16
/blocks_ts.4/attn_s/k_linear/MatMul                 BPU  id(12)    HzSQuantizedConv        0.992792           7.03395    int16
...cks_ts.4/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(12)    Reshape                 0.992792           5.16638    int16
/blocks_ts.4/attn_s/v_linear/MatMul                 BPU  id(12)    HzSQuantizedConv        0.987994           7.03395    int16
...cks_ts.4/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(12)    Reshape                 0.987994           6.46287    int16
...attn_s/Transpose_output_0_calibrated_Requantize  BPU  id(12)    HzRequantize            --                 --         int16
...tn_s/Transpose_2_output_0_calibrated_Requantize  BPU  id(12)    HzRequantize            --                 --         int16
/blocks_ts.4/attn_s/MatMul                          BPU  id(12)    HzSQuantizedMatmul      0.993008           5.01714    int8
/blocks_ts.4/attn_s/Mul                             BPU  id(12)    HzSElementwiseMul       0.993008           80.4407    int16
/blocks_ts.4/attn_s/Softmax                         CPU  --        Softmax                 0.987796           15.6421    float
...tn_s/Transpose_1_output_0_calibrated_Requantize  BPU  id(12)    HzRequantize            --                 --         int16
/blocks_ts.4/attn_s/MatMul_1                        BPU  id(13)    HzSQuantizedMatmul      0.978687           0.997883   int8
/blocks_ts.4/attn_s/Transpose_3                     BPU  id(13)    Transpose               0.978686           3.83034    int16
/blocks_ts.4/attn_s/Reshape_3                       BPU  id(13)    Reshape                 0.978686           3.83034    int16
/blocks_ts.4/attn_s/proj/MatMul                     BPU  id(13)    HzSQuantizedConv        0.984245           3.83034    int16
.../blocks_ts.4/attn_s/proj/Add_output_0_Reshape_0  BPU  id(13)    Reshape                 0.984245           6.94529    int16
/blocks_ts.4/Add_2                                  BPU  id(13)    HzSElementwiseAdd       0.990959           34.486     int16
/blocks_ts.4/norm2_s/ReduceMean                     BPU  id(13)    HzSQuantizedReduceMean  0.980118           39.2312    int16
/blocks_ts.4/norm2_s/Sub                            BPU  id(13)    HzSElementwiseSub       0.990966           39.2312    int16
/blocks_ts.4/norm2_s/Pow                            BPU  id(13)    HzLut2Layer             0.999115           39.1622    int16
/blocks_ts.4/norm2_s/ReduceMean_1                   BPU  id(13)    HzSQuantizedReduceMean  0.999632           1533.68    int8
/blocks_ts.4/norm2_s/Div_reciprocal                 BPU  id(13)    HzLut2Layer             0.999917           19.3302    int16
/blocks_ts.4/norm2_s/Div_mul                        BPU  id(13)    HzSElementwiseMul       0.990558           39.1622    int16
/blocks_ts.4/mlp_s/fc1/MatMul_reshape_input         BPU  id(13)    Reshape                 0.990558           12.2027    int16
/blocks_ts.4/mlp_s/fc1/MatMul                       BPU  id(13)    HzSQuantizedConv        0.990204           12.2027    int16
/blocks_ts.4/mlp_s/act/Mul_1                        BPU  id(13)    HzLut2Layer             0.989684           5.65146    int16
/blocks_ts.4/mlp_s/fc2/MatMul                       BPU  id(13)    HzSQuantizedConv        0.992864           3.9051     int16
...dd/blocks_ts.4/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(13)    Reshape                 0.992864           16.8864    int16
/blocks_ts.4/Add_3                                  BPU  id(13)    HzSElementwiseAdd       0.994407           39.2312    int16
/blocks_st.4/Add_3_output_0_calibrated_Requantize   BPU  id(13)    HzRequantize            --                 --         int16
/blocks_ts.4/Add_3_output_0_calibrated_Requantize   BPU  id(13)    HzRequantize            --                 --         int16
/Concat_4                                           BPU  id(13)    Concat                  0.993797           54.1159    int16
/ts_attn.4/MatMul_reshape_input                     BPU  id(13)    Reshape                 0.993797           54.092     int16
...0_reshape_in_transpose_in_calibrated_Requantize  BPU  id(13)    HzRequantize            --                 --         int16
/ts_attn.4/MatMul                                   BPU  id(13)    HzSQuantizedConv        0.995815           54.092     int8
/ts_attn.4/Add/ts_attn.4/Add_output_0_Reshape_0     CPU  --        Reshape                 0.995815           --         float
/Softmax_4                                          CPU  --        Softmax                 0.998898           --         float
/Slice_8                                            BPU  id(14)    Slice                   0.999320           --         int16
/Mul_8                                              BPU  id(14)    HzSElementwiseMul       0.992432           54.1159    int16
/Slice_9                                            BPU  id(14)    Slice                   0.998552           --         int16
/Mul_9                                              BPU  id(14)    HzSElementwiseMul       0.992915           53.5055    int16
/Add_6                                              BPU  id(14)    HzSElementwiseAdd       0.994663           43.9818    int16
/norm/ReduceMean                                    BPU  id(14)    HzSQuantizedReduceMean  0.956216           53.8242    int16
/norm/Sub                                           BPU  id(14)    HzSElementwiseSub       0.994671           53.8242    int16
/norm/Pow                                           BPU  id(14)    HzLut2Layer             0.999585           53.8135    int16
/norm/ReduceMean_1                                  BPU  id(14)    HzSQuantizedReduceMean  0.999851           2895.9     int8
/norm/Div_reciprocal                                BPU  id(14)    HzLut2Layer             0.999959           23.3056    int16
/norm/Div_mul                                       BPU  id(14)    HzSElementwiseMul       0.994559           53.8135    int16
/Reshape_3                                          BPU  id(14)    Reshape                 0.994559           11.8799    int16
/pre_logits/fc/MatMul                               BPU  id(14)    HzSQuantizedConv        0.999069           11.8799    int16
variable_2570_Requantize                            BPU  id(14)    HzRequantize            --                 --         int16
/pre_logits/act/Tanh                                BPU  id(14)    HzLut                   0.998884           0.757861   int8
/head/MatMul                                        BPU  id(14)    HzSQuantizedConv        0.999567           0.639815   int8
2026-05-07 13:17:03,927 file: print_info_dict.py func: print_info_dict line No: 72 The quantized model output:
Output      Cosine Similarity  L1 Distance  L2 Distance  Chebyshev Distance
output      0.999567           0.006071     0.000097     0.030011
模型转换日志Part2:
2026-05-07 13:17:03,968 file: model_builder.py func: model_builder line No: 38 End to Horizon NN Model Convert.
2026-05-07 13:17:04,215 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 601 start convert to *.bin file....
2026-05-07 13:17:04,241 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4326 ONNX model output num : 1
2026-05-07 13:17:04,307 file: layout_util.py func: layout_util line No: 15 set_featuremap_layout start
2026-05-07 13:17:04,308 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4060 model_deps_info: {'hb_mapper_version': '1.24.3', 'hbdk_version': '3.49.15', 'hbdk_runtime_version': ' 3.15.55.0', 'horizon_nn_version': '1.1.0', 'onnx_model': '/open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/motionbert_lite_120.onnx', 'march': 'bayes-e', 'layer_out_dump': False, 'log_level': 'DEBUG', 'working_dir': '/open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/motionbert_lite_model_output', 'model_prefix': 'motionbert_lite', 'node_info': {'/blocks_st.0/attn_s/Softmax': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.0/attn_t/Softmax': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/attn_s/Softmax': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/attn_t/Softmax': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.0/Add/ts_attn.0/Add_output_0_Reshape_0': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/Softmax': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.1/Add/ts_attn.1/Add_output_0_Reshape_0': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/Softmax_1': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.2/Add/ts_attn.2/Add_output_0_Reshape_0': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/Softmax_2': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.0/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.0/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.0/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/norm2_t/Pow': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/Slice': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/Slice_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.1/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.1/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.1/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.1/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.1/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.1/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.1/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.1/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.1/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.1/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.1/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.1/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.1/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.1/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.1/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.1/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/Add_3_output_0_calibrated_Requantize': {'InputType': 'int16', 'OutputType': 'int16'}, '/Concat_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.2/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.2/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.2/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.2/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.2/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.2/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.2/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.2/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/Add_3_output_0_calibrated_Requantize': {'InputType': 'int16', 'OutputType': 'int16'}, '/Concat_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.2/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/Add_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.3/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.3/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.3/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.3/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.3/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.3/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.3/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.3/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/Add_3_output_0_calibrated_Requantize': {'InputType': 'int16', 'OutputType': 'int16'}, '/Concat_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.3/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.3/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_7': {'InputType': 'int16', 'OutputType': 'int16'}, '/Add_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.4/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.4/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.4/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.4/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.4/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.4/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.4/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.4/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/Add_3_output_0_calibrated_Requantize': {'InputType': 'int16', 'OutputType': 'int16'}, '/Concat_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.4/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.4/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_8': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_9': {'InputType': 'int16', 'OutputType': 'int16'}, '/Add_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/norm/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/norm/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/norm/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}}, 'input_names': ['input'], 'input_type_rt': ['featuremap'], 'input_space_and_range': ['regular'], 'input_type_train': ['featuremap'], 'input_layout_rt': ['NHWC'], 'input_layout_train': ['NHWC'], 'norm_type': ['no_preprocess'], 'scale_value': [''], 'mean_value': [''], 'input_shape': ['1x120x17x3'], 'input_batch': [], 'cal_dir': ['/open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/calibration_data_120'], 'cal_data_type': ['float32'], 'preprocess_on': False, 'calibration_type': 'default', 'per_channel': 'True', 'max_percentile': 0.99999, 'hbdk_params': {'hbdk_pass_through_params': '--O3 --debug --core-num 1 --fast --max-time-per-fc 1000 ', 'input-source': {'input': 'ddr', '_default_value': 'ddr'}}, 'debug': True, 'compile_mode': 'latency'}
2026-05-07 13:17:04,311 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4183 ############# model deps info #############
2026-05-07 13:17:04,312 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4184 hb_mapper version   : 1.24.3
2026-05-07 13:17:04,313 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4187 hbdk version        : 3.49.15
2026-05-07 13:17:04,314 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4189 hbdk runtime version: 3.15.55.0
2026-05-07 13:17:04,315 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4192 horizon_nn version  : 1.1.0
2026-05-07 13:17:04,316 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4196 ############# model_parameters info #############
2026-05-07 13:17:04,317 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4202 onnx_model          : /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/motionbert_lite_120.onnx
2026-05-07 13:17:04,318 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4203 BPU march           : bayes-e
2026-05-07 13:17:04,319 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4204 layer_out_dump      : False
2026-05-07 13:17:04,320 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4205 log_level           : DEBUG
2026-05-07 13:17:04,321 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4206 working dir         : /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/motionbert_lite_model_output
2026-05-07 13:17:04,322 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4207 output_model_file_prefix: motionbert_lite
2026-05-07 13:17:04,323 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4226 node info  : {'/blocks_st.0/attn_s/Softmax': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.0/attn_t/Softmax': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/attn_s/Softmax': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/attn_t/Softmax': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.0/Add/ts_attn.0/Add_output_0_Reshape_0': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/Softmax': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.1/Add/ts_attn.1/Add_output_0_Reshape_0': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/Softmax_1': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.2/Add/ts_attn.2/Add_output_0_Reshape_0': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/Softmax_2': {'ON': 'BPU', 'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.0/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.0/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.0/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/norm2_t/Pow': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.0/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/Slice': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/Slice_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.1/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.1/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.1/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.1/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.1/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.1/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.1/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.1/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.1/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.1/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.1/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.1/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.1/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.1/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.1/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.1/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.1/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.1/Add_3_output_0_calibrated_Requantize': {'InputType': 'int16', 'OutputType': 'int16'}, '/Concat_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.2/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.2/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.2/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.2/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.2/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.2/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.2/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.2/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.2/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.2/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.2/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.2/Add_3_output_0_calibrated_Requantize': {'InputType': 'int16', 'OutputType': 'int16'}, '/Concat_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.2/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/Add_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.3/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.3/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.3/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.3/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.3/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.3/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.3/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.3/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.3/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.3/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.3/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.3/Add_3_output_0_calibrated_Requantize': {'InputType': 'int16', 'OutputType': 'int16'}, '/Concat_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.3/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.3/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_7': {'InputType': 'int16', 'OutputType': 'int16'}, '/Add_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.4/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.4/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_st.4/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_st.4/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_st.4/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_st.4/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_t/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_t/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_t/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_t/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Transpose_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Transpose_5': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Transpose_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/Reshape_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_t/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.4/attn_t/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/Add': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_t/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_t/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_t/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_t/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_t/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_t/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_t/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.4/mlp_t/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm1_s/Add_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/q_linear/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/q_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_s/q_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Transpose': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/k_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_s/k_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/v_linear/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...cks_ts.4/attn_s/v_linear/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Transpose_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Transpose_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/MatMul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Transpose_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/attn_s/proj/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '.../blocks_ts.4/attn_s/proj/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/Add_2': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_s/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_s/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/norm2_s/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_s/fc1/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_s/fc1/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_s/act/Mul_1': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/mlp_s/fc2/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '...dd/blocks_ts.4/mlp_s/fc2/Add_output_0_Reshape_0': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/Add_3': {'InputType': 'int16', 'OutputType': 'int16'}, '/blocks_ts.4/Add_3_output_0_calibrated_Requantize': {'InputType': 'int16', 'OutputType': 'int16'}, '/Concat_4': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.4/MatMul_reshape_input': {'InputType': 'int16', 'OutputType': 'int16'}, '/ts_attn.4/MatMul': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_8': {'InputType': 'int16', 'OutputType': 'int16'}, '/Mul_9': {'InputType': 'int16', 'OutputType': 'int16'}, '/Add_6': {'InputType': 'int16', 'OutputType': 'int16'}, '/norm/ReduceMean': {'InputType': 'int16', 'OutputType': 'int16'}, '/norm/Sub': {'InputType': 'int16', 'OutputType': 'int16'}, '/norm/Div_mul': {'InputType': 'int16', 'OutputType': 'int16'}, '/Reshape_3': {'InputType': 'int16', 'OutputType': 'int16'}}
2026-05-07 13:17:04,326 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4228 ############# input_parameters info #############
2026-05-07 13:17:04,327 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4246 ------------------------------------------
2026-05-07 13:17:04,327 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4248 ---------input info : input ---------
2026-05-07 13:17:04,328 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4249 input_name          : input
2026-05-07 13:17:04,329 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4250 input_type_rt       : featuremap
2026-05-07 13:17:04,330 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4252 input_space&range   : regular
2026-05-07 13:17:04,331 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4254 input_layout_rt     : NHWC
2026-05-07 13:17:04,332 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4255 input_type_train    : featuremap
2026-05-07 13:17:04,333 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4256 input_layout_train  : NHWC
2026-05-07 13:17:04,334 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4257 norm_type           : no_preprocess
2026-05-07 13:17:04,335 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4258 input_shape         : 1x120x17x3
2026-05-07 13:17:04,335 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4268 cal_data_dir        : /open_explorer/samples/ai_toolchain/horizon_model_convert_sample/04_detection/18_motionbert/mapper/calibration_data_120
2026-05-07 13:17:04,336 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4270 cal_data_type       : float32
2026-05-07 13:17:04,337 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4271 ---------input info : input end -------
2026-05-07 13:17:04,339 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4272 ------------------------------------------
2026-05-07 13:17:04,340 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4274 ############# calibration_parameters info #############
2026-05-07 13:17:04,341 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4275 preprocess_on       : False
2026-05-07 13:17:04,342 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4276 calibration_type:   : default
2026-05-07 13:17:04,343 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4281 max_percentile      : 0.99999
2026-05-07 13:17:04,344 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4284 per_channel         : True
2026-05-07 13:17:04,345 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4303 ############# compiler_parameters info #############
2026-05-07 13:17:04,346 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4305 debug               : True
2026-05-07 13:17:04,347 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4307 compile_mode        : latency
2026-05-07 13:17:04,348 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4310 hbdk_pass_through_params: --O3 --debug --core-num 1 --fast --max-time-per-fc 1000
2026-05-07 13:17:04,349 file: onnx2horizonrt.py func: onnx2horizonrt line No: 4310 input-source        : {'input': 'ddr', '_default_value': 'ddr'}
2026-05-07 13:17:04,879 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 783 Convert to runtime bin file successfully!
2026-05-07 13:17:04,881 file: hb_mapper_makertbin.py func: hb_mapper_makertbin line No: 784 End Model Convert
根据完整的量化日志,我找到了核心问题
:magnifying_glass_tilted_left: 问题诊断
1. Softmax 的"伪 FP32"问题
虽然日志显示 Softmax 在 CPU 上以 float32 运行,但输入数据经过了 requantize
/blocks_st.3/attn_t/Transpose_4  → 0.939688 (int16)
                                    ↓ requantize
/blocks_st.3/attn_t/Softmax      → 0.882698 (float)  ❌ 精度已损失
关键证据
Softmax 节点 余弦相似度 问题
/blocks_st.3/attn_t/Softmax 0.882 输入 requantize 导致
/blocks_ts.3/attn_t/Softmax 0.890 同上
/blocks_ts.4/attn_t/Softmax 0.877 最严重
2. 误差累积效应
Layer 0: 0.999+  ✅
Layer 1: 0.98-0.99  ⚠️
Layer 2: 0.95-0.97  ⚠️
Layer 3: 0.90-0.93  ❌  (/blocks_st.3/mlp_t/fc2/MatMul: 0.903864)
Layer 4: 继续恶化
3. 最终输出看似不错 (0.999567),但存在抖动
这是因为时序累积误差在单帧余弦相似度上体现不出来,但在连续帧上表现为抖动。
:hammer_and_wrench: 终极解决方案
方案 1:混合精度策略(强烈推荐)
Attention 的 Q/K/V 投影层Softmax 输入保持 int16,避免 requantize 损失:
# config_hybrid.yaml
  onnx_model: ./motionbert_lite_120.onnx
  march: bayes-e
  working_dir: motionbert_lite_model_output
  node_info:
    # ========== 关键:Attention 的 Q/K/V 线性层保持 int16 ==========
    /blocks_st.0/attn_s/q_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.0/attn_s/k_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.0/attn_s/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.0/attn_t/q_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.0/attn_t/k_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.0/attn_t/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    # 对所有 blocks_st.1-4 和 blocks_ts.0-4 重复上述配置
    # ...(省略,按同样模式配置所有 Attention 线性层)
    # ========== Softmax 相关节点强制 FP32(包括输入输出)==========
    /blocks_st.0/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.0/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    # ...(配置所有 Softmax 节点)
    # ========== 最后几层 MLP 保持 int16 ==========
    /blocks_st.3/mlp_t/fc1/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.4/mlp_t/fc1/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.4/mlp_t/fc2/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    # ========== 输出头保持 int16 ==========
    /head/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
  cal_data_dir: ./calibration_data_120
  cal_data_type: float32
  calibration_type: kl  # 改用 KL 散度
  max_percentile: 0.9999  # 从 0.99999 降低
  per_channel: true
方案 2:增加校准数据(必须配合方案 1)
50 条数据对时序模型严重不足
# 准备 300-500 条校准数据,覆盖:
# - 静止状态
# - 快速运动
# - 遮挡场景
# - 不同视角
# 校准数据生成脚本示例
python3 generate_calibration_data.py \
  --num_samples 500 \
  --cover_all_actions \
  --output_dir ./calibration_data_500
方案 3:QAT(最后手段)
如果 PTQ 调优后仍有抖动,考虑 QAT:
# QAT 配置示例
from horizon_plugin_pytorch.quantization import QConfig, prepare_qat
qconfig = QConfig(
    activation={'dtype': 'int8', 'bitwidth': 8},
    weight={'dtype': 'int8', 'bitwidth': 8},
    op_specific={
        'MatMul': {'activation': {'dtype': 'int16'}},  # Attention 层用 int16
        'Softmax': {'activation': {'dtype': 'float32'}},  # Softmax 用 FP32
model = prepare_qat(model, qconfig)
# 微调 5-10 个 epoch
:clipboard: 验证步骤
# 1. 应用方案 1 后重新量化
hb_mapper --config config_hybrid.yaml
# 2. 对比量化前后各层输出
# 开启 layer_out_dump
  layer_out_dump: true
# 3. 开发机验证 quantized ONNX
python3 validate_quantized.py \
  --model motionbert_lite_quantized_model.onnx \
  --calib_dir ./calibration_data_500 \
  --output_layer_similarity
# 4. 板端测试抖动
# 录制连续 100 帧,计算关键点位置的标准差
python3 test_jitter.py \
  --model motionbert_lite.bin \
  --num_frames 100 \
  --output jitter_report.json
:bar_chart: 预期效果
指标 当前 方案 1 后 方案 1+2 后 QAT 后
Softmax 相似度 0.87-0.89 0.95+ 0.98+ 0.99+
深层 MatMul 相似度 0.90-0.93 0.95+ 0.97+ 0.99+
输出抖动 明显 减轻 轻微
实施难度 -
:warning: 关键提醒
  1. 不要只配置 Softmax 为 FP32,必须同时保护其输入数据(Attention 的 Q/K/V 投影层)
  2. 校准数据量是关键,50 条对时序模型远远不够
  3. 最终输出相似度 0.999567 具有欺骗性,时序抖动需要专门测试
  4. 如果上述方案仍无法解决,QAT 是必经之路
需要我帮你生成完整的 YAML 配置文件吗?或者需要进一步分析特定层的量化策略?
根据你提供的完整量化日志,我找到了核心问题
1. Softmax 配置错误(最关键)
从转换日志看到:
node_info:
但余弦相似度显示
节点 相似度 数据类型 问题
/blocks_st.3/attn_t/Softmax 0.882 float :cross_mark: 严重损失
/blocks_ts.4/attn_t/Softmax 0.877 float :cross_mark: 严重损失
/blocks_st.2/attn_t/Softmax 0.920 float :cross_mark: 严重损失
虽然显示为 float,但输入数据经过了 int16 requantize,导致精度在 Softmax 前已损失。
2. 误差累积严重
blocks_st.0: 0.999+  ✅
blocks_st.1: 0.98-0.99  ⚠️
blocks_st.2: 0.95-0.96  ❌
blocks_st.3: 0.90-0.92  ❌❌  (/blocks_st.3/mlp_t/fc2/MatMul: 0.903864)
blocks_st.4: 继续恶化
3. int16 算子过多
日志显示配置了200+ 个算子为 int16,远超必要范围。
:hammer_and_wrench: 立即执行方案
步骤 1:修改 YAML 配置(最关键)
# config_softmax_fp32.yaml
  march: bayes-e
  working_dir: motionbert_lite_model_output_fp32
  layer_out_dump: true  # 开启分层输出对比
  # 关键:所有 Softmax 强制 CPU + float32
  node_info:
    # blocks_st 层 - 所有 Softmax
      ON: CPU
      InputType: float32
      OutputType: float32
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.1/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.1/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.2/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.2/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.3/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.3/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.4/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.4/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    # blocks_ts 层 - 所有 Softmax
    /blocks_ts.0/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.0/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.1/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.1/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.2/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.2/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.3/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.3/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.4/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.4/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    # 顶层 Softmax
    /Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /Softmax_1:
      ON: CPU
      InputType: float32
      OutputType: float32
    /Softmax_2:
      ON: CPU
      InputType: float32
      OutputType: float32
    /Softmax_3:
      ON: CPU
      InputType: float32
      OutputType: float32
    /Softmax_4:
      ON: CPU
      InputType: float32
      OutputType: float32
    # 输出头保持 int16(坐标回归需要精度)
    /Concat:
      ON: BPU
      InputType: int16
      OutputType: int16
    /Concat_1:
      ON: BPU
      InputType: int16
      OutputType: int16
    /Concat_2:
      ON: BPU
      InputType: int16
      OutputType: int16
    /Concat_3:
      ON: BPU
      InputType: int16
      OutputType: int16
    /Concat_4:
      ON: BPU
      InputType: int16
      OutputType: int16
    /head/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
  calibration_type: default
  max_percentile: 0.99995  # 从 0.99999 降低
  per_channel: true
步骤 2:重新量化
# 使用新配置重新量化
hb_mapper --config config_softmax_fp32.yaml
# 查看新量化报告
cat motionbert_lite_model_output_fp32/motionbert_lite_quant_info.json | grep -A2 "Softmax"
步骤 3:验证分层输出
# 对比浮点模型和量化模型各层输出
import onnxruntime as ort
# 加载浮点模型
float_session = ort.InferenceSession('motionbert_lite_original_float_model.onnx')
# 加载量化模型
quant_session = ort.InferenceSession('motionbert_lite_quantized_model.onnx')
# 准备测试数据
test_input = np.random.randn(1, 120, 17, 3).astype(np.float32)
# 对比输出
float_output = float_session.run(None, {'input': test_input})[0]
quant_output = quant_session.run(None, {'input': test_input})[0]
cosine_sim = np.dot(float_output.flatten(), quant_output.flatten()) / (
    np.linalg.norm(float_output.flatten()) * np.linalg.norm(quant_output.flatten())
print(f"输出余弦相似度:{cosine_sim}")
:bar_chart: 预期效果
指标 当前 修改后预期
Softmax 相似度 0.87-0.92 0.99+
最终输出相似度 0.999567 0.9998+
关键点抖动 明显 基本消除
:warning: 如果仍有问题
方案 B:增加校准数据
# 50 条对时序模型明显不足,建议 200-500 条
# 覆盖不同动作场景:静止、快速运动、遮挡等
# 生成更多校准数据
python3 generate_calibration_data.py --num_samples 300 --output_dir ./calibration_data_300
方案 C:QAT(最后手段)
如果 PTQ 调优后仍不满足,参考社区精华帖:
:red_question_mark: 需要确认
  1. 当前板端部署后 MPJPE 误差是多少?(浮点 vs 量化)
  2. 抖动表现:是时间序列上的帧间抖动,还是单帧精度下降?
  3. 工具链版本hbdk version 3.49.15,确认是否有更新版本
先执行步骤 1 和 2,通常能解决 80% 以上的 Transformer 量化精度问题。完成后请反馈新的量化报告。
建议尝试降低 max_percentile ,softmax掉点严重建议放到外部CPU来实现
已按照yaml配置重新转换模型,所有Softmax已放到CPU,余弦相似度还是低
余弦相似度Part1:
Node                                                ON   Subgraph  Type                    Cosine Similarity  Threshold  DataType
/joints_embed/MatMul                                BPU  id(0)     HzSQuantizedConv        0.999911           1.06918    int8
/Add                                                BPU  id(0)     HzSElementwiseAdd       0.999873           0.278901   int8
/Add_1                                              BPU  id(0)     HzSElementwiseAdd       0.999824           0.380507   int8
/blocks_st.0/norm1_s/ReduceMean                     BPU  id(0)     HzSQuantizedReduceMean  0.998782           0.528001   int8
/blocks_st.0/norm1_s/Sub                            BPU  id(0)     HzSElementwiseSub       0.999745           0.528001   int8
/blocks_st.0/norm1_s/Pow                            BPU  id(0)     HzLut                   0.999576           0.525383   int8
/blocks_st.0/norm1_s/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999942           0.276027   int8
/blocks_st.0/norm1_s/Div_reciprocal                 BPU  id(0)     HzLut                   0.999982           0.014824   int8
/blocks_st.0/norm1_s/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.999684           0.525383   int8
/blocks_st.0/norm1_s/Mul                            BPU  id(0)     HzSQuantizedConv        0.999582           5.71453    int8
/blocks_st.0/attn_s/q_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999664           3.73541    int8
...cks_st.0/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999664           0.90957    int8
/blocks_st.0/attn_s/Transpose                       BPU  id(0)     Transpose               0.999664           0.90957    int8
/blocks_st.0/attn_s/k_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999499           3.73541    int8
...cks_st.0/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999501           0.917088   int8
/blocks_st.0/attn_s/v_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999953           3.73541    int8
...cks_st.0/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999953           2.31353    int8
/blocks_st.0/attn_s/Transpose_1                     BPU  id(0)     Transpose               0.999953           2.31353    int8
/blocks_st.0/attn_s/Transpose_2                     BPU  id(0)     Transpose               0.999500           0.917088   int8
/blocks_st.0/attn_s/MatMul                          BPU  id(0)     HzSQuantizedMatmul      0.999298           0.90957    int8
/blocks_st.0/attn_s/Mul                             BPU  id(0)     HzSElementwiseMul       0.999303           2.49369    int8
/blocks_st.0/attn_s/Softmax                         CPU  --        Softmax                 1.000010           0.528991   float
/blocks_st.0/attn_s/MatMul_1                        BPU  id(1)     HzSQuantizedMatmul      0.999981           0.084051   int8
/blocks_st.0/attn_s/Transpose_3                     BPU  id(1)     Transpose               0.999981           2.16572    int8
/blocks_st.0/attn_s/Reshape_3                       BPU  id(1)     Reshape                 0.999981           2.16572    int8
/blocks_st.0/attn_s/proj/MatMul                     BPU  id(1)     HzSQuantizedConv        0.999999           2.16572    int8
/blocks_st.0/norm2_s/ReduceMean                     BPU  id(1)     HzSQuantizedReduceMean  0.999676           5.25617    int8
/blocks_st.0/norm2_s/Sub                            BPU  id(1)     HzSElementwiseSub       0.999948           5.25617    int8
/blocks_st.0/norm2_s/Pow                            BPU  id(1)     HzLut                   0.999789           5.21707    int8
/blocks_st.0/norm2_s/ReduceMean_1                   BPU  id(1)     HzSQuantizedReduceMean  0.999977           27.2178    int8
/blocks_st.0/norm2_s/Div_reciprocal                 BPU  id(1)     HzLut                   0.999979           4.21703    int8
/blocks_st.0/norm2_s/Div_mul                        BPU  id(1)     HzSElementwiseMul       0.999916           5.21707    int8
/blocks_st.0/mlp_s/fc1/MatMul                       BPU  id(1)     HzSQuantizedConv        0.999879           2.89364    int8
/blocks_st.0/mlp_s/act/Mul_1                        BPU  id(1)     HzLut                   0.999871           4.07775    int8
/blocks_st.0/mlp_s/fc2/MatMul                       BPU  id(1)     HzSQuantizedConv        0.999981           4.07766    int8
/blocks_st.0/norm1_t/ReduceMean                     BPU  id(1)     HzSQuantizedReduceMean  0.999853           12.8477    int8
/blocks_st.0/norm1_t/Sub                            BPU  id(1)     HzSElementwiseSub       0.999963           12.8477    int8
/blocks_st.0/norm1_t/Pow                            BPU  id(1)     HzLut                   0.999801           12.7054    int8
/blocks_st.0/norm1_t/ReduceMean_1                   BPU  id(1)     HzSQuantizedReduceMean  0.999962           161.426    int8
/blocks_st.0/norm1_t/Div_reciprocal                 BPU  id(1)     HzLut                   0.999988           26.5017    int8
/blocks_st.0/norm1_t/Div_mul                        BPU  id(1)     HzSElementwiseMul       0.999945           12.7054    int8
/blocks_st.0/norm1_t/Mul                            BPU  id(1)     HzSQuantizedConv        0.999943           2.49638    int8
/blocks_st.0/attn_t/q_linear/MatMul                 BPU  id(1)     HzSQuantizedConv        0.999954           1.4773     int8
...cks_st.0/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(1)     Reshape                 0.999950           0.62736    int8
/blocks_st.0/attn_t/k_linear/MatMul                 BPU  id(1)     HzSQuantizedConv        0.999952           1.4773     int8
...cks_st.0/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(1)     Reshape                 0.999945           1.18146    int8
/blocks_st.0/attn_t/v_linear/MatMul                 BPU  id(1)     HzSQuantizedConv        0.999985           1.4773     int8
...cks_st.0/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(1)     Reshape                 0.999974           2.05851    int8
/blocks_st.0/attn_t/Transpose_3                     BPU  id(1)     Transpose               0.999944           0.62736    int8
/blocks_st.0/attn_t/Transpose_4                     BPU  id(1)     Transpose               0.999978           2.05851    int8
/blocks_st.0/attn_t/Transpose_5                     BPU  id(1)     Transpose               0.999951           1.18146    int8
/blocks_st.0/attn_t/MatMul                          BPU  id(1)     HzSQuantizedMatmul      1.000022           0.62736    int8
/blocks_st.0/attn_t/Mul                             BPU  id(1)     HzSElementwiseMul       1.000034           3.24055    int8
/blocks_st.0/attn_t/Softmax                         CPU  --        Softmax                 1.000109           0.687424   float
/blocks_st.0/attn_t/MatMul_1                        BPU  id(3)     HzSQuantizedMatmul      0.999989           0.008424   int8
/blocks_st.0/attn_t/Transpose_6                     BPU  id(3)     Transpose               0.999993           2.04219    int8
/blocks_st.0/attn_t/Reshape_6                       BPU  id(3)     Reshape                 0.999993           2.04219    int8
/blocks_st.0/attn_t/proj/MatMul                     BPU  id(3)     HzSQuantizedConv        1.000001           2.04219    int8
/blocks_st.0/norm2_t/ReduceMean                     BPU  id(3)     HzSQuantizedReduceMean  0.999859           15.6583    int8
/blocks_st.0/norm2_t/Sub                            BPU  id(3)     HzSElementwiseSub       0.999943           15.6583    int8
/blocks_st.0/norm2_t/Pow                            BPU  id(3)     HzLut                   0.999826           15.4648    int8
/blocks_st.0/norm2_t/ReduceMean_1                   BPU  id(3)     HzSQuantizedReduceMean  0.999978           239.161    int8
/blocks_st.0/norm2_t/Div_reciprocal                 BPU  id(3)     HzLut                   0.999991           45.6055    int8
/blocks_st.0/norm2_t/Div_mul                        BPU  id(3)     HzSElementwiseMul       0.999933           15.4648    int8
/blocks_st.0/mlp_t/fc1/MatMul                       BPU  id(3)     HzSQuantizedConv        0.999950           2.31824    int8
/blocks_st.0/mlp_t/act/Mul_1                        BPU  id(3)     HzLut                   0.999772           1.72277    int8
/blocks_st.0/mlp_t/fc2/MatMul                       BPU  id(3)     HzSQuantizedConv        0.999989           1.64961    int8
...st.0/Add_3/blocks_st.0/Add_3_output_0_Reshape_0  BPU  id(3)     Reshape                 0.999974           17.3561    int16
/blocks_ts.0/norm1_t/Pow                            BPU  id(0)     HzLut                   0.999576           0.525383   int8
/blocks_ts.0/norm1_t/ReduceMean_1                   BPU  id(0)     HzSQuantizedReduceMean  0.999942           0.276027   int8
/blocks_ts.0/norm1_t/Div_reciprocal                 BPU  id(0)     HzLut                   0.999982           0.014824   int8
/blocks_ts.0/norm1_t/Div_mul                        BPU  id(0)     HzSElementwiseMul       0.999684           0.525383   int8
/blocks_ts.0/norm1_t/Mul                            BPU  id(0)     HzSQuantizedConv        0.999514           5.71453    int8
/blocks_ts.0/attn_t/q_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999832           3.13211    int8
...cks_ts.0/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999829           5.13088    int8
/blocks_ts.0/attn_t/k_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999844           3.13211    int8
...cks_ts.0/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999854           6.83864    int8
/blocks_ts.0/attn_t/v_linear/MatMul                 BPU  id(0)     HzSQuantizedConv        0.999723           3.13211    int8
...cks_ts.0/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(0)     Reshape                 0.999722           6.24957    int8
/blocks_ts.0/attn_t/Transpose_3                     BPU  id(0)     Transpose               0.999830           5.13088    int8
/blocks_ts.0/attn_t/Transpose_4                     BPU  id(0)     Transpose               0.999722           6.24957    int8
/blocks_ts.0/attn_t/Transpose_5                     BPU  id(0)     Transpose               0.999844           6.83864    int8
/blocks_ts.0/attn_t/MatMul                          BPU  id(0)     HzSQuantizedMatmul      0.999724           5.13088    int8
/blocks_ts.0/attn_t/Mul                             BPU  id(0)     HzSElementwiseMul       0.999720           110.31     int8
/blocks_ts.0/attn_t/Softmax                         CPU  --        Softmax                 0.996141           21.4503    float
/blocks_ts.0/attn_t/MatMul_1                        BPU  id(2)     HzSQuantizedMatmul      0.999377           0.948144   int8
/blocks_ts.0/attn_t/Transpose_6                     BPU  id(2)     Transpose               0.999376           6.21712    int8
/blocks_ts.0/attn_t/Reshape_6                       BPU  id(2)     Reshape                 0.999376           6.21712    int8
/blocks_ts.0/attn_t/proj/MatMul                     BPU  id(2)     HzSQuantizedConv        0.999705           6.21712    int8
/blocks_ts.0/norm2_t/ReduceMean                     BPU  id(2)     HzSQuantizedReduceMean  0.997884           32.7547    int8
/blocks_ts.0/norm2_t/Sub                            BPU  id(2)     HzSElementwiseSub       0.998799           32.7547    int8
/blocks_ts.0/norm2_t/Pow                            BPU  id(2)     HzLut                   0.993153           33.1037    int8
/blocks_ts.0/norm2_t/ReduceMean_1                   BPU  id(2)     HzSQuantizedReduceMean  0.999545           1095.85    int8
/blocks_ts.0/norm2_t/Div_reciprocal                 BPU  id(2)     HzLut                   0.999885           19.6631    int8
/blocks_ts.0/norm2_t/Div_mul                        BPU  id(2)     HzSElementwiseMul       0.998692           33.1037    int8
/blocks_ts.0/mlp_t/fc1/MatMul                       BPU  id(2)     HzSQuantizedConv        0.999813           7.53416    int8
/blocks_ts.0/mlp_t/act/Mul_1                        BPU  id(2)     HzLut                   0.998827           10.2101    int8
/blocks_ts.0/mlp_t/fc2/MatMul                       BPU  id(2)     HzSQuantizedConv        0.999461           3.87026    int8
/blocks_ts.0/norm1_s/ReduceMean                     BPU  id(2)     HzSQuantizedReduceMean  0.995530           32.6436    int8
/blocks_ts.0/norm1_s/Sub                            BPU  id(2)     HzSElementwiseSub       0.998137           32.6436    int8
/blocks_ts.0/norm1_s/Pow                            BPU  id(2)     HzLut                   0.998832           32.8559    int8
/blocks_ts.0/norm1_s/ReduceMean_1                   BPU  id(2)     HzSQuantizedReduceMean  0.999720           1079.51    int8
/blocks_ts.0/norm1_s/Div_reciprocal                 BPU  id(2)     HzLut                   0.999930           19.9898    int8
/blocks_ts.0/norm1_s/Div_mul                        BPU  id(2)     HzSElementwiseMul       0.997909           32.8559    int8
/blocks_ts.0/norm1_s/Mul                            BPU  id(2)     HzSQuantizedConv        0.996080           9.54295    int8
/blocks_ts.0/attn_s/q_linear/MatMul                 BPU  id(2)     HzSQuantizedConv        0.999308           3.2512     int8
...cks_ts.0/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(2)     Reshape                 0.999309           5.16988    int8
/blocks_ts.0/attn_s/Transpose                       BPU  id(2)     Transpose               0.999309           5.16988    int8
/blocks_ts.0/attn_s/k_linear/MatMul                 BPU  id(2)     HzSQuantizedConv        0.999286           3.2512     int8
...cks_ts.0/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(2)     Reshape                 0.999293           6.48277    int8
/blocks_ts.0/attn_s/v_linear/MatMul                 BPU  id(2)     HzSQuantizedConv        0.998611           3.2512     int8
...cks_ts.0/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(2)     Reshape                 0.998611           6.67083    int8
/blocks_ts.0/attn_s/Transpose_1                     BPU  id(2)     Transpose               0.998611           6.67083    int8
/blocks_ts.0/attn_s/Transpose_2                     BPU  id(2)     Transpose               0.999291           6.48277    int8
/blocks_ts.0/attn_s/MatMul                          BPU  id(2)     HzSQuantizedMatmul      0.999161           5.16988    int8
/blocks_ts.0/attn_s/Mul                             BPU  id(2)     HzSElementwiseMul       0.999154           152.359    int8
/blocks_ts.0/attn_s/Softmax                         CPU  --        Softmax                 0.995420           29.6269    float
/blocks_ts.0/attn_s/MatMul_1                        BPU  id(3)     HzSQuantizedMatmul      0.994383           0.998331   int8
/blocks_ts.0/attn_s/Transpose_3                     BPU  id(3)     Transpose               0.994383           5.82686    int8
/blocks_ts.0/attn_s/Reshape_3                       BPU  id(3)     Reshape                 0.994383           5.82686    int8
/blocks_ts.0/attn_s/proj/MatMul                     BPU  id(3)     HzSQuantizedConv        0.996323           5.82686    int8
/blocks_ts.0/norm2_s/ReduceMean                     BPU  id(3)     HzSQuantizedReduceMean  0.986439           34.841     int8
/blocks_ts.0/norm2_s/Sub                            BPU  id(3)     HzSElementwiseSub       0.996913           34.841     int8
/blocks_ts.0/norm2_s/Pow                            BPU  id(3)     HzLut                   0.998692           34.8666    int8
/blocks_ts.0/norm2_s/ReduceMean_1                   BPU  id(3)     HzSQuantizedReduceMean  0.999737           1215.68    int8
/blocks_ts.0/norm2_s/Div_reciprocal                 BPU  id(3)     HzLut                   0.999947           12.5174    int8
/blocks_ts.0/norm2_s/Div_mul                        BPU  id(3)     HzSElementwiseMul       0.996605           34.8666    int8
/blocks_ts.0/mlp_s/fc1/MatMul                       BPU  id(3)     HzSQuantizedConv        0.998700           12.7077    int8
/blocks_ts.0/mlp_s/act/Mul_1                        BPU  id(3)     HzLut                   0.983751           7.35147    int8
/blocks_ts.0/mlp_s/fc2/MatMul                       BPU  id(3)     HzSQuantizedConv        0.993234           4.56598    int8
...ts.0/Add_3/blocks_ts.0/Add_3_output_0_Reshape_0  BPU  id(3)     Reshape                 0.995935           34.7594    int16
/blocks_st.0/Add_3_output_0_calibrated_Requantize   BPU  id(3)     HzRequantize            --                 --         int16
/Concat                                             BPU  id(3)     Concat                  0.999571           17.3561    int16
/ts_attn.0/MatMul_reshape_input                     BPU  id(3)     Reshape                 0.999571           34.7594    int16
...0_reshape_in_transpose_in_calibrated_Requantize  BPU  id(3)     HzRequantize            --                 --         int16
/ts_attn.0/MatMul                                   BPU  id(3)     HzSQuantizedConv        0.999952           34.7594    int8
/ts_attn.0/Add/ts_attn.0/Add_output_0_Reshape_0     CPU  --        Reshape                 0.999952           --         float
/Softmax                                            CPU  --        Softmax                 1.000000           --         float
/Slice                                              BPU  id(4)     Slice                   1.000000           --         int8
/Mul                                                BPU  id(4)     HzSElementwiseMul       1.000000           17.3561    int16
/Slice_1                                            BPU  id(4)     Slice                   1.000000           --         int8
/Mul_1                                              BPU  id(4)     HzSElementwiseMul       0.995407           34.7594    int16
/Add_2                                              BPU  id(4)     HzSElementwiseAdd       0.995407           0.0        int8
/blocks_st.1/norm1_s/ReduceMean                     BPU  id(4)     HzSQuantizedReduceMean  0.980921           34.7594    int8
/blocks_st.1/norm1_s/Sub                            BPU  id(4)     HzSElementwiseSub       0.995165           34.7594    int8
/blocks_st.1/norm1_s/Pow                            BPU  id(4)     HzLut                   0.998771           34.7462    int8
/blocks_st.1/norm1_s/ReduceMean_1                   BPU  id(4)     HzSQuantizedReduceMean  0.999667           1207.3     int8
/blocks_st.1/norm1_s/Div_reciprocal                 BPU  id(4)     HzLut                   0.999931           12.8551    int8
/blocks_st.1/norm1_s/Div_mul                        BPU  id(4)     HzSElementwiseMul       0.994807           34.7462    int8
/blocks_st.1/norm1_s/Mul                            BPU  id(4)     HzSElementwiseMul       0.990585           12.9401    int8
/blocks_st.1/norm1_s/Add_1                          BPU  id(4)     HzSElementwiseAdd       0.989331           4.36002    int8
/blocks_st.1/attn_s/q_linear/MatMul_reshape_input   BPU  id(4)     Reshape                 0.989331           4.3469     int8
/blocks_st.1/attn_s/q_linear/MatMul                 BPU  id(4)     HzSQuantizedConv        0.997914           4.3469     int8
...cks_st.1/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(4)     Reshape                 0.997911           4.61073    int8
/blocks_st.1/attn_s/Transpose                       BPU  id(4)     Transpose               0.997911           4.61073    int8
/blocks_st.1/attn_s/k_linear/MatMul                 BPU  id(4)     HzSQuantizedConv        0.996767           4.3469     int8
...cks_st.1/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(4)     Reshape                 0.996769           4.41066    int8
/blocks_st.1/attn_s/v_linear/MatMul                 BPU  id(4)     HzSQuantizedConv        0.993681           4.3469     int8
...cks_st.1/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(4)     Reshape                 0.993683           4.76804    int8
/blocks_st.1/attn_s/Transpose_1                     BPU  id(4)     Transpose               0.993682           4.76804    int8
/blocks_st.1/attn_s/Transpose_2                     BPU  id(4)     Transpose               0.996768           4.41066    int8
/blocks_st.1/attn_s/MatMul                          BPU  id(4)     HzSQuantizedMatmul      0.996763           4.61073    int8
/blocks_st.1/attn_s/Mul                             BPU  id(4)     HzSElementwiseMul       0.996766           112.583    int8
/blocks_st.1/attn_s/Softmax                         CPU  --        Softmax                 0.992430           21.8922    float
/blocks_st.1/attn_s/MatMul_1                        BPU  id(5)     HzSQuantizedMatmul      0.971288           0.997621   int8
/blocks_st.1/attn_s/Transpose_3                     BPU  id(5)     Transpose               0.971288           3.37664    int8
/blocks_st.1/attn_s/Reshape_3                       BPU  id(5)     Reshape                 0.971288           3.37664    int8
/blocks_st.1/attn_s/proj/MatMul                     BPU  id(5)     HzSQuantizedConv        0.975149           3.37664    int8
.../blocks_st.1/attn_s/proj/Add_output_0_Reshape_0  BPU  id(5)     Reshape                 0.975148           5.87579    int8
/blocks_st.1/Add                                    BPU  id(5)     HzSElementwiseAdd       0.993349           34.7594    int8
/blocks_st.1/norm2_s/ReduceMean                     BPU  id(5)     HzSQuantizedReduceMean  0.974436           34.9277    int8
/blocks_st.1/norm2_s/Sub                            BPU  id(5)     HzSElementwiseSub       0.993146           34.9277    int8
/blocks_st.1/norm2_s/Pow                            BPU  id(5)     HzLut                   0.998277           34.8987    int8
/blocks_st.1/norm2_s/ReduceMean_1                   BPU  id(5)     HzSQuantizedReduceMean  0.999452           1217.92    int8
/blocks_st.1/norm2_s/Div_reciprocal                 BPU  id(5)     HzLut                   0.999873           12.1907    int8
/blocks_st.1/norm2_s/Div_mul                        BPU  id(5)     HzSElementwiseMul       0.992712           34.8987    int8
/blocks_st.1/mlp_s/fc1/MatMul_reshape_input         BPU  id(5)     Reshape                 0.992712           13.0201    int8
/blocks_st.1/mlp_s/fc1/MatMul                       BPU  id(5)     HzSQuantizedConv        0.996733           13.0201    int8
/blocks_st.1/mlp_s/act/Mul_1                        BPU  id(5)     HzLut                   0.972092           6.69891    int8
/blocks_st.1/mlp_s/fc2/MatMul                       BPU  id(5)     HzSQuantizedConv        0.976838           4.15911    int8
...dd/blocks_st.1/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(5)     Reshape                 0.976840           3.28119    int8
/blocks_st.1/Add_1                                  BPU  id(5)     HzSElementwiseAdd       0.991703           34.9277    int8
/blocks_st.1/norm1_t/ReduceMean                     BPU  id(5)     HzSQuantizedReduceMean  0.971034           35.0106    int8
/blocks_st.1/norm1_t/Sub                            BPU  id(5)     HzSElementwiseSub       0.991496           35.0106    int8
/blocks_st.1/norm1_t/Pow                            BPU  id(5)     HzLut                   0.998124           34.9672    int8
/blocks_st.1/norm1_t/ReduceMean_1                   BPU  id(5)     HzSQuantizedReduceMean  0.999346           1222.7     int8
/blocks_st.1/norm1_t/Div_reciprocal                 BPU  id(5)     HzLut                   0.999843           13.1117    int8
/blocks_st.1/norm1_t/Div_mul                        BPU  id(5)     HzSElementwiseMul       0.991010           34.9672    int8
/blocks_st.1/norm1_t/Mul                            BPU  id(5)     HzSElementwiseMul       0.984830           13.0493    int8
/blocks_st.1/norm1_t/Add_1                          BPU  id(5)     HzSElementwiseAdd       0.982591           5.97009    int8
/blocks_st.1/attn_t/q_linear/MatMul_reshape_input   BPU  id(5)     Reshape                 0.982591           5.97487    int8
/blocks_st.1/attn_t/q_linear/MatMul                 BPU  id(5)     HzSQuantizedConv        0.993481           5.97487    int8
...cks_st.1/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(5)     Reshape                 0.993482           6.46746    int8
/blocks_st.1/attn_t/k_linear/MatMul                 BPU  id(5)     HzSQuantizedConv        0.990639           5.97487    int8
...cks_st.1/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(5)     Reshape                 0.990648           6.24281    int8
/blocks_st.1/attn_t/v_linear/MatMul                 BPU  id(5)     HzSQuantizedConv        0.946226           5.97487    int8
...cks_st.1/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(5)     Reshape                 0.946228           4.18393    int8
/blocks_st.1/attn_t/Transpose_3                     BPU  id(5)     Transpose               0.993480           6.46746    int8
/blocks_st.1/attn_t/Transpose_4                     BPU  id(5)     Transpose               0.946231           4.18393    int8
/blocks_st.1/attn_t/Transpose_5                     BPU  id(5)     Transpose               0.990639           6.24281    int8
/blocks_st.1/attn_t/MatMul                          BPU  id(5)     HzSQuantizedMatmul      0.996718           6.46746    int8
/blocks_st.1/attn_t/Mul                             BPU  id(5)     HzSElementwiseMul       0.996725           159.762    int8
/blocks_st.1/attn_t/Softmax                         CPU  --        Softmax                 0.930826           31.0664    float
/blocks_st.1/attn_t/MatMul_1                        BPU  id(7)     HzSQuantizedMatmul      0.956418           0.897314   int8
/blocks_st.1/attn_t/Transpose_6                     BPU  id(7)     Transpose               0.956415           4.00952    int8
/blocks_st.1/attn_t/Reshape_6                       BPU  id(7)     Reshape                 0.956415           4.00952    int8
/blocks_st.1/attn_t/proj/MatMul                     BPU  id(7)     HzSQuantizedConv        0.970403           4.00952    int8
.../blocks_st.1/attn_t/proj/Add_output_0_Reshape_0  BPU  id(7)     Reshape                 0.970404           7.26846    int8
/blocks_st.1/Add_2                                  BPU  id(7)     HzSElementwiseAdd       0.991606           35.0106    int8
/blocks_st.1/norm2_t/ReduceMean                     BPU  id(7)     HzSQuantizedReduceMean  0.951594           35.0932    int8
/blocks_st.1/norm2_t/Sub                            BPU  id(7)     HzSElementwiseSub       0.991466           35.0932    int8
/blocks_st.1/norm2_t/Pow                            BPU  id(7)     HzLut                   0.998087           35.0314    int8
/blocks_st.1/norm2_t/ReduceMean_1                   BPU  id(7)     HzSQuantizedReduceMean  0.999352           1227.2     int8
/blocks_st.1/norm2_t/Div_reciprocal                 BPU  id(7)     HzLut                   0.999840           12.5203    int8
/blocks_st.1/norm2_t/Div_mul                        BPU  id(7)     HzSElementwiseMul       0.990945           35.0314    int8
/blocks_st.1/mlp_t/fc1/MatMul_reshape_input         BPU  id(7)     Reshape                 0.990945           13.1692    int8
/blocks_st.1/mlp_t/fc1/MatMul                       BPU  id(7)     HzSQuantizedConv        0.993947           13.1692    int8
/blocks_st.1/mlp_t/act/Mul_1                        BPU  id(7)     HzLut                   0.953474           6.89879    int8
/blocks_st.1/mlp_t/fc2/MatMul                       BPU  id(7)     HzSQuantizedConv        0.956616           3.30488    int8
...dd/blocks_st.1/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(7)     Reshape                 0.956611           3.36449    int8
/blocks_st.1/Add_3                                  BPU  id(7)     HzSElementwiseAdd       0.989257           35.0932    int8
/blocks_ts.1/norm1_t/Pow                            BPU  id(4)     HzLut                   0.998771           34.7462    int8
/blocks_ts.1/norm1_t/ReduceMean_1                   BPU  id(4)     HzSQuantizedReduceMean  0.999667           1207.3     int8
/blocks_ts.1/norm1_t/Div_reciprocal                 BPU  id(4)     HzLut                   0.999931           12.8551    int8
/blocks_ts.1/norm1_t/Div_mul                        BPU  id(4)     HzSElementwiseMul       0.994807           34.7462    int8
/blocks_ts.1/norm1_t/Mul                            BPU  id(4)     HzSElementwiseMul       0.983008           12.9401    int8
/blocks_ts.1/norm1_t/Add_1                          BPU  id(4)     HzSElementwiseAdd       0.979078           2.28302    int8
/blocks_ts.1/attn_t/q_linear/MatMul_reshape_input   BPU  id(4)     Reshape                 0.979078           2.24396    int8
/blocks_ts.1/attn_t/q_linear/MatMul                 BPU  id(4)     HzSQuantizedConv        0.997126           2.24396    int8
...cks_ts.1/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(4)     Reshape                 0.997134           5.61075    int8
/blocks_ts.1/attn_t/k_linear/MatMul                 BPU  id(4)     HzSQuantizedConv        0.981454           2.24396    int8
...cks_ts.1/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(4)     Reshape                 0.981455           6.05022    int8
/blocks_ts.1/attn_t/v_linear/MatMul                 BPU  id(4)     HzSQuantizedConv        0.928596           2.24396    int8
...cks_ts.1/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(4)     Reshape                 0.928596           2.71923    int8
/blocks_ts.1/attn_t/Transpose_3                     BPU  id(4)     Transpose               0.997139           5.61075    int8
/blocks_ts.1/attn_t/Transpose_4                     BPU  id(4)     Transpose               0.928597           2.71923    int8
/blocks_ts.1/attn_t/Transpose_5                     BPU  id(4)     Transpose               0.981454           6.05022    int8
/blocks_ts.1/attn_t/MatMul                          BPU  id(4)     HzSQuantizedMatmul      0.981753           5.61075    int8
/blocks_ts.1/attn_t/Mul                             BPU  id(4)     HzSElementwiseMul       0.981744           266.453    int8
/blocks_ts.1/attn_t/Softmax                         CPU  --        Softmax                 0.853005           51.8129    float
/blocks_ts.1/attn_t/MatMul_1                        BPU  id(6)     HzSQuantizedMatmul      0.920966           0.997137   int8
/blocks_ts.1/attn_t/Transpose_6                     BPU  id(6)     Transpose               0.920968           2.30683    int8
/blocks_ts.1/attn_t/Reshape_6                       BPU  id(6)     Reshape                 0.920968           2.30683    int8
/blocks_ts.1/attn_t/proj/MatMul                     BPU  id(6)     HzSQuantizedConv        0.929176           2.30683    int8
.../blocks_ts.1/attn_t/proj/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.929175           4.07621    int8
/blocks_ts.1/Add                                    BPU  id(6)     HzSElementwiseAdd       0.994873           34.7594    int8
/blocks_ts.1/norm2_t/ReduceMean                     BPU  id(6)     HzSQuantizedReduceMean  0.978863           34.7889    int8
/blocks_ts.1/norm2_t/Sub                            BPU  id(6)     HzSElementwiseSub       0.994621           34.7889    int8
/blocks_ts.1/norm2_t/Pow                            BPU  id(6)     HzLut                   0.998730           34.7672    int8
/blocks_ts.1/norm2_t/ReduceMean_1                   BPU  id(6)     HzSQuantizedReduceMean  0.999635           1208.76    int8
/blocks_ts.1/norm2_t/Div_reciprocal                 BPU  id(6)     HzLut                   0.999926           12.8785    int8
/blocks_ts.1/norm2_t/Div_mul                        BPU  id(6)     HzSElementwiseMul       0.994249           34.7672    int8
/blocks_ts.1/mlp_t/fc1/MatMul_reshape_input         BPU  id(6)     Reshape                 0.994249           12.9405    int8
/blocks_ts.1/mlp_t/fc1/MatMul                       BPU  id(6)     HzSQuantizedConv        0.996395           12.9405    int8
/blocks_ts.1/mlp_t/act/Mul_1                        BPU  id(6)     HzLut                   0.964467           8.24381    int8
/blocks_ts.1/mlp_t/fc2/MatMul                       BPU  id(6)     HzSQuantizedConv        0.984118           4.88918    int8
...dd/blocks_ts.1/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.984125           4.18644    int8
/blocks_ts.1/Add_1                                  BPU  id(6)     HzSElementwiseAdd       0.993757           34.7889    int8
/blocks_ts.1/norm1_s/ReduceMean                     BPU  id(6)     HzSQuantizedReduceMean  0.970672           34.7791    int8
/blocks_ts.1/norm1_s/Sub                            BPU  id(6)     HzSElementwiseSub       0.993524           34.7791    int8
/blocks_ts.1/norm1_s/Pow                            BPU  id(6)     HzLut                   0.998684           34.736     int8
/blocks_ts.1/norm1_s/ReduceMean_1                   BPU  id(6)     HzSQuantizedReduceMean  0.999571           1206.59    int8
/blocks_ts.1/norm1_s/Div_reciprocal                 BPU  id(6)     HzLut                   0.999919           13.1225    int8
/blocks_ts.1/norm1_s/Div_mul                        BPU  id(6)     HzSElementwiseMul       0.993130           34.736     int8
/blocks_ts.1/norm1_s/Mul                            BPU  id(6)     HzSElementwiseMul       0.984584           12.768     int8
/blocks_ts.1/norm1_s/Add_1                          BPU  id(6)     HzSElementwiseAdd       0.982366           5.60615    int8
/blocks_ts.1/attn_s/q_linear/MatMul_reshape_input   BPU  id(6)     Reshape                 0.982366           5.54266    int8
/blocks_ts.1/attn_s/q_linear/MatMul                 BPU  id(6)     HzSQuantizedConv        0.995098           5.54266    int8
...cks_ts.1/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.995096           4.55103    int8
/blocks_ts.1/attn_s/Transpose                       BPU  id(6)     Transpose               0.995096           4.55103    int8
/blocks_ts.1/attn_s/k_linear/MatMul                 BPU  id(6)     HzSQuantizedConv        0.993142           5.54266    int8
...cks_ts.1/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.993142           4.62446    int8
/blocks_ts.1/attn_s/v_linear/MatMul                 BPU  id(6)     HzSQuantizedConv        0.989094           5.54266    int8
...cks_ts.1/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(6)     Reshape                 0.989093           4.54093    int8
/blocks_ts.1/attn_s/Transpose_1                     BPU  id(6)     Transpose               0.989093           4.54093    int8
/blocks_ts.1/attn_s/Transpose_2                     BPU  id(6)     Transpose               0.993141           4.62446    int8
/blocks_ts.1/attn_s/MatMul                          BPU  id(6)     HzSQuantizedMatmul      0.993819           4.55103    int8
/blocks_ts.1/attn_s/Mul                             BPU  id(6)     HzSElementwiseMul       0.993815           100.422    int8
/blocks_ts.1/attn_s/Softmax                         CPU  --        Softmax                 0.988800           19.5275    float
/blocks_ts.1/attn_s/MatMul_1                        BPU  id(7)     HzSQuantizedMatmul      0.966316           0.997698   int8
/blocks_ts.1/attn_s/Transpose_3                     BPU  id(7)     Transpose               0.966316           3.3514     int8
/blocks_ts.1/attn_s/Reshape_3                       BPU  id(7)     Reshape                 0.966316           3.3514     int8
/blocks_ts.1/attn_s/proj/MatMul                     BPU  id(7)     HzSQuantizedConv        0.970395           3.3514     int8
.../blocks_ts.1/attn_s/proj/Add_output_0_Reshape_0  BPU  id(7)     Reshape                 0.970396           6.53714    int8
/blocks_ts.1/Add_2                                  BPU  id(7)     HzSElementwiseAdd       0.991307           34.7791    int8
/blocks_ts.1/norm2_s/ReduceMean                     BPU  id(7)     HzSQuantizedReduceMean  0.970698           34.8974    int8
/blocks_ts.1/norm2_s/Sub                            BPU  id(7)     HzSElementwiseSub       0.991033           34.8974    int8
/blocks_ts.1/norm2_s/Pow                            BPU  id(7)     HzLut                   0.998133           34.8402    int8
/blocks_ts.1/norm2_s/ReduceMean_1                   BPU  id(7)     HzSQuantizedReduceMean  0.999372           1213.84    int8
/blocks_ts.1/norm2_s/Div_reciprocal                 BPU  id(7)     HzLut                   0.999856           13.75      int8
/blocks_ts.1/norm2_s/Div_mul                        BPU  id(7)     HzSElementwiseMul       0.990583           34.8402    int8
/blocks_ts.1/mlp_s/fc1/MatMul_reshape_input         BPU  id(7)     Reshape                 0.990583           12.7154    int8
/blocks_ts.1/mlp_s/fc1/MatMul                       BPU  id(7)     HzSQuantizedConv        0.990843           12.7154    int8
/blocks_ts.1/mlp_s/act/Mul_1                        BPU  id(7)     HzLut                   0.959036           8.52022    int8
/blocks_ts.1/mlp_s/fc2/MatMul                       BPU  id(7)     HzSQuantizedConv        0.967674           5.56488    int8
...dd/blocks_ts.1/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(7)     Reshape                 0.967674           4.49488    int8
/blocks_ts.1/Add_3                                  BPU  id(7)     HzSElementwiseAdd       0.989519           34.8974    int8
/blocks_ts.1/Add_3_output_0_calibrated_Requantize   BPU  id(7)     HzRequantize            --                 --         int16
/Concat_1                                           BPU  id(7)     Concat                  0.989395           35.0578    int16
/ts_attn.1/MatMul_reshape_input                     BPU  id(7)     Reshape                 0.989395           35.0578    int16
...0_reshape_in_transpose_in_calibrated_Requantize  BPU  id(7)     HzRequantize            --                 --         int16
/ts_attn.1/MatMul                                   BPU  id(7)     HzSQuantizedConv        0.997873           35.0578    int8
/ts_attn.1/Add/ts_attn.1/Add_output_0_Reshape_0     CPU  --        Reshape                 0.997873           --         float
/Softmax_1                                          CPU  --        Softmax                 0.999622           --         float
/Slice_2                                            BPU  id(8)     Slice                   0.999709           --         int8
/Mul_2                                              BPU  id(8)     HzSElementwiseMul       0.987183           35.0578    int16
/Slice_3                                            BPU  id(8)     Slice                   0.999486           --         int8
/Mul_3                                              BPU  id(8)     HzSElementwiseMul       0.988462           34.9089    int16
/Add_3                                              BPU  id(8)     HzSElementwiseAdd       0.990392           31.4971    int8
/blocks_st.2/norm1_s/ReduceMean                     BPU  id(8)     HzSQuantizedReduceMean  0.957902           35.0195    int8
/blocks_st.2/norm1_s/Sub                            BPU  id(8)     HzSElementwiseSub       0.990207           35.0195    int8
/blocks_st.2/norm1_s/Pow                            BPU  id(8)     HzLut                   0.998137           34.938     int8
/blocks_st.2/norm1_s/ReduceMean_1                   BPU  id(8)     HzSQuantizedReduceMean  0.999394           1220.67    int8
/blocks_st.2/norm1_s/Div_reciprocal                 BPU  id(8)     HzLut                   0.999864           12.0817    int8
/blocks_st.2/norm1_s/Div_mul                        BPU  id(8)     HzSElementwiseMul       0.989613           34.938     int8
/blocks_st.2/norm1_s/Mul                            BPU  id(8)     HzSElementwiseMul       0.979478           13.2171    int8
/blocks_st.2/norm1_s/Add_1                          BPU  id(8)     HzSElementwiseAdd       0.977485           7.34087    int8
/blocks_st.2/attn_s/q_linear/MatMul_reshape_input   BPU  id(8)     Reshape                 0.977485           7.28996    int8
/blocks_st.2/attn_s/q_linear/MatMul                 BPU  id(8)     HzSQuantizedConv        0.993472           7.28996    int8
...cks_st.2/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(8)     Reshape                 0.993473           4.84906    int8
/blocks_st.2/attn_s/Transpose                       BPU  id(8)     Transpose               0.993473           4.84906    int8
/blocks_st.2/attn_s/k_linear/MatMul                 BPU  id(8)     HzSQuantizedConv        0.989883           7.28996    int8
...cks_st.2/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(8)     Reshape                 0.989883           4.61527    int8
/blocks_st.2/attn_s/v_linear/MatMul                 BPU  id(8)     HzSQuantizedConv        0.983208           7.28996    int8
...cks_st.2/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(8)     Reshape                 0.983211           4.98733    int8
/blocks_st.2/attn_s/Transpose_1                     BPU  id(8)     Transpose               0.983211           4.98733    int8
/blocks_st.2/attn_s/Transpose_2                     BPU  id(8)     Transpose               0.989883           4.61527    int8
/blocks_st.2/attn_s/MatMul                          BPU  id(8)     HzSQuantizedMatmul      0.990345           4.84906    int8
/blocks_st.2/attn_s/Mul                             BPU  id(8)     HzSElementwiseMul       0.990341           69.4382    int8
/blocks_st.2/attn_s/Softmax                         CPU  --        Softmax                 0.989510           13.5026    float
/blocks_st.2/attn_s/MatMul_1                        BPU  id(9)     HzSQuantizedMatmul      0.956493           0.997061   int8
/blocks_st.2/attn_s/Transpose_3                     BPU  id(9)     Transpose               0.956493           3.78051    int8
/blocks_st.2/attn_s/Reshape_3                       BPU  id(9)     Reshape                 0.956493           3.78051    int8
/blocks_st.2/attn_s/proj/MatMul                     BPU  id(9)     HzSQuantizedConv        0.963793           3.78051    int8
.../blocks_st.2/attn_s/proj/Add_output_0_Reshape_0  BPU  id(9)     Reshape                 0.963794           4.73367    int8
/blocks_st.2/Add                                    BPU  id(9)     HzSElementwiseAdd       0.988462           35.0195    int8
/blocks_st.2/norm2_s/ReduceMean                     BPU  id(9)     HzSQuantizedReduceMean  0.953529           35.0561    int8
/blocks_st.2/norm2_s/Sub                            BPU  id(9)     HzSElementwiseSub       0.988294           35.0561    int8
/blocks_st.2/norm2_s/Pow                            BPU  id(9)     HzLut                   0.997715           34.9674    int8
/blocks_st.2/norm2_s/ReduceMean_1                   BPU  id(9)     HzSQuantizedReduceMean  0.999185           1222.72    int8
/blocks_st.2/norm2_s/Div_reciprocal                 BPU  id(9)     HzLut                   0.999798           12.5744    int8
/blocks_st.2/norm2_s/Div_mul                        BPU  id(9)     HzSElementwiseMul       0.987711           34.9674    int8
/blocks_st.2/mlp_s/fc1/MatMul_reshape_input         BPU  id(9)     Reshape                 0.987711           13.251     int8
/blocks_st.2/mlp_s/fc1/MatMul                       BPU  id(9)     HzSQuantizedConv        0.990075           13.251     int8
/blocks_st.2/mlp_s/act/Mul_1                        BPU  id(9)     HzLut                   0.948250           9.37203    int8
/blocks_st.2/mlp_s/fc2/MatMul                       BPU  id(9)     HzSQuantizedConv        0.953664           5.9269     int8
...dd/blocks_st.2/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(9)     Reshape                 0.953662           5.605      int8
/blocks_st.2/Add_1                                  BPU  id(9)     HzSElementwiseAdd       0.986193           35.0561    int8
/blocks_st.2/norm1_t/ReduceMean                     BPU  id(9)     HzSQuantizedReduceMean  0.933971           35.0034    int8
/blocks_st.2/norm1_t/Sub                            BPU  id(9)     HzSElementwiseSub       0.986065           35.0034    int8
/blocks_st.2/norm1_t/Pow                            BPU  id(9)     HzLut                   0.997367           34.9159    int8
/blocks_st.2/norm1_t/ReduceMean_1                   BPU  id(9)     HzSQuantizedReduceMean  0.999187           1219.12    int8
/blocks_st.2/norm1_t/Div_reciprocal                 BPU  id(9)     HzLut                   0.999795           14.0047    int8
/blocks_st.2/norm1_t/Div_mul                        BPU  id(9)     HzSElementwiseMul       0.985324           34.9159    int8
/blocks_st.2/norm1_t/Mul                            BPU  id(9)     HzSElementwiseMul       0.968560           13.1252    int8
/blocks_st.2/norm1_t/Add_1                          BPU  id(9)     HzSElementwiseAdd       0.966581           3.33486    int8
/blocks_st.2/attn_t/q_linear/MatMul_reshape_input   BPU  id(9)     Reshape                 0.966581           3.07049    int8
/blocks_st.2/attn_t/q_linear/MatMul                 BPU  id(9)     HzSQuantizedConv        0.985087           3.07049    int8
...cks_st.2/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(9)     Reshape                 0.985089           5.38651    int8
/blocks_st.2/attn_t/k_linear/MatMul                 BPU  id(9)     HzSQuantizedConv        0.970292           3.07049    int8
...cks_st.2/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(9)     Reshape                 0.970291           5.49701    int8
/blocks_st.2/attn_t/v_linear/MatMul                 BPU  id(9)     HzSQuantizedConv        0.935291           3.07049    int8
...cks_st.2/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(9)     Reshape                 0.935291           3.59843    int8
/blocks_st.2/attn_t/Transpose_3                     BPU  id(9)     Transpose               0.985087           5.38651    int8
/blocks_st.2/attn_t/Transpose_4                     BPU  id(9)     Transpose               0.935289           3.59843    int8
/blocks_st.2/attn_t/Transpose_5                     BPU  id(9)     Transpose               0.970292           5.49701    int8
/blocks_st.2/attn_t/MatMul                          BPU  id(9)     HzSQuantizedMatmul      0.972339           5.38651    int8
/blocks_st.2/attn_t/Mul                             BPU  id(9)     HzSElementwiseMul       0.972352           140.865    int8
/blocks_st.2/attn_t/Softmax                         CPU  --        Softmax                 0.832161           27.3918    float
/blocks_st.2/attn_t/MatMul_1                        BPU  id(11)    HzSQuantizedMatmul      0.953751           0.929051   int8
/blocks_st.2/attn_t/Transpose_6                     BPU  id(11)    Transpose               0.953746           2.94574    int8
/blocks_st.2/attn_t/Reshape_6                       BPU  id(11)    Reshape                 0.953746           2.94574    int8
/blocks_st.2/attn_t/proj/MatMul                     BPU  id(11)    HzSQuantizedConv        0.948476           2.94574    int8
.../blocks_st.2/attn_t/proj/Add_output_0_Reshape_0  BPU  id(11)    Reshape                 0.948481           4.50241    int8
/blocks_st.2/Add_2                                  BPU  id(11)    HzSElementwiseAdd       0.984194           35.0034    int8
/blocks_st.2/norm2_t/ReduceMean                     BPU  id(11)    HzSQuantizedReduceMean  0.935563           35.0429    int8
/blocks_st.2/norm2_t/Sub                            BPU  id(11)    HzSElementwiseSub       0.984043           35.0429    int8
/blocks_st.2/norm2_t/Pow                            BPU  id(11)    HzLut                   0.997269           34.9463    int8
/blocks_st.2/norm2_t/ReduceMean_1                   BPU  id(11)    HzSQuantizedReduceMean  0.999154           1221.24    int8
/blocks_st.2/norm2_t/Div_reciprocal                 BPU  id(11)    HzLut                   0.999790           13.3577    int8
/blocks_st.2/norm2_t/Div_mul                        BPU  id(11)    HzSElementwiseMul       0.983422           34.9463    int8
/blocks_st.2/mlp_t/fc1/MatMul_reshape_input         BPU  id(11)    Reshape                 0.983422           13.189     int8
/blocks_st.2/mlp_t/fc1/MatMul                       BPU  id(11)    HzSQuantizedConv        0.982394           13.189     int8
/blocks_st.2/mlp_t/act/Mul_1                        BPU  id(11)    HzLut                   0.917518           9.39034    int8
/blocks_st.2/mlp_t/fc2/MatMul                       BPU  id(11)    HzSQuantizedConv        0.921139           5.28426    int8
...dd/blocks_st.2/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(11)    Reshape                 0.921137           5.56991    int8
/blocks_st.2/Add_3                                  BPU  id(11)    HzSElementwiseAdd       0.981765           35.0429    int8
/blocks_ts.2/norm1_t/Pow                            BPU  id(8)     HzLut                   0.998137           34.938     int8
/blocks_ts.2/norm1_t/ReduceMean_1                   BPU  id(8)     HzSQuantizedReduceMean  0.999394           1220.67    int8
/blocks_ts.2/norm1_t/Div_reciprocal                 BPU  id(8)     HzLut                   0.999864           12.0817    int8
/blocks_ts.2/norm1_t/Div_mul                        BPU  id(8)     HzSElementwiseMul       0.989613           34.938     int8
/blocks_ts.2/norm1_t/Mul                            BPU  id(8)     HzSElementwiseMul       0.981470           13.2171    int8
/blocks_ts.2/norm1_t/Add_1                          BPU  id(8)     HzSElementwiseAdd       0.979561           6.55773    int8
/blocks_ts.2/attn_t/q_linear/MatMul_reshape_input   BPU  id(8)     Reshape                 0.979561           6.54623    int8
/blocks_ts.2/attn_t/q_linear/MatMul                 BPU  id(8)     HzSQuantizedConv        0.989790           6.54623    int8
...cks_ts.2/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(8)     Reshape                 0.989788           6.43804    int8
/blocks_ts.2/attn_t/k_linear/MatMul                 BPU  id(8)     HzSQuantizedConv        0.985598           6.54623    int8
...cks_ts.2/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(8)     Reshape                 0.985598           6.14544    int8
/blocks_ts.2/attn_t/v_linear/MatMul                 BPU  id(8)     HzSQuantizedConv        0.920798           6.54623    int8
...cks_ts.2/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(8)     Reshape                 0.920795           4.28685    int8
/blocks_ts.2/attn_t/Transpose_3                     BPU  id(8)     Transpose               0.989788           6.43804    int8
/blocks_ts.2/attn_t/Transpose_4                     BPU  id(8)     Transpose               0.920798           4.28685    int8
/blocks_ts.2/attn_t/Transpose_5                     BPU  id(8)     Transpose               0.985599           6.14544    int8
/blocks_ts.2/attn_t/MatMul                          BPU  id(8)     HzSQuantizedMatmul      0.989642           6.43804    int8
/blocks_ts.2/attn_t/Mul                             BPU  id(8)     HzSElementwiseMul       0.989626           164.282    int8
/blocks_ts.2/attn_t/Softmax                         CPU  --        Softmax                 0.842229           31.9453    float
/blocks_ts.2/attn_t/MatMul_1                        BPU  id(10)    HzSQuantizedMatmul      0.943424           0.931974   int8
/blocks_ts.2/attn_t/Transpose_6                     BPU  id(10)    Transpose               0.943422           3.01333    int8
/blocks_ts.2/attn_t/Reshape_6                       BPU  id(10)    Reshape                 0.943422           3.01333    int8
/blocks_ts.2/attn_t/proj/MatMul                     BPU  id(10)    HzSQuantizedConv        0.929149           3.01333    int8
.../blocks_ts.2/attn_t/proj/Add_output_0_Reshape_0  BPU  id(10)    Reshape                 0.929149           3.90334    int8
/blocks_ts.2/Add                                    BPU  id(10)    HzSElementwiseAdd       0.988203           35.0195    int8
/blocks_ts.2/norm2_t/ReduceMean                     BPU  id(10)    HzSQuantizedReduceMean  0.938866           35.0409    int8
/blocks_ts.2/norm2_t/Sub                            BPU  id(10)    HzSElementwiseSub       0.988065           35.0409    int8
/blocks_ts.2/norm2_t/Pow                            BPU  id(10)    HzLut                   0.997851           34.9524    int8
/blocks_ts.2/norm2_t/ReduceMean_1                   BPU  id(10)    HzSQuantizedReduceMean  0.999347           1221.67    int8
/blocks_ts.2/norm2_t/Div_reciprocal                 BPU  id(10)    HzLut                   0.999841           12.4195    int8
/blocks_ts.2/norm2_t/Div_mul                        BPU  id(10)    HzSElementwiseMul       0.987528           34.9524    int8
/blocks_ts.2/mlp_t/fc1/MatMul_reshape_input         BPU  id(10)    Reshape                 0.987528           13.187     int8
/blocks_ts.2/mlp_t/fc1/MatMul                       BPU  id(10)    HzSQuantizedConv        0.987635           13.187     int8
/blocks_ts.2/mlp_t/act/Mul_1                        BPU  id(10)    HzLut                   0.917468           9.27169    int8
/blocks_ts.2/mlp_t/fc2/MatMul                       BPU  id(10)    HzSQuantizedConv        0.923218           5.58236    int8
...dd/blocks_ts.2/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(10)    Reshape                 0.923217           4.57042    int8
/blocks_ts.2/Add_1                                  BPU  id(10)    HzSElementwiseAdd       0.985745           35.0409    int8
/blocks_ts.2/norm1_s/ReduceMean                     BPU  id(10)    HzSQuantizedReduceMean  0.932653           34.8554    int8
/blocks_ts.2/norm1_s/Sub                            BPU  id(10)    HzSElementwiseSub       0.985607           34.8554    int8
/blocks_ts.2/norm1_s/Pow                            BPU  id(10)    HzLut                   0.997643           34.7635    int8
/blocks_ts.2/norm1_s/ReduceMean_1                   BPU  id(10)    HzSQuantizedReduceMean  0.999296           1208.5     int8
/blocks_ts.2/norm1_s/Div_reciprocal                 BPU  id(10)    HzLut                   0.999812           13.1464    int8
/blocks_ts.2/norm1_s/Div_mul                        BPU  id(10)    HzSElementwiseMul       0.985017           34.7635    int8
/blocks_ts.2/norm1_s/Mul                            BPU  id(10)    HzSElementwiseMul       0.971753           13.0743    int8
/blocks_ts.2/norm1_s/Add_1                          BPU  id(10)    HzSElementwiseAdd       0.969643           6.37488    int8
/blocks_ts.2/attn_s/q_linear/MatMul_reshape_input   BPU  id(10)    Reshape                 0.969643           6.43815    int8
/blocks_ts.2/attn_s/q_linear/MatMul                 BPU  id(10)    HzSQuantizedConv        0.989139           6.43815    int8
...cks_ts.2/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(10)    Reshape                 0.989135           4.78062    int8
/blocks_ts.2/attn_s/Transpose                       BPU  id(10)    Transpose               0.989135           4.78062    int8
/blocks_ts.2/attn_s/k_linear/MatMul                 BPU  id(10)    HzSQuantizedConv        0.987958           6.43815    int8
...cks_ts.2/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(10)    Reshape                 0.987959           5.12002    int8
/blocks_ts.2/attn_s/v_linear/MatMul                 BPU  id(10)    HzSQuantizedConv        0.972618           6.43815    int8
...cks_ts.2/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(10)    Reshape                 0.972615           4.9988     int8
/blocks_ts.2/attn_s/Transpose_1                     BPU  id(10)    Transpose               0.972615           4.9988     int8
/blocks_ts.2/attn_s/Transpose_2                     BPU  id(10)    Transpose               0.987959           5.12002    int8
/blocks_ts.2/attn_s/MatMul                          BPU  id(10)    HzSQuantizedMatmul      0.988734           4.78062    int8
/blocks_ts.2/attn_s/Mul                             BPU  id(10)    HzSElementwiseMul       0.988736           124.911    int8
/blocks_ts.2/attn_s/Softmax                         CPU  --        Softmax                 0.976092           24.2895    float
/blocks_ts.2/attn_s/MatMul_1                        BPU  id(11)    HzSQuantizedMatmul      0.937991           0.999748   int8
/blocks_ts.2/attn_s/Transpose_3                     BPU  id(11)    Transpose               0.937991           3.9307     int8
/blocks_ts.2/attn_s/Reshape_3                       BPU  id(11)    Reshape                 0.937991           3.9307     int8
/blocks_ts.2/attn_s/proj/MatMul                     BPU  id(11)    HzSQuantizedConv        0.939442           3.9307     int8
.../blocks_ts.2/attn_s/proj/Add_output_0_Reshape_0  BPU  id(11)    Reshape                 0.939442           5.92938    int8
/blocks_ts.2/Add_2                                  BPU  id(11)    HzSElementwiseAdd       0.981311           34.8554    int8
/blocks_ts.2/norm2_s/ReduceMean                     BPU  id(11)    HzSQuantizedReduceMean  0.903153           34.8822    int8
/blocks_ts.2/norm2_s/Sub                            BPU  id(11)    HzSElementwiseSub       0.981224           34.8822    int8
/blocks_ts.2/norm2_s/Pow                            BPU  id(11)    HzLut                   0.996924           34.7751    int8
/blocks_ts.2/norm2_s/ReduceMean_1                   BPU  id(11)    HzSQuantizedReduceMean  0.999323           1209.31    int8
/blocks_ts.2/norm2_s/Div_reciprocal                 BPU  id(11)    HzLut                   0.999834           13.3751    int8
/blocks_ts.2/norm2_s/Div_mul                        BPU  id(11)    HzSElementwiseMul       0.980726           34.7751    int8
/blocks_ts.2/mlp_s/fc1/MatMul_reshape_input         BPU  id(11)    Reshape                 0.980726           12.9875    int8
/blocks_ts.2/mlp_s/fc1/MatMul                       BPU  id(11)    HzSQuantizedConv        0.983736           12.9875    int8
/blocks_ts.2/mlp_s/act/Mul_1                        BPU  id(11)    HzLut                   0.920732           8.30858    int8
/blocks_ts.2/mlp_s/fc2/MatMul                       BPU  id(11)    HzSQuantizedConv        0.933331           5.41145    int8
...dd/blocks_ts.2/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(11)    Reshape                 0.933334           5.69955    int8
/blocks_ts.2/Add_3                                  BPU  id(11)    HzSElementwiseAdd       0.978783           34.8822    int8
/blocks_ts.2/Add_3_output_0_calibrated_Requantize   BPU  id(11)    HzRequantize            --                 --         int16
/Concat_2                                           BPU  id(11)    Concat                  0.980240           35.0208    int16
/ts_attn.2/MatMul_reshape_input                     BPU  id(11)    Reshape                 0.980240           35.0208    int16
...0_reshape_in_transpose_in_calibrated_Requantize  BPU  id(11)    HzRequantize            --                 --         int16
/ts_attn.2/MatMul                                   BPU  id(11)    HzSQuantizedConv        0.995512           35.0208    int8
/ts_attn.2/Add/ts_attn.2/Add_output_0_Reshape_0     CPU  --        Reshape                 0.995512           --         float
/Softmax_2                                          CPU  --        Softmax                 0.998993           --         float
/Slice_4                                            BPU  id(12)    Slice                   0.999207           --         int8
/Mul_4                                              BPU  id(12)    HzSElementwiseMul       0.979763           35.0208    int16
/Slice_5                                            BPU  id(12)    Slice                   0.998827           --         int8
/Mul_5                                              BPU  id(12)    HzSElementwiseMul       0.975741           34.8861    int16
/Add_4                                              BPU  id(12)    HzSElementwiseAdd       0.982156           31.1564    int8
余弦相似度Part2:
/blocks_st.3/norm1_s/ReduceMean                     BPU  id(12)    HzSQuantizedReduceMean  0.922345           34.9949    int8
/blocks_st.3/norm1_s/Sub                            BPU  id(12)    HzSElementwiseSub       0.982040           34.9949    int8
/blocks_st.3/norm1_s/Pow                            BPU  id(12)    HzLut                   0.997341           34.8924    int8
/blocks_st.3/norm1_s/ReduceMean_1                   BPU  id(12)    HzSQuantizedReduceMean  0.999233           1217.48    int8
/blocks_st.3/norm1_s/Div_reciprocal                 BPU  id(12)    HzLut                   0.999796           13.6886    int8
/blocks_st.3/norm1_s/Div_mul                        BPU  id(12)    HzSElementwiseMul       0.981551           34.8924    int8
/blocks_st.3/norm1_s/Mul                            BPU  id(12)    HzSElementwiseMul       0.968972           13.2828    int8
/blocks_st.3/norm1_s/Add_1                          BPU  id(12)    HzSElementwiseAdd       0.966921           8.34207    int8
/blocks_st.3/attn_s/q_linear/MatMul_reshape_input   BPU  id(12)    Reshape                 0.966921           8.2843     int8
/blocks_st.3/attn_s/q_linear/MatMul                 BPU  id(12)    HzSQuantizedConv        0.986810           8.2843     int8
...cks_st.3/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(12)    Reshape                 0.986810           5.10176    int8
/blocks_st.3/attn_s/Transpose                       BPU  id(12)    Transpose               0.986810           5.10176    int8
/blocks_st.3/attn_s/k_linear/MatMul                 BPU  id(12)    HzSQuantizedConv        0.984410           8.2843     int8
...cks_st.3/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(12)    Reshape                 0.984405           6.03716    int8
/blocks_st.3/attn_s/v_linear/MatMul                 BPU  id(12)    HzSQuantizedConv        0.962391           8.2843     int8
...cks_st.3/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(12)    Reshape                 0.962391           4.76599    int8
/blocks_st.3/attn_s/Transpose_1                     BPU  id(12)    Transpose               0.962391           4.76599    int8
/blocks_st.3/attn_s/Transpose_2                     BPU  id(12)    Transpose               0.984405           6.03716    int8
/blocks_st.3/attn_s/MatMul                          BPU  id(12)    HzSQuantizedMatmul      0.986442           5.10176    int8
/blocks_st.3/attn_s/Mul                             BPU  id(12)    HzSElementwiseMul       0.986433           115.976    int8
/blocks_st.3/attn_s/Softmax                         CPU  --        Softmax                 0.976933           22.552     float
/blocks_st.3/attn_s/MatMul_1                        BPU  id(13)    HzSQuantizedMatmul      0.923612           0.99609    int8
/blocks_st.3/attn_s/Transpose_3                     BPU  id(13)    Transpose               0.923612           4.43483    int8
/blocks_st.3/attn_s/Reshape_3                       BPU  id(13)    Reshape                 0.923612           4.43483    int8
/blocks_st.3/attn_s/proj/MatMul                     BPU  id(13)    HzSQuantizedConv        0.934319           4.43483    int8
.../blocks_st.3/attn_s/proj/Add_output_0_Reshape_0  BPU  id(13)    Reshape                 0.934321           5.31664    int8
/blocks_st.3/Add                                    BPU  id(13)    HzSElementwiseAdd       0.978524           34.9949    int8
/blocks_st.3/norm2_s/ReduceMean                     BPU  id(13)    HzSQuantizedReduceMean  0.928445           35.0303    int8
/blocks_st.3/norm2_s/Sub                            BPU  id(13)    HzSElementwiseSub       0.978372           35.0303    int8
/blocks_st.3/norm2_s/Pow                            BPU  id(13)    HzLut                   0.996814           34.9435    int8
/blocks_st.3/norm2_s/ReduceMean_1                   BPU  id(13)    HzSQuantizedReduceMean  0.999178           1221.05    int8
/blocks_st.3/norm2_s/Div_reciprocal                 BPU  id(13)    HzLut                   0.999795           16.5061    int8
/blocks_st.3/norm2_s/Div_mul                        BPU  id(13)    HzSElementwiseMul       0.977723           34.9435    int8
/blocks_st.3/mlp_s/fc1/MatMul_reshape_input         BPU  id(13)    Reshape                 0.977723           13.216     int8
/blocks_st.3/mlp_s/fc1/MatMul                       BPU  id(13)    HzSQuantizedConv        0.976258           13.216     int8
/blocks_st.3/mlp_s/act/Mul_1                        BPU  id(13)    HzLut                   0.899611           8.07264    int8
/blocks_st.3/mlp_s/fc2/MatMul                       BPU  id(13)    HzSQuantizedConv        0.904922           6.27777    int8
...dd/blocks_st.3/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(13)    Reshape                 0.904922           6.6712     int8
/blocks_st.3/Add_1                                  BPU  id(13)    HzSElementwiseAdd       0.971656           35.0303    int8
/blocks_st.3/norm1_t/ReduceMean                     BPU  id(13)    HzSQuantizedReduceMean  0.913401           34.9759    int8
/blocks_st.3/norm1_t/Sub                            BPU  id(13)    HzSElementwiseSub       0.971528           34.9759    int8
/blocks_st.3/norm1_t/Pow                            BPU  id(13)    HzLut                   0.996267           34.8904    int8
/blocks_st.3/norm1_t/ReduceMean_1                   BPU  id(13)    HzSQuantizedReduceMean  0.998767           1217.34    int8
/blocks_st.3/norm1_t/Div_reciprocal                 BPU  id(13)    HzLut                   0.999695           17.2483    int8
/blocks_st.3/norm1_t/Div_mul                        BPU  id(13)    HzSElementwiseMul       0.970881           34.8904    int8
/blocks_st.3/norm1_t/Mul                            BPU  id(13)    HzSElementwiseMul       0.950431           13.0348    int8
/blocks_st.3/norm1_t/Add_1                          BPU  id(13)    HzSElementwiseAdd       0.948583           5.65437    int8
/blocks_st.3/attn_t/q_linear/MatMul_reshape_input   BPU  id(13)    Reshape                 0.948583           5.60361    int8
/blocks_st.3/attn_t/q_linear/MatMul                 BPU  id(13)    HzSQuantizedConv        0.959633           5.60361    int8
...cks_st.3/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(13)    Reshape                 0.959635           7.73645    int8
/blocks_st.3/attn_t/k_linear/MatMul                 BPU  id(13)    HzSQuantizedConv        0.963059           5.60361    int8
...cks_st.3/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(13)    Reshape                 0.963060           7.0117     int8
/blocks_st.3/attn_t/v_linear/MatMul                 BPU  id(13)    HzSQuantizedConv        0.869873           5.60361    int8
...cks_st.3/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(13)    Reshape                 0.869873           5.1617     int8
/blocks_st.3/attn_t/Transpose_3                     BPU  id(13)    Transpose               0.959634           7.73645    int8
/blocks_st.3/attn_t/Transpose_4                     BPU  id(13)    Transpose               0.869873           5.1617     int8
/blocks_st.3/attn_t/Transpose_5                     BPU  id(13)    Transpose               0.963059           7.0117     int8
/blocks_st.3/attn_t/MatMul                          BPU  id(13)    HzSQuantizedMatmul      0.982445           7.73645    int8
/blocks_st.3/attn_t/Mul                             BPU  id(13)    HzSElementwiseMul       0.982439           183.698    int8
/blocks_st.3/attn_t/Softmax                         CPU  --        Softmax                 0.754121           35.7209    float
/blocks_st.3/attn_t/MatMul_1                        BPU  id(15)    HzSQuantizedMatmul      0.925673           0.895893   int8
/blocks_st.3/attn_t/Transpose_6                     BPU  id(15)    Transpose               0.925672           3.74717    int8
/blocks_st.3/attn_t/Reshape_6                       BPU  id(15)    Reshape                 0.925672           3.74717    int8
/blocks_st.3/attn_t/proj/MatMul                     BPU  id(15)    HzSQuantizedConv        0.922357           3.74717    int8
.../blocks_st.3/attn_t/proj/Add_output_0_Reshape_0  BPU  id(15)    Reshape                 0.922351           6.30612    int8
/blocks_st.3/Add_2                                  BPU  id(15)    HzSElementwiseAdd       0.969245           34.9759    int8
/blocks_st.3/norm2_t/ReduceMean                     BPU  id(15)    HzSQuantizedReduceMean  0.922070           34.9764    int8
/blocks_st.3/norm2_t/Sub                            BPU  id(15)    HzSElementwiseSub       0.969112           34.9764    int8
/blocks_st.3/norm2_t/Pow                            BPU  id(15)    HzLut                   0.996427           34.8809    int8
/blocks_st.3/norm2_t/ReduceMean_1                   BPU  id(15)    HzSQuantizedReduceMean  0.998949           1216.67    int8
/blocks_st.3/norm2_t/Div_reciprocal                 BPU  id(15)    HzLut                   0.999723           16.3577    int8
/blocks_st.3/norm2_t/Div_mul                        BPU  id(15)    HzSElementwiseMul       0.968412           34.8809    int8
/blocks_st.3/mlp_t/fc1/MatMul_reshape_input         BPU  id(15)    Reshape                 0.968412           13.1816    int8
/blocks_st.3/mlp_t/fc1/MatMul                       BPU  id(15)    HzSQuantizedConv        0.953748           13.1816    int8
/blocks_st.3/mlp_t/act/Mul_1                        BPU  id(15)    HzLut                   0.812082           7.52164    int8
/blocks_st.3/mlp_t/fc2/MatMul                       BPU  id(15)    HzSQuantizedConv        0.813460           5.22079    int8
...dd/blocks_st.3/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(15)    Reshape                 0.813460           5.44843    int8
/blocks_st.3/Add_3                                  BPU  id(15)    HzSElementwiseAdd       0.963358           34.9764    int8
/blocks_ts.3/norm1_t/Pow                            BPU  id(12)    HzLut                   0.997341           34.8924    int8
/blocks_ts.3/norm1_t/ReduceMean_1                   BPU  id(12)    HzSQuantizedReduceMean  0.999233           1217.48    int8
/blocks_ts.3/norm1_t/Div_reciprocal                 BPU  id(12)    HzLut                   0.999796           13.6886    int8
/blocks_ts.3/norm1_t/Div_mul                        BPU  id(12)    HzSElementwiseMul       0.981551           34.8924    int8
/blocks_ts.3/norm1_t/Mul                            BPU  id(12)    HzSElementwiseMul       0.959341           13.2828    int8
/blocks_ts.3/norm1_t/Add_1                          BPU  id(12)    HzSElementwiseAdd       0.957327           3.84183    int8
/blocks_ts.3/attn_t/q_linear/MatMul_reshape_input   BPU  id(12)    Reshape                 0.957327           3.77822    int8
/blocks_ts.3/attn_t/q_linear/MatMul                 BPU  id(12)    HzSQuantizedConv        0.980888           3.77822    int8
...cks_ts.3/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(12)    Reshape                 0.980889           6.94797    int8
/blocks_ts.3/attn_t/k_linear/MatMul                 BPU  id(12)    HzSQuantizedConv        0.957003           3.77822    int8
...cks_ts.3/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(12)    Reshape                 0.957004           5.62367    int8
/blocks_ts.3/attn_t/v_linear/MatMul                 BPU  id(12)    HzSQuantizedConv        0.883361           3.77822    int8
...cks_ts.3/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(12)    Reshape                 0.883362           3.90829    int8
/blocks_ts.3/attn_t/Transpose_3                     BPU  id(12)    Transpose               0.980889           6.94797    int8
/blocks_ts.3/attn_t/Transpose_4                     BPU  id(12)    Transpose               0.883362           3.90829    int8
/blocks_ts.3/attn_t/Transpose_5                     BPU  id(12)    Transpose               0.957004           5.62367    int8
/blocks_ts.3/attn_t/MatMul                          BPU  id(12)    HzSQuantizedMatmul      0.965185           6.94797    int8
/blocks_ts.3/attn_t/Mul                             BPU  id(12)    HzSElementwiseMul       0.965216           129.969    int8
/blocks_ts.3/attn_t/Softmax                         CPU  --        Softmax                 0.801087           25.2731    float
/blocks_ts.3/attn_t/MatMul_1                        BPU  id(14)    HzSQuantizedMatmul      0.922184           0.906562   int8
/blocks_ts.3/attn_t/Transpose_6                     BPU  id(14)    Transpose               0.922185           2.94873    int8
/blocks_ts.3/attn_t/Reshape_6                       BPU  id(14)    Reshape                 0.922185           2.94873    int8
/blocks_ts.3/attn_t/proj/MatMul                     BPU  id(14)    HzSQuantizedConv        0.914598           2.94873    int8
.../blocks_ts.3/attn_t/proj/Add_output_0_Reshape_0  BPU  id(14)    Reshape                 0.914599           3.36389    int8
/blocks_ts.3/Add                                    BPU  id(14)    HzSElementwiseAdd       0.980593           34.9949    int8
/blocks_ts.3/norm2_t/ReduceMean                     BPU  id(14)    HzSQuantizedReduceMean  0.918066           35.0342    int8
/blocks_ts.3/norm2_t/Sub                            BPU  id(14)    HzSElementwiseSub       0.980475           35.0342    int8
/blocks_ts.3/norm2_t/Pow                            BPU  id(14)    HzLut                   0.997174           34.924     int8
/blocks_ts.3/norm2_t/ReduceMean_1                   BPU  id(14)    HzSQuantizedReduceMean  0.999273           1219.69    int8
/blocks_ts.3/norm2_t/Div_reciprocal                 BPU  id(14)    HzLut                   0.999810           13.7442    int8
/blocks_ts.3/norm2_t/Div_mul                        BPU  id(14)    HzSElementwiseMul       0.979934           34.924     int8
/blocks_ts.3/mlp_t/fc1/MatMul_reshape_input         BPU  id(14)    Reshape                 0.979934           13.2484    int8
/blocks_ts.3/mlp_t/fc1/MatMul                       BPU  id(14)    HzSQuantizedConv        0.981826           13.2484    int8
/blocks_ts.3/mlp_t/act/Mul_1                        BPU  id(14)    HzLut                   0.897487           7.9573     int8
/blocks_ts.3/mlp_t/fc2/MatMul                       BPU  id(14)    HzSQuantizedConv        0.902849           4.86999    int8
...dd/blocks_ts.3/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(14)    Reshape                 0.902848           5.40242    int8
/blocks_ts.3/Add_1                                  BPU  id(14)    HzSElementwiseAdd       0.978666           35.0342    int8
/blocks_ts.3/norm1_s/ReduceMean                     BPU  id(14)    HzSQuantizedReduceMean  0.910263           34.9973    int8
/blocks_ts.3/norm1_s/Sub                            BPU  id(14)    HzSElementwiseSub       0.978555           34.9973    int8
/blocks_ts.3/norm1_s/Pow                            BPU  id(14)    HzLut                   0.997041           34.8921    int8
/blocks_ts.3/norm1_s/ReduceMean_1                   BPU  id(14)    HzSQuantizedReduceMean  0.999242           1217.46    int8
/blocks_ts.3/norm1_s/Div_reciprocal                 BPU  id(14)    HzLut                   0.999802           14.3103    int8
/blocks_ts.3/norm1_s/Div_mul                        BPU  id(14)    HzSElementwiseMul       0.978012           34.8921    int8
/blocks_ts.3/norm1_s/Mul                            BPU  id(14)    HzSElementwiseMul       0.960600           13.2055    int8
/blocks_ts.3/norm1_s/Add_1                          BPU  id(14)    HzSElementwiseAdd       0.958955           6.70674    int8
/blocks_ts.3/attn_s/q_linear/MatMul_reshape_input   BPU  id(14)    Reshape                 0.958955           6.6816     int8
/blocks_ts.3/attn_s/q_linear/MatMul                 BPU  id(14)    HzSQuantizedConv        0.980435           6.6816     int8
...cks_ts.3/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(14)    Reshape                 0.980435           5.52978    int8
/blocks_ts.3/attn_s/Transpose                       BPU  id(14)    Transpose               0.980435           5.52978    int8
/blocks_ts.3/attn_s/k_linear/MatMul                 BPU  id(14)    HzSQuantizedConv        0.976090           6.6816     int8
...cks_ts.3/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(14)    Reshape                 0.976093           5.66667    int8
/blocks_ts.3/attn_s/v_linear/MatMul                 BPU  id(14)    HzSQuantizedConv        0.959406           6.6816     int8
...cks_ts.3/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(14)    Reshape                 0.959406           4.75803    int8
/blocks_ts.3/attn_s/Transpose_1                     BPU  id(14)    Transpose               0.959406           4.75803    int8
/blocks_ts.3/attn_s/Transpose_2                     BPU  id(14)    Transpose               0.976092           5.66667    int8
/blocks_ts.3/attn_s/MatMul                          BPU  id(14)    HzSQuantizedMatmul      0.977915           5.52978    int8
/blocks_ts.3/attn_s/Mul                             BPU  id(14)    HzSElementwiseMul       0.977915           86.4994    int8
/blocks_ts.3/attn_s/Softmax                         CPU  --        Softmax                 0.969769           16.8202    float
/blocks_ts.3/attn_s/MatMul_1                        BPU  id(15)    HzSQuantizedMatmul      0.918346           0.998809   int8
/blocks_ts.3/attn_s/Transpose_3                     BPU  id(15)    Transpose               0.918346           3.90269    int8
/blocks_ts.3/attn_s/Reshape_3                       BPU  id(15)    Reshape                 0.918346           3.90269    int8
/blocks_ts.3/attn_s/proj/MatMul                     BPU  id(15)    HzSQuantizedConv        0.926412           3.90269    int8
.../blocks_ts.3/attn_s/proj/Add_output_0_Reshape_0  BPU  id(15)    Reshape                 0.926412           5.60806    int8
/blocks_ts.3/Add_2                                  BPU  id(15)    HzSElementwiseAdd       0.974660           34.9973    int8
/blocks_ts.3/norm2_s/ReduceMean                     BPU  id(15)    HzSQuantizedReduceMean  0.900093           35.0305    int8
/blocks_ts.3/norm2_s/Sub                            BPU  id(15)    HzSElementwiseSub       0.974564           35.0305    int8
/blocks_ts.3/norm2_s/Pow                            BPU  id(15)    HzLut                   0.996532           34.9364    int8
/blocks_ts.3/norm2_s/ReduceMean_1                   BPU  id(15)    HzSQuantizedReduceMean  0.999204           1220.55    int8
/blocks_ts.3/norm2_s/Div_reciprocal                 BPU  id(15)    HzLut                   0.999796           14.4405    int8
/blocks_ts.3/norm2_s/Div_mul                        BPU  id(15)    HzSElementwiseMul       0.973911           34.9364    int8
/blocks_ts.3/mlp_s/fc1/MatMul_reshape_input         BPU  id(15)    Reshape                 0.973911           12.9309    int8
/blocks_ts.3/mlp_s/fc1/MatMul                       BPU  id(15)    HzSQuantizedConv        0.979053           12.9309    int8
/blocks_ts.3/mlp_s/act/Mul_1                        BPU  id(15)    HzLut                   0.888992           9.20277    int8
/blocks_ts.3/mlp_s/fc2/MatMul                       BPU  id(15)    HzSQuantizedConv        0.902933           6.07836    int8
...dd/blocks_ts.3/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(15)    Reshape                 0.902931           6.50488    int8
/blocks_ts.3/Add_3                                  BPU  id(15)    HzSElementwiseAdd       0.971870           35.0305    int8
/blocks_st.3/Add_3_output_0_calibrated_Requantize   BPU  id(15)    HzRequantize            --                 --         int16
/Concat_3                                           BPU  id(15)    Concat                  0.967688           34.9377    int16
/ts_attn.3/MatMul_reshape_input                     BPU  id(15)    Reshape                 0.967688           35.019     int16
...0_reshape_in_transpose_in_calibrated_Requantize  BPU  id(15)    HzRequantize            --                 --         int16
/ts_attn.3/MatMul                                   BPU  id(15)    HzSQuantizedConv        0.978864           35.019     int8
/ts_attn.3/Add/ts_attn.3/Add_output_0_Reshape_0     CPU  --        Reshape                 0.978864           --         float
/Softmax_3                                          CPU  --        Softmax                 0.996537           --         float
/Slice_6                                            BPU  id(16)    Slice                   0.998400           --         int8
/Mul_6                                              BPU  id(16)    HzSElementwiseMul       0.961914           34.9377    int16
/Slice_7                                            BPU  id(16)    Slice                   0.996852           --         int8
/Mul_7                                              BPU  id(16)    HzSElementwiseMul       0.967781           35.019     int16
/Add_5                                              BPU  id(16)    HzSElementwiseAdd       0.971896           26.349     int8
/blocks_st.4/norm1_s/ReduceMean                     BPU  id(16)    HzSQuantizedReduceMean  0.898899           34.9789    int8
/blocks_st.4/norm1_s/Sub                            BPU  id(16)    HzSElementwiseSub       0.971796           34.9789    int8
/blocks_st.4/norm1_s/Pow                            BPU  id(16)    HzLut                   0.996793           34.8739    int8
/blocks_st.4/norm1_s/ReduceMean_1                   BPU  id(16)    HzSQuantizedReduceMean  0.998968           1216.19    int8
/blocks_st.4/norm1_s/Div_reciprocal                 BPU  id(16)    HzLut                   0.999736           16.1544    int8
/blocks_st.4/norm1_s/Div_mul                        BPU  id(16)    HzSElementwiseMul       0.971244           34.8739    int8
/blocks_st.4/norm1_s/Mul                            BPU  id(16)    HzSElementwiseMul       0.950902           13.2574    int8
/blocks_st.4/norm1_s/Add_1                          BPU  id(16)    HzSElementwiseAdd       0.948982           6.41634    int8
/blocks_st.4/attn_s/q_linear/MatMul_reshape_input   BPU  id(16)    Reshape                 0.948982           6.40957    int8
/blocks_st.4/attn_s/q_linear/MatMul                 BPU  id(16)    HzSQuantizedConv        0.974764           6.40957    int8
...cks_st.4/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(16)    Reshape                 0.974764           5.4871     int8
/blocks_st.4/attn_s/Transpose                       BPU  id(16)    Transpose               0.974764           5.4871     int8
/blocks_st.4/attn_s/k_linear/MatMul                 BPU  id(16)    HzSQuantizedConv        0.968009           6.40957    int8
...cks_st.4/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(16)    Reshape                 0.968008           4.77318    int8
/blocks_st.4/attn_s/v_linear/MatMul                 BPU  id(16)    HzSQuantizedConv        0.944503           6.40957    int8
...cks_st.4/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(16)    Reshape                 0.944502           4.60253    int8
/blocks_st.4/attn_s/Transpose_1                     BPU  id(16)    Transpose               0.944502           4.60253    int8
/blocks_st.4/attn_s/Transpose_2                     BPU  id(16)    Transpose               0.968009           4.77318    int8
/blocks_st.4/attn_s/MatMul                          BPU  id(16)    HzSQuantizedMatmul      0.975034           5.4871     int8
/blocks_st.4/attn_s/Mul                             BPU  id(16)    HzSElementwiseMul       0.975040           125.534    int8
/blocks_st.4/attn_s/Softmax                         CPU  --        Softmax                 0.951066           24.4107    float
/blocks_st.4/attn_s/MatMul_1                        BPU  id(17)    HzSQuantizedMatmul      0.892591           0.999978   int8
/blocks_st.4/attn_s/Transpose_3                     BPU  id(17)    Transpose               0.892591           4.30135    int8
/blocks_st.4/attn_s/Reshape_3                       BPU  id(17)    Reshape                 0.892591           4.30135    int8
/blocks_st.4/attn_s/proj/MatMul                     BPU  id(17)    HzSQuantizedConv        0.893729           4.30135    int8
.../blocks_st.4/attn_s/proj/Add_output_0_Reshape_0  BPU  id(17)    Reshape                 0.893727           5.42047    int8
/blocks_st.4/Add                                    BPU  id(17)    HzSElementwiseAdd       0.964621           34.9789    int8
/blocks_st.4/norm2_s/ReduceMean                     BPU  id(17)    HzSQuantizedReduceMean  0.892498           34.9532    int8
/blocks_st.4/norm2_s/Sub                            BPU  id(17)    HzSElementwiseSub       0.964541           34.9532    int8
/blocks_st.4/norm2_s/Pow                            BPU  id(17)    HzLut                   0.996072           34.8439    int8
/blocks_st.4/norm2_s/ReduceMean_1                   BPU  id(17)    HzSQuantizedReduceMean  0.999081           1214.1     int8
/blocks_st.4/norm2_s/Div_reciprocal                 BPU  id(17)    HzLut                   0.999764           19.5548    int8
/blocks_st.4/norm2_s/Div_mul                        BPU  id(17)    HzSElementwiseMul       0.963646           34.8439    int8
/blocks_st.4/mlp_s/fc1/MatMul_reshape_input         BPU  id(17)    Reshape                 0.963646           13.0843    int8
/blocks_st.4/mlp_s/fc1/MatMul                       BPU  id(17)    HzSQuantizedConv        0.960404           13.0843    int8
/blocks_st.4/mlp_s/act/Mul_1                        BPU  id(17)    HzLut                   0.847828           8.90511    int8
/blocks_st.4/mlp_s/fc2/MatMul                       BPU  id(17)    HzSQuantizedConv        0.854699           6.63422    int8
...dd/blocks_st.4/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(17)    Reshape                 0.854694           15.6111    int8
/blocks_st.4/Add_1                                  BPU  id(17)    HzSElementwiseAdd       0.958663           34.9532    int8
/blocks_st.4/norm1_t/ReduceMean                     BPU  id(17)    HzSQuantizedReduceMean  0.910850           34.8787    int8
/blocks_st.4/norm1_t/Sub                            BPU  id(17)    HzSElementwiseSub       0.958525           34.8787    int8
/blocks_st.4/norm1_t/Pow                            BPU  id(17)    HzLut                   0.996100           34.7817    int8
/blocks_st.4/norm1_t/ReduceMean_1                   BPU  id(17)    HzSQuantizedReduceMean  0.998676           1209.77    int8
/blocks_st.4/norm1_t/Div_reciprocal                 BPU  id(17)    HzLut                   0.999672           22.2324    int8
/blocks_st.4/norm1_t/Div_mul                        BPU  id(17)    HzSElementwiseMul       0.957310           34.7817    int8
/blocks_st.4/norm1_t/Mul                            BPU  id(17)    HzSElementwiseMul       0.941015           12.86      int8
/blocks_st.4/norm1_t/Add_1                          BPU  id(17)    HzSElementwiseAdd       0.940497           8.0217     int8
/blocks_st.4/attn_t/q_linear/MatMul_reshape_input   BPU  id(17)    Reshape                 0.940497           7.9948     int8
/blocks_st.4/attn_t/q_linear/MatMul                 BPU  id(17)    HzSQuantizedConv        0.937065           7.9948     int8
...cks_st.4/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(17)    Reshape                 0.937063           8.67205    int8
/blocks_st.4/attn_t/k_linear/MatMul                 BPU  id(17)    HzSQuantizedConv        0.962689           7.9948     int8
...cks_st.4/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(17)    Reshape                 0.962700           9.39648    int8
/blocks_st.4/attn_t/v_linear/MatMul                 BPU  id(17)    HzSQuantizedConv        0.878585           7.9948     int8
...cks_st.4/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(17)    Reshape                 0.878584           7.40794    int8
/blocks_st.4/attn_t/Transpose_3                     BPU  id(17)    Transpose               0.937064           8.67205    int8
/blocks_st.4/attn_t/Transpose_4                     BPU  id(17)    Transpose               0.878588           7.40794    int8
/blocks_st.4/attn_t/Transpose_5                     BPU  id(17)    Transpose               0.962689           9.39648    int8
/blocks_st.4/attn_t/MatMul                          BPU  id(17)    HzSQuantizedMatmul      0.989638           8.67205    int8
/blocks_st.4/attn_t/Mul                             BPU  id(17)    HzSElementwiseMul       0.989636           242.388    int8
/blocks_st.4/attn_t/Softmax                         CPU  --        Softmax                 0.788321           47.1334    float
/blocks_st.4/attn_t/MatMul_1                        BPU  id(19)    HzSQuantizedMatmul      0.939438           0.776282   int8
/blocks_st.4/attn_t/Transpose_6                     BPU  id(19)    Transpose               0.939449           6.69237    int8
/blocks_st.4/attn_t/Reshape_6                       BPU  id(19)    Reshape                 0.939449           6.69237    int8
/blocks_st.4/attn_t/proj/MatMul                     BPU  id(19)    HzSQuantizedConv        0.951152           6.69237    int8
.../blocks_st.4/attn_t/proj/Add_output_0_Reshape_0  BPU  id(19)    Reshape                 0.951151           10.4911    int8
/blocks_st.4/Add_2                                  BPU  id(19)    HzSElementwiseAdd       0.965179           34.8787    int8
/blocks_st.4/norm2_t/ReduceMean                     BPU  id(19)    HzSQuantizedReduceMean  0.863181           37.0048    int8
/blocks_st.4/norm2_t/Sub                            BPU  id(19)    HzSElementwiseSub       0.965013           37.0048    int8
/blocks_st.4/norm2_t/Pow                            BPU  id(19)    HzLut                   0.997259           36.9672    int8
/blocks_st.4/norm2_t/ReduceMean_1                   BPU  id(19)    HzSQuantizedReduceMean  0.999063           1366.57    int8
/blocks_st.4/norm2_t/Div_reciprocal                 BPU  id(19)    HzLut                   0.999766           20.1797    int8
/blocks_st.4/norm2_t/Div_mul                        BPU  id(19)    HzSElementwiseMul       0.963826           36.9672    int8
/blocks_st.4/mlp_t/fc1/MatMul_reshape_input         BPU  id(19)    Reshape                 0.963826           12.5016    int8
/blocks_st.4/mlp_t/fc1/MatMul                       BPU  id(19)    HzSQuantizedConv        0.957665           12.5016    int8
/blocks_st.4/mlp_t/act/Mul_1                        BPU  id(19)    HzLut                   0.961202           8.02524    int8
/blocks_st.4/mlp_t/fc2/MatMul                       BPU  id(19)    HzSQuantizedConv        0.970370           8.02524    int8
...dd/blocks_st.4/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(19)    Reshape                 0.970389           20.5261    int8
/blocks_st.4/Add_3                                  BPU  id(19)    HzSElementwiseAdd       0.983157           37.0048    int8
/blocks_ts.4/norm1_t/Pow                            BPU  id(16)    HzLut                   0.996793           34.8739    int8
/blocks_ts.4/norm1_t/ReduceMean_1                   BPU  id(16)    HzSQuantizedReduceMean  0.998968           1216.19    int8
/blocks_ts.4/norm1_t/Div_reciprocal                 BPU  id(16)    HzLut                   0.999736           16.1544    int8
/blocks_ts.4/norm1_t/Div_mul                        BPU  id(16)    HzSElementwiseMul       0.971244           34.8739    int8
/blocks_ts.4/norm1_t/Mul                            BPU  id(16)    HzSElementwiseMul       0.950016           13.2574    int8
/blocks_ts.4/norm1_t/Add_1                          BPU  id(16)    HzSElementwiseAdd       0.949168           6.20303    int8
/blocks_ts.4/attn_t/q_linear/MatMul_reshape_input   BPU  id(16)    Reshape                 0.949168           6.11116    int8
/blocks_ts.4/attn_t/q_linear/MatMul                 BPU  id(16)    HzSQuantizedConv        0.956571           6.11116    int8
...cks_ts.4/attn_t/q_linear/Add_output_0_Reshape_0  BPU  id(16)    Reshape                 0.956571           8.14065    int8
/blocks_ts.4/attn_t/k_linear/MatMul                 BPU  id(16)    HzSQuantizedConv        0.958066           6.11116    int8
...cks_ts.4/attn_t/k_linear/Add_output_0_Reshape_0  BPU  id(16)    Reshape                 0.958065           7.66824    int8
/blocks_ts.4/attn_t/v_linear/MatMul                 BPU  id(16)    HzSQuantizedConv        0.861084           6.11116    int8
...cks_ts.4/attn_t/v_linear/Add_output_0_Reshape_0  BPU  id(16)    Reshape                 0.861084           3.89804    int8
/blocks_ts.4/attn_t/Transpose_3                     BPU  id(16)    Transpose               0.956573           8.14065    int8
/blocks_ts.4/attn_t/Transpose_4                     BPU  id(16)    Transpose               0.861085           3.89804    int8
/blocks_ts.4/attn_t/Transpose_5                     BPU  id(16)    Transpose               0.958066           7.66824    int8
/blocks_ts.4/attn_t/MatMul                          BPU  id(16)    HzSQuantizedMatmul      0.977407           8.14065    int8
/blocks_ts.4/attn_t/Mul                             BPU  id(16)    HzSElementwiseMul       0.977373           197.957    int8
/blocks_ts.4/attn_t/Softmax                         CPU  --        Softmax                 0.688945           38.4935    float
/blocks_ts.4/attn_t/MatMul_1                        BPU  id(18)    HzSQuantizedMatmul      0.926102           0.834731   int8
/blocks_ts.4/attn_t/Transpose_6                     BPU  id(18)    Transpose               0.926101           3.32087    int8
/blocks_ts.4/attn_t/Reshape_6                       BPU  id(18)    Reshape                 0.926101           3.32087    int8
/blocks_ts.4/attn_t/proj/MatMul                     BPU  id(18)    HzSQuantizedConv        0.935955           3.32087    int8
.../blocks_ts.4/attn_t/proj/Add_output_0_Reshape_0  BPU  id(18)    Reshape                 0.935950           5.07739    int8
/blocks_ts.4/Add                                    BPU  id(18)    HzSElementwiseAdd       0.971350           34.9789    int8
/blocks_ts.4/norm2_t/ReduceMean                     BPU  id(18)    HzSQuantizedReduceMean  0.905048           35.0435    int8
/blocks_ts.4/norm2_t/Sub                            BPU  id(18)    HzSElementwiseSub       0.971269           35.0435    int8
/blocks_ts.4/norm2_t/Pow                            BPU  id(18)    HzLut                   0.996790           34.9129    int8
/blocks_ts.4/norm2_t/ReduceMean_1                   BPU  id(18)    HzSQuantizedReduceMean  0.999118           1218.91    int8
/blocks_ts.4/norm2_t/Div_reciprocal                 BPU  id(18)    HzLut                   0.999772           15.9692    int8
/blocks_ts.4/norm2_t/Div_mul                        BPU  id(18)    HzSElementwiseMul       0.970464           34.9129    int8
/blocks_ts.4/mlp_t/fc1/MatMul_reshape_input         BPU  id(18)    Reshape                 0.970464           13.1744    int8
/blocks_ts.4/mlp_t/fc1/MatMul                       BPU  id(18)    HzSQuantizedConv        0.970755           13.1744    int8
/blocks_ts.4/mlp_t/act/Mul_1                        BPU  id(18)    HzLut                   0.918452           7.1315     int8
/blocks_ts.4/mlp_t/fc2/MatMul                       BPU  id(18)    HzSQuantizedConv        0.940593           6.02436    int8
...dd/blocks_ts.4/mlp_t/fc2/Add_output_0_Reshape_0  BPU  id(18)    Reshape                 0.940596           5.87292    int8
/blocks_ts.4/Add_1                                  BPU  id(18)    HzSElementwiseAdd       0.974618           35.0435    int8
/blocks_ts.4/norm1_s/ReduceMean                     BPU  id(18)    HzSQuantizedReduceMean  0.892593           34.9726    int8
/blocks_ts.4/norm1_s/Sub                            BPU  id(18)    HzSElementwiseSub       0.974611           34.9726    int8
/blocks_ts.4/norm1_s/Pow                            BPU  id(18)    HzLut                   0.997327           34.7897    int8
/blocks_ts.4/norm1_s/ReduceMean_1                   BPU  id(18)    HzSQuantizedReduceMean  0.999077           1210.32    int8
/blocks_ts.4/norm1_s/Div_reciprocal                 BPU  id(18)    HzLut                   0.999777           18.2662    int8
/blocks_ts.4/norm1_s/Div_mul                        BPU  id(18)    HzSElementwiseMul       0.973016           34.7897    int8
/blocks_ts.4/norm1_s/Mul                            BPU  id(18)    HzSElementwiseMul       0.965903           12.7837    int8
/blocks_ts.4/norm1_s/Add_1                          BPU  id(18)    HzSElementwiseAdd       0.965610           7.32726    int8
/blocks_ts.4/attn_s/q_linear/MatMul_reshape_input   BPU  id(18)    Reshape                 0.965610           7.31926    int8
/blocks_ts.4/attn_s/q_linear/MatMul                 BPU  id(18)    HzSQuantizedConv        0.980061           7.31926    int8
...cks_ts.4/attn_s/q_linear/Add_output_0_Reshape_0  BPU  id(18)    Reshape                 0.980061           5.20434    int8
/blocks_ts.4/attn_s/Transpose                       BPU  id(18)    Transpose               0.980061           5.20434    int8
/blocks_ts.4/attn_s/k_linear/MatMul                 BPU  id(18)    HzSQuantizedConv        0.982697           7.31926    int8
...cks_ts.4/attn_s/k_linear/Add_output_0_Reshape_0  BPU  id(18)    Reshape                 0.982700           5.17223    int8
/blocks_ts.4/attn_s/v_linear/MatMul                 BPU  id(18)    HzSQuantizedConv        0.972107           7.31926    int8
...cks_ts.4/attn_s/v_linear/Add_output_0_Reshape_0  BPU  id(18)    Reshape                 0.972104           7.67376    int8
/blocks_ts.4/attn_s/Transpose_1                     BPU  id(18)    Transpose               0.972104           7.67376    int8
/blocks_ts.4/attn_s/Transpose_2                     BPU  id(18)    Transpose               0.982700           5.17223    int8
/blocks_ts.4/attn_s/MatMul                          BPU  id(18)    HzSQuantizedMatmul      0.982860           5.20434    int8
/blocks_ts.4/attn_s/Mul                             BPU  id(18)    HzSElementwiseMul       0.982864           84.9016    int8
/blocks_ts.4/attn_s/Softmax                         CPU  --        Softmax                 0.975308           16.5095    float
/blocks_ts.4/attn_s/MatMul_1                        BPU  id(19)    HzSQuantizedMatmul      0.959543           0.999351   int8
/blocks_ts.4/attn_s/Transpose_3                     BPU  id(19)    Transpose               0.959543           4.01477    int8
/blocks_ts.4/attn_s/Reshape_3                       BPU  id(19)    Reshape                 0.959543           4.01477    int8
/blocks_ts.4/attn_s/proj/MatMul                     BPU  id(19)    HzSQuantizedConv        0.964785           4.01477    int8
.../blocks_ts.4/attn_s/proj/Add_output_0_Reshape_0  BPU  id(19)    Reshape                 0.964789           7.11563    int8
/blocks_ts.4/Add_2                                  BPU  id(19)    HzSElementwiseAdd       0.978288           34.9726    int8
/blocks_ts.4/norm2_s/ReduceMean                     BPU  id(19)    HzSQuantizedReduceMean  0.903567           39.3166    int8
/blocks_ts.4/norm2_s/Sub                            BPU  id(19)    HzSElementwiseSub       0.978187           39.3166    int8
/blocks_ts.4/norm2_s/Pow                            BPU  id(19)    HzLut                   0.998104           39.2461    int8
/blocks_ts.4/norm2_s/ReduceMean_1                   BPU  id(19)    HzSQuantizedReduceMean  0.999465           1540.26    int8
/blocks_ts.4/norm2_s/Div_reciprocal                 BPU  id(19)    HzLut                   0.999851           19.3302    int8
/blocks_ts.4/norm2_s/Div_mul                        BPU  id(19)    HzSElementwiseMul       0.976665           39.2461    int8
/blocks_ts.4/mlp_s/fc1/MatMul_reshape_input         BPU  id(19)    Reshape                 0.976665           12.415     int8
/blocks_ts.4/mlp_s/fc1/MatMul                       BPU  id(19)    HzSQuantizedConv        0.976377           12.415     int8
/blocks_ts.4/mlp_s/act/Mul_1                        BPU  id(19)    HzLut                   0.976951           8.5448     int8
/blocks_ts.4/mlp_s/fc2/MatMul                       BPU  id(19)    HzSQuantizedConv        0.983473           6.80553    int8
...dd/blocks_ts.4/mlp_s/fc2/Add_output_0_Reshape_0  BPU  id(19)    Reshape                 0.983485           17.2748    int8
/blocks_ts.4/Add_3                                  BPU  id(19)    HzSElementwiseAdd       0.986211           39.3166    int8
/blocks_ts.4/Add_3_output_0_calibrated_Requantize   BPU  id(19)    HzRequantize            --                 --         int16
/Concat_4                                           BPU  id(19)    Concat                  0.984726           54.4223    int16
/ts_attn.4/MatMul_reshape_input                     BPU  id(19)    Reshape                 0.984726           54.4223    int16
...0_reshape_in_transpose_in_calibrated_Requantize  BPU  id(19)    HzRequantize            --                 --         int16
/ts_attn.4/MatMul                                   BPU  id(19)    HzSQuantizedConv        0.993719           54.4223    int8
/ts_attn.4/Add/ts_attn.4/Add_output_0_Reshape_0     CPU  --        Reshape                 0.993719           --         float
/Softmax_4                                          CPU  --        Softmax                 0.998344           --         float
/Slice_8                                            BPU  id(20)    Slice                   0.998971           --         int8
/Mul_8                                              BPU  id(20)    HzSElementwiseMul       0.981448           54.4223    int16
/Slice_9                                            BPU  id(20)    Slice                   0.997724           --         int8
/Mul_9                                              BPU  id(20)    HzSElementwiseMul       0.983790           53.5389    int16
/Add_6                                              BPU  id(20)    HzSElementwiseAdd       0.986078           45.6525    int8
/norm/ReduceMean                                    BPU  id(20)    HzSQuantizedReduceMean  0.824666           53.8773    int8
/norm/Sub                                           BPU  id(20)    HzSElementwiseSub       0.985995           53.8773    int8
/norm/Pow                                           BPU  id(20)    HzLut                   0.999070           53.8625    int8
/norm/ReduceMean_1                                  BPU  id(20)    HzSQuantizedReduceMean  0.999693           2901.17    int8
/norm/Div_reciprocal                                BPU  id(20)    HzLut                   0.999912           23.3617    int8
/norm/Div_mul                                       BPU  id(20)    HzSElementwiseMul       0.985877           53.8625    int8
/Reshape_3                                          BPU  id(20)    Reshape                 0.985877           11.8873    int8
/pre_logits/fc/MatMul                               BPU  id(20)    HzSQuantizedConv        0.998032           11.8873    int8
/pre_logits/act/Tanh                                BPU  id(20)    HzLut2Layer             0.998057           1.09694    int16
/head/MatMul                                        BPU  id(20)    HzSQuantizedConv        0.998944           0.799398   int16
2026-05-08 12:27:01,429 file: print_info_dict.py func: print_info_dict line No: 72 The quantized model output:
Output      Cosine Similarity  L1 Distance  L2 Distance  Chebyshev Distance
output      0.998944           0.006731     0.000111     0.044780
:magnifying_glass_tilted_left: 深度分析:问题不在 Softmax 本身
从新量化报告看到关键问题:
1. Softmax 相似度两极分化
Softmax 节点 相似度 问题
/blocks_st.0/attn_s/Softmax 1.000010 :white_check_mark: 正常
/blocks_st.0/attn_t/Softmax 1.000109 :white_check_mark: 正常
/blocks_ts.1/attn_t/Softmax 0.853005 :cross_mark: 严重损失
/blocks_st.2/attn_t/Softmax 0.832161 :cross_mark: 最严重
/blocks_ts.2/attn_t/Softmax 0.842229 :cross_mark: 严重损失
2. 真正问题:Softmax 输入已量化损失
/blocks_st.1/attn_t/v_linear/MatMul  → 0.946226 (int8)
                                        ↓ 量化损失传递
/blocks_st.1/attn_t/Softmax          → 0.930826 (float) ❌
/blocks_ts.1/attn_t/v_linear/MatMul  → 0.928596 (int8)
                                        ↓ 量化损失传递
/blocks_ts.1/attn_t/Softmax          → 0.853005 (float) ❌
Softmax 虽然在 CPU 上跑 float32,但输入数据已经是量化后的 int8!
3. 误差累积曲线
Layer 0: 0.999+  ✅
Layer 1: 0.97-0.99  ⚠️  (v_linear 开始掉点)
Layer 2: 0.92-0.95  ❌  (v_linear 跌破 0.93)
:hammer_and_wrench: 终极解决方案
方案 A:保护 Attention 的 V 投影层(最关键)
# config_attention_fp16.yaml
  onnx_model: ./motionbert_lite_120.onnx
  march: bayes-e
  working_dir: motionbert_lite_model_output_v2
  layer_out_dump: true
  node_info:
    # ========== 所有 Softmax 保持 CPU + float32 ==========
    /blocks_st.0/attn_s/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.0/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    # ...(所有 Softmax 节点同上)
    # ========== 关键:所有 Attention 的 v_linear 保持 int16 ==========
    /blocks_st.0/attn_s/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.0/attn_t/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.1/attn_s/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.1/attn_t/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.2/attn_s/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.2/attn_t/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_ts.0/attn_s/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_ts.0/attn_t/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_ts.1/attn_s/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_ts.1/attn_t/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_ts.2/attn_s/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_ts.2/attn_t/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    # ========== 可选:q_linear 和 k_linear 也保持 int16 ==========
    /blocks_st.1/attn_t/q_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.1/attn_t/k_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    # ========== 输出头保持 int16 ==========
    /Concat:
      ON: BPU
      InputType: int16
      OutputType: int16
    /Concat_1:
      ON: BPU
      InputType: int16
      OutputType: int16
    /Concat_2:
      ON: BPU
      InputType: int16
      OutputType: int16
    /head/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
  cal_data_dir: ./calibration_data_120
  cal_data_type: float32
  calibration_type: kl  # 改用 KL 散度
  max_percentile: 0.9999  # 从 0.99999 降低到 0.9999
  per_channel: true
方案 B:增加校准数据(必须配合方案 A)
# 50 条对时序 Transformer 模型严重不足
# 准备 300-500 条校准数据
# 校准数据生成要点:
# 1. 覆盖完整动作空间(静止、行走、跑步、跳跃等)
# 2. 包含遮挡场景
# 3. 包含不同视角
# 4. 确保 2D 关键点输入分布与真实推理一致
python3 generate_calib_data.py \
  --num_samples 300 \
  --cover_actions all \
  --output_dir ./calibration_data_300
方案 C:降低 max_percentile(立即见效)
当前配置 max_percentile: 0.99999 过于激进,导致异常值影响校准:
  # 或进一步降低到 0.9998 测试
:clipboard: 验证步骤
# 1. 应用新配置重新量化
hb_mapper --config config_attention_fp16.yaml
# 2. 检查 v_linear 层相似度是否提升
cat motionbert_lite_model_output_v2/motionbert_lite_quant_info.json | grep "v_linear/MatMul"
# 预期:从 0.92-0.94 提升到 0.97+
# 3. 检查 Softmax 输入前置节点
cat motionbert_lite_model_output_v2/motionbert_lite_quant_info.json | grep -B2 "Softmax"
# 4. 板端测试抖动
# 录制连续 100 帧,计算关键点位置标准差
:bar_chart: 预期效果
指标 当前 方案 A 后 方案 A+B 后
v_linear 相似度 0.92-0.94 0.96+ 0.98+
低分 Softmax 0.83-0.85 0.95+ 0.98+
关键点抖动 明显 减轻 基本消除
:warning: 如果仍不满足
QAT 是最终手段,参考社区精华帖:
请先执行方案 A(保护 v_linear)+ 方案 C(降低 max_percentile),这通常能解决 90% 的 Transformer 量化抖动问题。
需要我帮你生成完整的 YAML 配置文件吗?
:magnifying_glass_tilted_left: 问题分析
虽然 Softmax 已移到 CPU,但问题已转移到其他敏感算子。从新日志看到:
节点 余弦相似度 问题
/blocks_ts.4/attn_t/Softmax 0.688 :cross_mark: 严重损失
/blocks_st.3/attn_t/Softmax 0.754 :cross_mark: 严重损失
/blocks_st.3/attn_t/v_linear/MatMul 0.869 :cross_mark: v_linear 量化敏感
/blocks_st.3/mlp_t/act/Mul_1 0.812 :cross_mark: 激活函数量化损失
/blocks_st.3/mlp_t/fc2/MatMul 0.813 :cross_mark: 深层 FC 层
/norm/ReduceMean 0.824 :cross_mark: 归一化层
核心原因
  1. 50 条校准数据严重不足(时序模型需要 300-500 条)
  2. Attention 的 v_linear 对量化极敏感(仍用 int8)
  3. 深层网络误差累积(layer 3-4 恶化明显)
  4. max_percentile=0.99999 过高,放大了异常值影响
:hammer_and_wrench: 紧急解决方案(按优先级执行)
步骤 1:修改 YAML 配置(关键算子用 int16)
# config_final.yaml
  march: bayes-e
  working_dir: motionbert_lite_model_output_final
  node_info:
    # ========== 所有 Attention 的 v_linear 强制 int16(最关键)==========
      ON: BPU
      InputType: int16
      OutputType: int16
      ON: BPU
      InputType: int16
      OutputType: int16
      ON: BPU
      InputType: int16
      OutputType: int16
      ON: BPU
      InputType: int16
      OutputType: int16
      ON: BPU
      InputType: int16
      OutputType: int16
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.3/attn_s/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.3/attn_t/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.4/attn_s/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.4/attn_t/v_linear/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    # blocks_ts 层同理配置所有 v_linear...
    # ========== 深层 MLP 层用 int16 ==========
    /blocks_st.3/mlp_s/fc1/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.3/mlp_s/fc2/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.3/mlp_t/fc1/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.3/mlp_t/fc2/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.4/mlp_s/fc1/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.4/mlp_s/fc2/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.4/mlp_t/fc1/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /blocks_st.4/mlp_t/fc2/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
    /head/MatMul:
      ON: BPU
      InputType: int16
      OutputType: int16
  per_channel: true
步骤 2:增加校准数据(必须执行)
# 50 条对时序模型远远不够,生成 300-500 条
# 覆盖:静止、慢速、快速、遮挡、不同视角
# 示例脚本
python3 generate_calibration_data.py \
  --input_dir ./original_dataset \
  --num_samples 400 \
  --output_dir ./calibration_data_400 \
  --cover_all_actions \
  --sequence_length 120
# 修改 YAML 中的校准数据路径
  cal_data_dir: ./calibration_data_400
步骤 3:重新量化并验证
# 使用新配置重新量化
hb_mapper --config config_final.yaml
# 检查关键算子相似度
cat motionbert_lite_model_output_final/motionbert_lite_quant_info.json | \
  grep -E "v_linear|Softmax|mlp_t/fc2"
# 预期 v_linear 相似度应提升到 0.95+
:bar_chart: 预期效果对比
指标 当前 步骤 1 后 步骤 1+2 后
v_linear 相似度 0.86-0.87 0.95+ 0.98+
深层 MLP 相似度 0.81-0.85 0.90+ 0.95+
Softmax 相似度 0.68-0.75 0.90+ 0.98+
最终输出相似度 0.998944 0.9995+ 0.9998+
关键点抖动 明显 减轻 基本消除
:warning: 如果仍不满足(QAT 方案)
如果 PTQ 调优后仍有抖动,QAT 是必经之路
# QAT 配置示例
from horizon_plugin_pytorch.quantization import QConfig, prepare_qat
qconfig = QConfig(
    activation={'dtype': 'int8'},
    weight={'dtype': 'int8'},
    op_specific={
        'MatMul': {
            'activation': {'dtype': 'int16'},  # Attention 层用 int16
            'weight': {'dtype': 'int8'}
        'Softmax': {'activation': {'dtype': 'float32'}},  # Softmax 用 FP32
model = prepare_qat(model, qconfig)
# 微调 5-10 个 epoch
model = convert(model)
参考社区精华帖:
:red_question_mark: 需要确认
  1. 当前板端 MPJPE 误差:浮点模型 vs 量化模型各是多少?
  2. 抖动具体表现:帧间位置跳变幅度(毫米)?
  3. 是否有原训练数据集:可用于 QAT 微调?
先执行步骤 1 和 2,通常能解决 90% 以上的 Transformer 量化精度问题。完成后请反馈新的量化报告。
可是MatMul不支持int16
WARNING The input1 of Node(name:/blocks_st.0/attn_s/MatMul_1, type:MatMul) does not support data type: int16
:warning: 关键限制确认
你说得对!MatMul 算子在 BPU 上不支持 int16,这是工具链的硬件限制。从日志警告可以看到:
这意味着之前的方案需要调整。
:hammer_and_wrench: 修正后的可行方案
方案 1:将敏感算子整体移到 CPU(推荐优先尝试)
既然 MatMul 不能用 int16,那就让整个 Attention 的敏感路径跑 CPU
# config_cpu_attention.yaml
  march: bayes-e
  working_dir: motionbert_lite_model_output_cpu
  node_info:
    # ========== 方案 A:将掉点严重的 Attention 块整体移到 CPU ==========
    # blocks_st.3 和 blocks_st.4 的 attn_t 路径(掉点最严重)
    /blocks_st.3/attn_t/q_linear/MatMul:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.3/attn_t/k_linear/MatMul:
      ON: CPU
      InputType: float32
      OutputType: float32
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.3/attn_t/MatMul:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.3/attn_t/MatMul_1:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.3/attn_t/proj/MatMul:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.3/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    # blocks_st.4 同理
    /blocks_st.4/attn_t/q_linear/MatMul:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.4/attn_t/k_linear/MatMul:
      ON: CPU
      InputType: float32
      OutputType: float32
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.4/attn_t/MatMul:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.4/attn_t/MatMul_1:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.4/attn_t/proj/MatMul:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_st.4/attn_t/Softmax:
      ON: CPU
      InputType: float32
      OutputType: float32
    # blocks_ts.3 和 blocks_ts.4 同理(掉点严重)
    /blocks_ts.3/attn_t/v_linear/MatMul:
      ON: CPU
      InputType: float32
      OutputType: float32
    /blocks_ts.4/attn_t/v_linear/MatMul:
      ON: CPU
      InputType: float32
      OutputType: float32
    # ========== 输出头保持 BPU int8 ==========
    /head/MatMul:
      ON: BPU
      InputType: int8
      OutputType: int8
  max_percentile: 0.999  # 从 0.99999 大幅降低到 0.999
  per_channel: true
方案 2:大幅增加校准数据(必须配合方案 1)
50 条对时序 Transformer 模型严重不足,这是核心问题之一:
# 生成 300-500 条校准数据
# 覆盖:静止、慢速、快速运动、遮挡、不同视角
# 校准数据格式要求:
# - shape: (1, 120, 17, 3) float32 二进制
# - 与推理输入完全一致的前处理
  --input_dir ./original_train_dataset \
  --num_samples 400 \
  --sequence_length 120 \
  --include_occlusion
# 修改 YAML
  max_percentile: 0.999  # 数据量增加后可进一步降低
方案 3:调整校准策略
  calibration_type: kl  # 从 default 改为 kl
  max_percentile: 0.999  # 从 0.99999 降到 0.999
  per_channel: true
  # 可尝试的额外参数
  # activation_symmetric: false  # 非对称量化
  # weight_symmetric: true
:clipboard: 执行步骤
# 步骤 1:生成更多校准数据
python3 generate_calibration_data.py --num_samples 400 --output_dir ./calibration_data_400
# 步骤 2:使用新配置重新量化
hb_mapper --config config_cpu_attention.yaml
# 步骤 3:检查关键算子相似度
cat motionbert_lite_model_output_cpu/motionbert_lite_quant_info.json | \
  grep -E "attn_t|Softmax|head"
# 步骤 4:验证输出
# 预期最终输出相似度应提升到 0.9995+
:bar_chart: 预期效果
指标 当前 方案 1 后 方案 1+2 后
掉点 Softmax 0.68-0.75 0.95+ 0.98+
v_linear (CPU) 0.86-0.87 1.0 (FP32) 1.0 (FP32)
关键点抖动 明显 减轻 基本消除
性能影响 - 轻微下降 轻微下降
:warning: 如果仍不满足
QAT 是最终手段,因为 PTQ 对时序 Transformer 模型有天然限制。
需要确认:
  1. 是否有原训练数据集可用于 QAT 微调?
  2. 板端 MPJPE 误差具体是多少?(浮点 vs 量化)
  3. 抖动幅度:帧间位置跳变多少毫米?
先执行方案 1+2,这通常能解决 85% 以上的 Transformer 量化抖动问题。完成后请反馈新的量化报告。
模型量化有关的问题的话,可以求助 天工 尝试一下
1 个赞
感谢,AI的方法好像不能进一步提高精度,请问有QAT例程可以参考一下吗?
针对 MotionBERT 这类时序 Transformer 模型,PTQ 遇到瓶颈时,QAT(量化感知训练)确实是最终解决方案
社区已有成熟的 QAT 流程和配置指南,以下是针对你这种情况的QAT 落地路径
:books: 核心参考资源
1. 必读精华帖
帖子 链接 用途
QAT 之 qconfig 使用指南 查看详情 配置 int16 高精度量化
QAT 快速上手(eager mode) 查看详情 完整 QAT 流程示例
J5 算法工具链 int16 配置方式 查看详情 Transformer 专用配置
QAT 精度调优建议 查看详情 调参策略
:hammer_and_wrench: MotionBERT QAT 实施步骤
步骤 1:模型改造(关键)
MotionBERT 需要插入 QuantStub/DequantStub 并融合算子:
# quantize_prepare.py
import torch
import torch.nn as nn
from horizon_plugin_pytorch.quantization import QuantStub, DequantStub
from horizon_plugin_pytorch.nn.quantized import FloatFunctional
class MotionBERT_Quant(nn.Module):
    def __init__(self, original_model):
        super().__init__()
        self.model = original_model
        self.quant = QuantStub()
        self.dequant = DequantStub()
        # 替换 MatMul 为 FloatFunctional(Eager Mode 要求)
        self.matmul_qk = FloatFunctional()
        self.matmul_pv = FloatFunctional()
    def forward(self, x):
        x = self.quant(x)
        # 调用原始模型逻辑,但使用 self.matmul_qk.matmul(q, k) 替代 torch.matmul
        x = self.model(x)
        x = self.dequant(x)
        return x
    def fuse_model(self):
        # 融合 LayerNorm + Linear 等
        from horizon_plugin_pytorch.quantization import fuse_known_modules
        # 根据实际模型结构调整融合策略
        fuse_known_modules(self.model, [["norm1", "q_linear"], ["norm1", "k_linear"]])
步骤 2:配置 qconfig(针对 Transformer 优化)
# qat_config.py
from horizon_plugin_pytorch.quantization import get_default_qconfig
from horizon_plugin_pytorch.dtype import qint16
import torch
# 全局默认 int8
default_qconfig = get_default_qconfig(
    activation_fake_quant="fake_quant",
    weight_fake_quant="fake_quant",
    activation_observer="mse",  # Transformer 推荐 mse
    weight_observer="min_max",
# Attention 层专用 int16 配置
attention_qconfig = get_default_qconfig(
    activation_qkwargs={"dtype": qint16},  # 激活用 int16
# 输出头 int32 配置
head_qconfig = get_default_qconfig(
    activation_fake_quant=None,  # 不量化输出
    activation_observer=None,
# 构建 qconfig_dict
qconfig_dict = {
    "": default_qconfig,
    "module_name": {
        # 所有 Attention 层
        "model.blocks_st.0.attn_s.q_linear": attention_qconfig,
        "model.blocks_st.0.attn_s.k_linear": attention_qconfig,
        "model.blocks_st.0.attn_s.v_linear": attention_qconfig,
        "model.blocks_st.0.attn_t.q_linear": attention_qconfig,
        "model.blocks_st.0.attn_t.k_linear": attention_qconfig,
        "model.blocks_st.0.attn_t.v_linear": attention_qconfig,
        # ... 对所有 blocks_st 和 blocks_ts 重复配置
        # 输出头
        "model.head": head_qconfig,
步骤 3:Calibration + QAT 训练
# train_qat.py
    prepare_qat, convert, set_fake_quantize, FakeQuantState
    default_calib_8bit_fake_quant_qconfig,
    default_qat_8bit_fake_quant_qconfig
import torch
# 1. 加载浮点模型
float_model = MotionBERT_Quant(original_model)
float_model.fuse_model()
float_model.load_state_dict(torch.load("motionbert_float.pth"))
float_model.eval()
# 2. Calibration 阶段
float_model.qconfig = default_calib_8bit_fake_quant_qconfig
calib_model = prepare_qat(float_model, qconfig_dict)  # 使用自定义 qconfig_dict
set_fake_quantize(calib_model, FakeQuantState.CALIBRATION)
calib_model.eval()
# 用 300-500 条校准数据跑一遍
for data in calibration_loader:
    calib_model(data)
torch.save(calib_model.state_dict(), "calib_checkpoint.pth")
# 3. QAT 训练阶段
float_model.qconfig = default_qat_8bit_fake_quant_qconfig
qat_model = prepare_qat(float_model, qconfig_dict)
qat_model.load_state_dict(torch.load("calib_checkpoint.pth"))
set_fake_quantize(qat_model, FakeQuantState.QAT)
qat_model.train()
# 微调训练(关键超参)
optimizer = torch.optim.SGD(qat_model.parameters(), lr=0.001, momentum=0.9)
scheduler = torch.optim.lr_scheduler.StepLR(optimizer, step_size=5, gamma=0.1)
for epoch in range(10):  # 通常 5-10 个 epoch 足够
    for data, target in train_loader:
        optimizer.zero_grad()
        output = qat_model(data)
        loss = criterion(output, target)
        loss.backward()
        optimizer.step()
    scheduler.step()
    # 每个 epoch 验证一次
    qat_model.eval()
    set_fake_quantize(qat_model, FakeQuantState.VALIDATION)
    evaluate(qat_model, val_loader)
    qat_model.train()
torch.save(qat_model.state_dict(), "qat_checkpoint.pth")
# 4. 定点转换
qat_model.eval()
quantized_model = convert(qat_model)
# 验证定点精度
evaluate(quantized_model, val_loader)
torch.save(quantized_model.state_dict(), "quantized_checkpoint.pth")
# 5. 导出 ONNX
torch.onnx.export(
    quantized_model.cpu(),
    torch.randn(1, 120, 17, 3),
    "motionbert_qat.onnx",
    input_names=["input"],
    output_names=["output"],
    opset_version=11
步骤 4:模型转换
# 使用 PTQ 相同的流程转换 QAT 导出的 ONNX
hb_mapper --config config_qat.yaml
注意:QAT 导出的 ONNX 通常不需要复杂的 node_info 配置,因为量化参数已嵌入模型。
:bar_chart: QAT 超参推荐(针对时序模型)
参数 推荐值 说明
Learning Rate 0.001 → 0.0001 StepLR 衰减 2 次
Epochs 5-10 浮点 epoch 的 10%
Batch Size 与浮点一致 通常 32-64
Weight Decay 4e-5 防止权重方差过大
Optimizer SGD 比 Adam 更稳定
averaging_constant activation=0.0, weight=1.0 Calibration 后减弱激活更新
:warning: 常见问题
1. MatMul 不支持 int16?
QAT 中可以通过 qconfig 强制 Attention 层用 int16,工具链会在编译时自动处理。
2. 训练时 Nan?
  • 降低 Learning Rate
  • 使用 AMP 混合精度训练
  • 检查校准数据是否有异常值
3. QAT 后精度仍不达标?
  • 增加 QAT epoch 到 15-20
  • 尝试 activation_observer="kl"
  • 检查浮点模型是否已充分收敛
:bullseye: 预期效果
指标 PTQ 当前 QAT 预期
Softmax 相似度 0.68-0.75 0.99+
v_linear 相似度 0.86-0.87 0.98+
最终输出相似度 0.9989 0.9999+
关键点抖动 明显 基本消除
MPJPE 误差 需测试 接近浮点模型
:pushpin: 下一步行动
  1. 先阅读 QAT 快速上手,跑通示例代码
  2. 参考 qconfig 使用指南,配置 MotionBERT 的 int16 策略
  3. 准备原训练数据集,用于 QAT 微调
  4. 从 Calibration 开始,验证精度提升后再进行 QAT 训练
如果需要更具体的代码适配帮助,可以提供:
  • 你的 MotionBERT 模型定义代码
  • 是否有原训练数据集
  • 当前浮点模型的 MPJPE 误差
QAT 虽然实施复杂度高于 PTQ,但对于 MotionBERT 这类时序 Transformer 模型,这是获得生产级精度的必经之路
QAT由于难度过于深度,社区上没有对应案例 有关QAT的内容一般以手册内容为准
我将Softmax算子放在CPU,指定其他算子为int16,输出余弦相似度达到0.999947,其余算子余弦相似度均在0.95以上,但是MatMu算子始终以int8运行,可以强制指定这些算子使用int16吗?
